2001 New Beetle 2.0L AEG via VCDS Mobile
MattF-MN
C?ID=134881
 VCDS-Mobile
Auto-Scan
Finished
Chassis Type:1C 9C AG 1Y or AL
Scan: 01 02 03 08 15 17 19 22 25 26 29 35 37 39 46 54 56 65 75
Address 01: Engine	Labels: None
	Part No SW: 06A 906 018 EQ
	Component: 2.0l R4/2V  MOTR AT V06
	Coding: 00033
	Shop #: WSC 02352 000
	VCID: 75AD72D746FF37958D950B6F17-4B3C
17663 - Engine Coolant Temp Sensor (G62)
	P1255 - 35-10 - Short to Ground - Intermittent
16515 - Oxygen (Lambda) Sensor B1 S1
	P0131 - 35-10 - Signal too Low - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
	P0300 - 35-10 - - - Intermittent
16685 - Cylinder 1
	P0301 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
	P0302 - 35-10 - Misfire Detected - Intermittent
Address 02: Auto Trans	Labels: 01M-927-733.lbl
	Part No SW: 01M 927 733 KB
	Component: AG4 Getriebe 01M    4725D
	Coding: 00000
	Shop #: WSC 00000 000
	VCID: 7AB761EB6FE158EDE0C740ABD6-0964
No fault codes found.
Address 03: ABS Brakes	Labels: None
	Part No SW: 1J0 907 379
	Component: ABS     20 IE CAN  0001
	Coding: 03504
	Shop #: WSC 00066 000
	VCID: EE9FDDBBA3A9844DCC4F3C3BFA-4B3C
Address 15: Airbags	Labels: 6Q0-909-605-VW5.lbl
	Part No SW: 6Q0 909 605
	Component: 16 AIRBAG VW5  0D   0004
	Coding: 12598
	VCID: F4ABCFD3CD85AE9D3A8B7E6384-4B3C
Address 17: Instruments	Labels: 1C0-920-xx0.lbl
	Part No SW: 1C0 920 901
	Component: KOMBI+WEGFAHRS. M73 V07
	Coding: 03202
	Shop #: WSC 02407 000
	VCID: D9F59E674A27F3F5097D573FEB-4B3C
	Subsystem 1 - 	Part No SW: Ide-nt.--Nr-.
	Component: egfahrs.:VWZ5Z0Y7096036
Address 19: CAN Gateway	Labels: 6N0-909-901-19.lbl
	Part No SW: 6N0 909 901
	Component: Gateway K<->CAN    V072
	Coding: 00007
	VCID: F0A3C3C3B99D92BDDE635253D0-4B3C
Address 46: Central Conv.	Labels: 1J0-959-799.lbl
	Part No SW: 1J0 959 799 AJ
	Component: 5X Zentral-SG Komf. 0001
	Coding: 00256
	VCID: 864F851BAB19AC0D143FC45B32-4B3C
	Subsystem 1 - 	Part No SW: 1J2-959-802-C
	Component: 5X Türsteuerger. FS0002r
00953 - Interior Light Time limit
	25-10 - Unknown Switch Condition - Intermittent
	35-00 - -
	35-00 - -
Address 56: Radio	Labels: 1J0-035-18x-56.lbl
	Part No SW: 1C0 035 180 E
	Component:  RADIO 3CP         0002
	Coding: 00401
	VCID: 1A77416B8FA1B8ED4007202BB6-4B3C
End-------------------------(Elapsed Time: 06:23)--------------------------
Save Done, Go Back
