Wednesday,31,August,2016,19:47:07:05371
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: 3VW447AU5GM054463 License Plate:
Mileage: 497km-308mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 32 42 44 47 52 55 5F 75 A9
VIN: 3VW447AU5GM054463 Mileage: 497km-308miles
Address 01: Engine (J623-CXCB) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00124424002F1000
Shop #: WSC 00066 790 00149
ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
ROD: EV_ECM20TFS0205G0906259D.rod
VCID: 2F6682447609B73A09-807A
Part No SW: 0D9 300 020 J HW: 02E 927 770 AQ
Component: DQ250-6V MQB H53 4931
Revision: 06253104 Serial number: TFK01601071364
ROD: EV_TCMDQ250021.rod
VCID: 1C3C458817BF3CA25C-8048
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 50476000001575
Coding: 01FA6BA154250970007B020641C66880D62A9000408216B600430051C009
Shop #: WSC 01383 790 50316
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 4B9EF6D4E2D1EB1A05-801E
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0390003422
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_VW37.rod
VCID: 3A70A310BD4B6292AE-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 00020014200100000005000012111402
ROD: EV_ACClimaBHBVW37X_VW37.rod
VCID: 4280DBF0D59B2A52F6-8016
B10CD 00 [008] - -
Fault Frequency: 11
Reset counter: 57
Mileage: 18 km
Date: 2011.03.25
Time: 20:47:00
Voltage terminal 30: 12.0 V
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 86580501160132
Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
Shop #: WSC 00066 790 00208
ROD: EV_BCMBOSCH_VW37.rod
VCID: 7AF06310FDCBA292EE-802E
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150819 043 0581
Serial number: 160308075257
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S2Y15M12D21H08M03S17
Coding: 90A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03691632992208150902
Coding: 181803
527872 - Transport Mode Active
U1105 00 [008] - -
Fault Frequency: 128
Reset counter: 57
Mileage: 16 km
Date: 2011.02.27
Time: 01:29:16
Component: AirbagVW20 010 0830
Serial number: 003GCR04817Z
VCID: 4796CAE4FEB90F7A21-8012
Occupant Detection:
Component: BF-Gewichtss. H12 0021
Serial number: IBH000000000004K1DXV
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 001 401 16
Serial number: 35700000000EECEC681A
Subsystem 3 - Part No SW: ----------- HW: 480 001 401 16
Serial number: 35800000000BAAEC6812
Subsystem 4 - Part No SW: ----------- HW: 480 401 301 16
Serial number: 3510002A91E85EA2940B
Subsystem 5 - Part No SW: ----------- HW: 480 401 301 16
Serial number: 35200029D1E9F104313%
Subsystem 6 - Part No SW: ----------- HW: 480 401 101 16
Serial number: 35500029D1E85EA4A2DW
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 101 16
Serial number: 35600029D1E85EA320FO
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151204500502
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 040C1DE88F0FE46284-8050
Part No SW: 5G1 920 856 A HW: 5G1 920 856 A
Component: KOMBI 342 6420
Coding: 0BAD091AA980CF0502086A001000000000000000
VCID: 2C5C9548471FCC222C-8078
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 09121510800510
Coding: 0101000830085900FB00022B1C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07027
ROD: EV_GatewConti.rod
VCID: 79F27C1CF8CDA98AE7-802C
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H11 0103
Serial number: 29150002294890025473
Coding: 31FFFF
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000012381010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_VW37.rod
VCID: 346C8D289F2F94E274-8060
Address 32: Differential Locks (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00010.11.15
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
Component: TSG FS 020 0041
Serial number: 11021606050BQ1
Coding: 003E13200000020000000000
VCID: 438EDEF4CA81235AFD-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Serial number: 00000000000011426303
Coding: 011000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8102
VCID: 3972BC1CB84D698AA7-806C
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0130
Revision: 00000001 Serial number: VWZ8Z1FBA01C4VB
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6DDA584CBC85052A7B-8038
Component: TSG BFS 020 0041
Serial number: 11021606050DSR
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Serial number: 00000000000011437017
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021A01010B000400
VCID: 4084D1F8DB973842E0-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 HW: 3Q0 035 876
Component: MU-S-NS-US 820 0613
Coding: 027300020000000051220002001808001F0203F401200105C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 71E2443CA0BDE1CA5F-8024
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9RJX002L7
Subsystem 2 - Part No SW: 3G0 919 866 R HW: -----------
Component: NAR 2016 --- 0321
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C2823A017F1E06000000
ROD: EV_OCULowMQB.rod
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 151215201401
VCID: 6BDE565482910B1A65-803E
End-------------------------(Elapsed Time: 04:27)--------------------------
