07 Eos MFD2 Headunit upgrade to RNS-315
tehfalcon
C?ID=235987
I have just upgraded the head unit from an MFD2 to an RNS-315, but the steering wheel buttons do not work for the radio, there is no Audio section in the MFD, and I cannot access the Radio in VCDS.
Everything is working on the radio itself, so I am confused.
Here is my Autoscan
Saturday,31,December,2016,15:37:02:15363
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 16.8.1.3 (x64)
Data version: 20160902 DS256
VIN: WVWDB71FX7V032118   License Plate:
Mileage: 83980km-52182mi   Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 26 37 42 44 46 47 52 55 56
          62 63 65 72 73 76
VIN: WVWDB71FX7V032118   Mileage: 83980km-52182miles
1C-Position Sensing -- Status: Cannot be reached 1100
63-Entry Assist,D -- Status: OK 0000
73-Entry Assist, P -- Status: OK 0000
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 CF    HW: 022 906 032 GP
   Component: MOTRONIC ME7.1.1G   9378
   Revision: --H02---    Serial number: VWX7Z0FD3NK831
   Coding: 0000078
   Shop #: WSC 00020 000 00000
   VCID: 518786A0C8D539CA71-8005
Readiness: 0110 1101
   Part No SW: 02E 300 043 T    HW: 02E 927 770 AE
   Component: GSG DSG         070 1302
   Revision: 04507000    Serial number: 00000611180305
   Shop #: WSC 44551 111 44551
   VCID: 256F0270ECDD056AFD-8071
   Revision: 00H11001
   Coding: 0021218
   VCID: 73CB2C2812892BDAA3-8027
   Part No SW: 1Q0 907 044 A    HW: 1Q0 907 044 A
   Component: ClimatronicPQ35 093 0101
   Revision: 00093002    Serial number: 00000000000000
   VCID: 2B7BF4488A39331A2B-807F
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006364893
   Coding: F704D30940041500550000000F00000000490000640001
   Shop #: WSC 00020 123 12345
   VCID: 6CF937544FB7F42262-8039
   Component: Wischer 121206 020  0501
   Coding: 00040853
   Shop #: WSC 00020
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     081206 020  0105
   Coding: 00471077
   Shop #: WSC 00020
01834 - Bulb for Side-Blinkers; Left (M18)
01835 - Bulb for Side-Blinkers; Right (M19)
02390 - Control / Regulation for Ambience Lighting (E400)
            009 - Open or Short to Ground
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 14 Airbag VW8C      0180
   Revision: 92009018    Serial number: 003B30019891
   Coding: 0012596
   VCID: 3A55C10C75639A92A0-806F
   Subsystem 1 - Part No: 1Q0 959 339 A
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 3JDAU
   Subsystem 3 - Serial number: 0001.01.000000700000000000ˇÜ63
   Subsystem 4 - Serial number: 000000ˇÜ6332SRB40472C816 ˇÜ63
   Subsystem 5 - Serial number: 2C816 ˇÜ6342SRB404734E21YˇÜ63
   Subsystem 6 - Serial number: 34E21YˇÜ6372URB401E0C2EBFˇÜ63
   Subsystem 7 - Serial number: 0C2EBFˇÜ6382URB401E0B5597ˇ
   Subsystem 8 - Serial number: 0B5597ˇ
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0012121
   VCID: 012776E05835094AA1-8055
01749 - Switch for Tiptronic in Steering Wheel (E439); Down
   Part No SW: 1Q0 920 973 B    HW: 1Q0 920 973 B
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWX7Z0FD3NK831
   Coding: 0023207
   Shop #: WSC 20129 444 100640
   VCID: 3245E92CAD1362D268-8067
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H12 0170
   Revision:   H12       Serial number: 3300106B200A6B
   Coding: 7FBF274A0F065000
   VCID: 2F43E058BE214F3A07-807B
00484 - Vehicle Position Recognition Control Module (J603)
Address 1C: Position Sensing
   Component: IMMO            VDD 1610
   Shop #: WSC 53959 001 1048576
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 B    HW: 1Q0 959 255 B
   Component: Verdecksteuergeraet 0622
   Revision: 0032000K    Serial number: 063200631
   Coding: 0655362
   VCID: 3753D838467187FA5F-8063
