Hello Guys, this is my first post on this forum and was hoping for some help.
I have replaced the pressure sensor called G450, the one connected to the DPF. The dealership told me that the sensor needed to be adapted, so then the search for excact instructions started.
I found these instructions
Select engine (01)
Login or coding 11
Type 30605 in the box and login.
But i get a error message when i hit activate, says that is not a valid command and that i need to turn of my ignition before i try another code. I was hoping you guys know a alternative.
Here is my autoscan:
Select engine (01)
Login or coding 11
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 34 37 42 46 47 4F 52 53
55 56 61 62 69 72 76 77
VIN: WAUZZZ4F27N050540 Mileage: 161750km-100506miles
Part No SW: 4F5 910 401 E HW: 4F0 907 401 C
Component: 2.7L V6TDI 000AG 0010
Revision: --H03--- Serial number:
Coding: 0011372
Shop #: WSC 02335 785 00200
VCID: 2345BC3EE2FD275A93-8076
009263 - Diesel Particulate Filter (Bank 1)
P242F - 001 - Restricted/Clogged - MIL ON
Fault Status: 11100001
Mileage: 161750 km
Date: 2016.09.19
Time: 17:45:53
(no units): 0.0
(no units): 42.0
(no units): 35.5
Temperature: 23.6°C
Absolute Pres.: 0.0 mbar
Pressure: 0 mbar
Readiness: 1 1 1 1 1
