I just bought a brand new Golf about two months ago and recently picked up a new Micro-CAN cable. I wanted to program the car to open and close the windows with the remote, but before I did that I did an Auto Scan to make sure everything was a-okay. When I preformed the scan it came up with a few errors in some of the secondary systems. I don't know if this is normal (I would think not). Should I go to the dealer? If I show them the Auto Scan report, would the dealer know how to interpret the results? I'm going to copy and paste the report in this message so you guys can take a look. Should I be concerned?
Saturday,20,August,2016,11:21:16:22105
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
VIN: 3VW217AU7GM055601 License Plate:
Mileage: 3015km-1873mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 52 55 5F
75 A5
VIN: 3VW217AU7GM055601 Mileage: 3015km-1873miles
Address 01: Engine (J623-CXBB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 264 F HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0004
Revision: --H13---
Coding: 091A00322464002F1000
Shop #: WSC 00066 790 00060
ASAM Dataset: EV_ECM18TFS0208V0906264F 001004
ROD: EV_ECM18TFS0208V0906264F.rod
VCID: 3FA3BE62A62BE5BA99-806A
17178 - Databus
Address 02: Auto Trans (J217) Labels: 09G-927-749.clb
Part No SW: 09G 927 749 AP HW: 09G 927 749 AP
Component: AISIN AG6 G3 129 2943
Coding: 010200000C000000000000000000000000000000
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031.rod
VCID: 07336682BE7B6D7AE1-8052
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60326000000119
Coding: 01FA6AA124250971007D020081C4298056249000408194B416405052C082
Shop #: WSC 01383 790 50316
VCID: 7AD50F76FD890092EE-802E
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0391975429
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_VW37.rod
VCID: 3A55CF76BD09C092AE-806E
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5GM 907 426 A HW: 5GM 907 426 A
Component: AC Manuell H02 1001
Revision: 00001K01
Coding: 00020004200100000100000000000002
ROD: EV_ACManueBHBVW37X.rod
VCID: 46ADAB86F9F1B472DA-8012
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 86580712150450
Coding: 00111A464041A26969E44000001407001800000000000000000000000000
Shop #: WSC 00066 790 00194
ROD: EV_BCMBOSCH_VW37.rod
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150819 043 0581
Serial number: 160308143010
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S5Y15M12D28H06M20S49
Coding: 90A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03691681042208152054
Coding: 181803
131586 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
722437 - Control Module for Power Sunroof
B13C6 54 [009] - Missing Calibration / Basic Setting
Reset counter: 9
Mileage: 20 km
Date: 2016.05.20
Time: 00:00:14
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39491533702419
Coding: 0031165011
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_VW37.rod
VCID: 47B3A682FEFBAD7A21-8012
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 28071503211941
Coding: 01045400FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
Component: AirbagVW20 010 0830
Serial number: 003GCR04ADKJ
Occupant Detection:
Component: BF-Gewichtss. H12 0021
Serial number: IBH000000000004KUN3/
Coding: 303135
Subsystem 2 - Part No SW: ----------- HW: 480 000 102 16
Serial number: 35700000000B845CF51X
Subsystem 3 - Part No SW: ----------- HW: 480 000 102 16
Serial number: 358000000003045CF51I
Subsystem 4 - Part No SW: ----------- HW: 480 401 301 16
Serial number: 3510002A91E85EB4227C
Subsystem 5 - Part No SW: ----------- HW: 480 402 701 16
Serial number: 3520002C31E9F0E0B1DJ
Subsystem 6 - Part No SW: ----------- HW: 480 402 501 16
Serial number: 35500029B1EDD3E6223K
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 501 16
Serial number: 3560002A71E9F0E4D19R
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160126500539
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
VCID: 73CB2252DAE371DAAD-8026
Part No SW: 5G1 920 840 A HW: 5G1 920 840 A
Component: KOMBI 242 6420
Coding: 0BA4191AED98CF0502886A0B5000000000000000
VCID: 256F0C0A24B75F6AF3-8070
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 09121510800146
Coding: 0101000830085900FB00001A1C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07030
ROD: EV_GatewConti.rod
VCID: 79D7107AF88F0B8AE7-802C
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R
Component: E221__MFL-DC1 H16 0040
Serial number: 29150001633190015335
Coding: 35FFFF
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000011616010
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_VW37.rod
VCID: 3449E14E9F6D36E274-8060
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0391777731
Coding: 02011103
ROD: EV_HREntryHella.rod
VCID: 3C59C96EB73DFEA2BC-8068
Lane Change Assistant 2:
Component: TSG FS 020 0041
Serial number: 24021606050B2J
Coding: 003A13200000020000000000
VCID: 43ABB292CAC3815AFD-8016
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Serial number: 00000000000011666435
Coding: 011000
589829 - Window Regulator; Rear Driver side
B131F F5 [008] - Supply Voltage too Low
Mileage: 20 km
Date: 2016.05.19
Time: 23:50:17
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 1302
VCID: 44A9B18ECFCD8662C4-8010
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0130
Revision: 00000001 Serial number: VWZ8Z1FBA01B49V
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6DFF342ABCC7A72A7B-8038
Component: TSG BFS 020 0041
Serial number: 27021606050739
VCID: 42A5B796D5D98852F6-8016
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Serial number: 00000000000011513780
Coding: 091000
589845 - Window Regulator; Front Passenger side
B1320 F5 [008] - Supply Voltage too Low
Mileage: 20 km
Date: 2016.05.19
Time: 23:50:25
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021A00010B000400
VCID: 40A1BD9EDBD59A42E0-8014
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 844 HW: 3Q0 035 844
Component: MU-S-S-US 620 0613
Coding: 027300000000000051220002001808001F0100F40120010002
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6CF9392E87DDAE226C-8038
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H53 1031
Serial number: VWZ8Z9SJW00AKM
1539 - Function Restricted due to Insufficient Voltage
U1400 00 [009] - -
Reset counter: 9
Mileage: 20 km
Date: 2016.05.19
Time: 23:41:13
Voltage terminal 30: 8.4 V
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C2823A017F1E06000000
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000471365
Coding: 0100000000020300000400010100000100
ROD: EV_MFKBoschAU370.rod
