VCDS-Mobile
Auto-Scan
Finished
Chassis Type:1C 9C AG 1Y or AL
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
Address 01: Engine Labels: None
Part No SW: 06A 906 018 EQ
Component: 2.0l R4/2V MOTR AT V06
Coding: 00033
Shop #: WSC 02352 000
VCID: 75AD72D746FF37958D950B6F17-4B3C
17663 - Engine Coolant Temp Sensor (G62)
P1255 - 35-10 - Short to Ground - Intermittent
16515 - Oxygen (Lambda) Sensor B1 S1
P0131 - 35-10 - Signal too Low - Intermittent
P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No SW: 01M 927 733 KB
Component: AG4 Getriebe 01M 4725D
Coding: 00000
Shop #: WSC 00000 000
VCID: 7AB761EB6FE158EDE0C740ABD6-0964
No fault codes found.
Address 03: ABS Brakes Labels: None
Part No SW: 1J0 907 379
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 00066 000
VCID: EE9FDDBBA3A9844DCC4F3C3BFA-4B3C
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No SW: 6Q0 909 605
Component: 16 AIRBAG VW5 0D 0004
Coding: 12598
VCID: F4ABCFD3CD85AE9D3A8B7E6384-4B3C
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1C0-920-xx0.lbl
Part No SW: 1C0 920 901
Component: KOMBI+WEGFAHRS. M73 V07
Coding: 03202
Shop #: WSC 02407 000
VCID: D9F59E674A27F3F5097D573FEB-4B3C
Subsystem 1 - Part No SW: Ide-nt.--Nr-.
Component: egfahrs.:VWZ5Z0Y7096036
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No SW: 6N0 909 901
Component: Gateway K<->CAN V072
Coding: 00007
VCID: F0A3C3C3B99D92BDDE635253D0-4B3C
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No SW: 1J0 959 799 AJ
Component: 5X Zentral-SG Komf. 0001
Coding: 00256
VCID: 864F851BAB19AC0D143FC45B32-4B3C
Subsystem 1 - Part No SW: 1J2-959-802-C
Component: 5X Türsteuerger. FS0002r
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No SW: 1C0 035 180 E
Component: RADIO 3CP 0002
Coding: 00401
VCID: 1A77416B8FA1B8ED4007202BB6-4B3C
End-------------------------(Elapsed Time: 06:23)--------------------------
Save Done, Go Back