Address 37: Navigation
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1Q0 959 701 E    HW: 1Q0 959 701 E
   Component: Tuer-SG         004 1209
   Coding: 0001207
   VCID: 364DD53C417B7EF244-8063
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.071 H07 1806
   VCID: 3449EF3457076CE27A-8061
   Component:    KSG PQ35 RDK 052 0218
   Coding: 1A908B800186403F3F020F0FF0000E0088D840
   VCID: 04297FF447271C628A-8051
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No SW: 1Q0 035 456 B    HW: 1Q0 035 456 B
   Component: DSP 10 Kanal        0013
   Revision: 00010000    Serial number: 00000000005051
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1Q0 959 702 E    HW: 1Q0 959 702 E
   Coding: 0001206
   Part No SW: 5M0 907 357 A    HW: 5M0 907 357 A
   Component: AFS-Steuergeraet    X014
   Revision:   H01       Serial number:
   Coding: 2519043
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0002
   Coding: 00000038
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0002
   Coding: 00000038
Address 56: Radio
   Part No SW: 1Q0 959 703 A    HW: 1Q0 959 703 A
   Component: Tuer-SG         004 1202
   Coding: 0000128
   Shop #: WSC 00020 000 1012544
Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
   Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
   Component: J572  EASYENTRY FS  0603
   Revision: 00H02000    Serial number: 5DS008646-01--
   Component:    RDK              0440
   Coding: 0100101
   Part No SW: 1Q0 959 704 A    HW: 1Q0 959 704 A
   Coding: 0000128
   VCID: 354FD2305C7D75EA4D-8061
Address 73: Entry Assist, P        Labels: 1Q0-959-790.lbl
   Component: J573  EASYENTRY BFS 0603
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1Q0 919 283 A
   Component: 30 Einparkhilfe     0802
   VCID: 334BEC2852096BDA63-8067
End-------------------------(Elapsed Time: 01:39)--------------------------
m87a
Bosnia and Herzegovina
C?ID=156900
remove position sensing module or compass in golf it was under roof lining and in jetta it was in trunk above metal sheet, you will see 2 screws, possibly in eos it's also in trunk
also remove in gateway coding Address 1C: Position Sensing
your gateway has software 170 but can be updated to 178 which will support navigation and also stop battery drain
in navigation try to find protocol BAP and untick it, you have red display?
tehfalcon
C?ID=235987
I will try to locate the compass module. I also do have a red MFD yes.
Also how is the gateway updated?
golfi_vend
Tartu, Estonia
C?ID=195131
Rns315 supports only BAP(white cluster).
tehfalcon
C?ID=235987
Great, but that would mean the only thing that wouldn't work is the Audio Section in the MFD correct?
MSFW Buttons should be able to work and I should be able to access the Navigation Module to enable Dynaudio no? (I do have dynaudio).
Spacewalker
Poland
C?ID=159607
Nothing
No Audio, No radio, no Satnav, no BT phone on the cluster
also MFSW might not fully work, because cluster is partly responsibile for that
tehfalcon
C?ID=235987
Nothing
So I won't have MFSW either? Removing the compass module and removing it from the can gateway will allow me to access the radio in VCDS?
Spacewalker
Poland
C?ID=159607
access to radioa via VCDS can be done if you have proper Gateway
Access to Radio via Instrument cluster - need proper cluster
tehfalcon
C?ID=235987
What gateway do I need?
tehfalcon
C?ID=235987
Not sure if 1K0 907 530 L, definatelly Q or any from 2008/9
Alright I ordered 1K0907530Q.
Also removing compass module. So everything should work except for MFD audio section correct after this?
Spacewalker
Poland
C?ID=159607
already told you what might be wrong if you have RED display cluster
