- Joined
- Oct 7, 2015
- Messages
- 53
- Reaction score
- 14
- VCDS Serial number
- C?ID=180423
I have a stage 1 tuned 2003 GTI [AWP] that seems to be eating #4 coilpacks. I have killed 3 of them in less than 2 weeks, which immediately makes me think something else is going on. First time it happened I was accelerating and I started misfiring hard. Turned around, got home, scanned, found #2 & #4 intermittent misfires, grabbed 2 "old but good" coilpacks out of the garage, and away I went. Until that afternoon, when accelerating again #4 went out. Got home, swapped an old-but-good in, and that worked for about a week. Today I felt it miss a couple times under heavy load. So I took it easy on it, but I was an hour away from home and ended up limping on 2 or 3 cylinders the last 15 minutes. I just put in the last of my old-but-goods, and ran it around the block with no hesitation. I think it's weird that #4 always goes, and #2 went with it on the two times I've had to limp home, though #2 goes "intermittent,"#4 is just solid misfire, as you'll see in the autoscan below. I also think it's weird that it starts to happen under heavy, almost WOT load, then progessively gets worse until the coilpack is totally dead, or so it appears. This happens whether I'm using the stock tune or a 93 octane stage 1 tune, I've switched it over 2 times while this has happened.
I put new plugs in after the first go-around, and the old plugs looked fine. I want to think putting in all new coilpacks would fix it, but that's a $125 mistake waiting to happen, I feel. Thoughts?
Thanks in advance,
Chris
Thanks in advance,
Chris
Wednesday,31,August,2016,20:23:12:59113
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: 9BWKE61J634078581 License Plate:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
76
VIN: 9BWKE61J634078581 Mileage: 246980km-153466miles
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Part No: 06A 906 032 KP
Component: 1.8T S2V5.0 G01 0005
Coding: 07510
Shop #: WSC 21591
VCID: 76E3BB275221D4F28A-5140
9BWKE61J634078581 VWZ7Z0C7130981
P0300 - 35-00 -
16688 - Cylinder 4
P0304 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 35-00 - Misfire Detected
Readiness: 0010 1101
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019970
Shop #: WSC 00000 785 00200
VCID: 3467412F54DD86E274-5124
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 0S AIRBAG VW61 0108 0003
Coding: 12371
VCID: 275DA663C50BFD7AC1-5106
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J6 920 906
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 07234
VCID: 6BD59A531963191A65-5106
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
VCID: 70EF8D3F3045FAC250-5124
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8B Komfortgerát HLO 0003
Coding: 00064
VCID: 377D762315AB6DFA51-4B00
Component: 8B Tõrsteuer.FS KLO 0009
Component: 8B Tõrsteuer.BF KLO 0009
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 E
Component: Radio ZSW 0010
Coding: 00031
VCID: 224BB777AE29185296-5124
End-------------------------(Elapsed Time: 05:17)--------------------------
