Basic setting
Experimentos
Spain
C?ID=267380
basic setting pressure brake vw mk7
Lateral Acceleration Sensor
Longitudinal Acceleration Sensor
as I can make the adjustment?
Experimentos
Spain
C?ID=267380
Wednesday,17,August,2016,16:02:26:18021
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
VIN: WVWZZZAUZEW067115   License Plate:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52
VIN: WVWZZZAUZEW067115   Mileage: 14008km-8704miles
Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110032032415092000
   Shop #: WSC 16820 002 104857
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021M.rod
   VCID: 2F43E699765B293A09-807A
          U0428 00 [032] - -
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 22:14:12
                    Engine speed: 769.50 /min
                    Normed load value: 38.8 %
                    Coolant temperature: 85 °C
                    Intake air temperature: 71 °C
                    Voltage terminal 30: 13.880 V
17158 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 22:04:57
                    Coolant temperature: 83 °C
                    Intake air temperature: 78 °C
                    Voltage terminal 30: 12.360 V
                    Drivetrain coordinator: ACC fault status-Bit 0: 0
                    Drivetrain coordinator: ACC fault status-Bit 8: 0
                    Drivetrain coordinator: brake fault status-Bit 0: 4
                    Drivetrain coordinator: brake function status-Bit 0: 0
                    Drivetrain coordinator: brake function status-Bit 8: 0
                    Acceleration: 0.000 m/s²
   Revision: 00000000    Serial number: 61843000000017
   Coding: 01FA62A1242609730378060141C82580462490C06082A4F30040F076C002
   VCID: 7BDB02C9F2A3059AF5-802E
10 Faults Found:
0212 - Longitudinal Acceleration Sensor
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 49
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 23:24:54
0270 - Lateral Acceleration Sensor
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 49
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 23:24:54
0295 - Steering angle sensor
          B1168 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 90
                    Mileage: 14004 km
                    Date: 2016.08.17
                    Time: 10:33:46
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 90
                    Mileage: 14004 km
                    Date: 2016.08.17
                    Time: 10:33:47
8277 - Databus
          U1122 00 [009] - Implausible Message
                    Reset counter: 49
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 23:24:54
8299 - Databus
                    Reset counter: 49
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 23:24:54
8342 - Switch for Tire Monitoring System Display
          C10C6 29 [009] - Signal Implausible
                    Reset counter: 49
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 23:25:43
                    Reset counter: 49
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 23:25:03
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 90
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 23:24:54
33000 - Longitudinal Acceleration
          C10B1 29 [137] - Signal Implausible
                    Reset counter: 49
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 23:24:54
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5G0 907 426 R    HW: 5G0 907 426 R
   Component: AC Manuell    110 0907
   Revision: 00001K05
   Coding: 00120004100100001000000000000000
   ROD: EV_ACManueBHBVW37X.rod
   VCID: 3A55C7CDBD19FC92AE-806E
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
   Component: BCM MQBAB M   H14 0112
   Serial number: 00011319900454
   Coding: 00000842C2C102FB4BE44000B1040308100A000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 48B1AD05F3F59E0228-801C
   Component: WWS    130628  042 0551
   Serial number:         130701071150
   Serial number: 20947082
   Coding: 02006C
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY121240TM7
   Serial number: 00000000000055590018
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131225100549
   Coding: 0031161041
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_VW37.rod
   VCID: 3D5FCCD1AC37CBAA8B-8068
8 Faults Found:
13637120 - Databus
                    Reset counter: 89
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 22:05:25
13697024 - Control Module
          U110F 00 [008] - I'm sorry Dave; I'm afraid I can't do that!
                    Reset counter: 89
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 22:42:11
13637409 - Databus
                    Reset counter: 89
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 22:42:11
13637410 - Databus
                    Reset counter: 89
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 22:42:11
13637422 - Databus
                    Reset counter: 89
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 22:42:11
13637423 - Databus
                    Reset counter: 89
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 22:42:11
13637426 - Databus
                    Reset counter: 49
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 22:05:25
13679388 - Databus
                    Reset counter: 89
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 22:42:12
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Serial number: 003F5R06G3H6
   VCID: 40A1B525DBC5A642E0-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 002 407 13
   Serial number: 357670000002F3583D0Y
   Subsystem 2 - Part No SW: -----------    HW: 480 001 707 13
   Serial number: 35867000000F33E05D0$
   Subsystem 3 - Part No SW: -----------    HW: 480 400 107 13
   Serial number: 3516502AD106FA4071AD
   Subsystem 4 - Part No SW: -----------    HW: 480 400 607 13
   Serial number: 3526502B5106FA41013.
   Subsystem 5 - Part No SW: -----------    HW: 480 402 906 13
   Serial number: 35565029F106FA4453CO
   Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
   Revision: --------    Serial number: 04071304400768
   Coding: 0400
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 75CF14F1D48753EA83-8020
   Part No SW: 5G0 920 871 A    HW: 5G0 920 871 A
   Component: KOMBI         304 3390
   Coding: 07AC1A002390000800082800040000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB_VW37.rod
   VCID: 28710D8553B57E02C8-807C
13637376 - Databus
                    Reset counter: 89
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 21:46:04
16776967 - Databus
                    Reset counter: 89
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 21:45:28
16776973 - Databus
                    Reset counter: 89
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 21:45:32
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Fault Frequency: 47
                    Reset counter: 91
                    Mileage: 13990 km
                    Date: 2016.08.16
                    Time: 18:26:06
16777020 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
                    Reset counter: 89
                    Mileage: 14003 km
                    Date: 2016.08.16
                    Time: 23:28:36
   Part No SW: 5Q0 907 530 L    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1144
   Revision: --------    Serial number: 0000768120
   Coding: 030100040B087300EF000048080F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 009013
   ROD: EV_GatewLear.rod
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
H14 0035
   Serial number: 27130000975080023267
   Coding: 28FFFF
   Serial number: 3976280803
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 01051306070138
   Coding: 001F0320D000040000001000
   Shop #: WSC 21587 002 104857
   VCID: 3FA3B6D9A63BD9BA99-806A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000002063445
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 82
19204 - Databus
                    Reset counter: 91
                    Mileage: 14004 km
                    Date: 2016.08.17
                    Time: 11:33:39
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 13.75 V
                    Temperature: 45.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 21
                    uAdSensI_U5VFiltered_xdu16: 5.06842 V
                    uioUdNotFilt_xdu16: 13.86 V
                    uAdSensI_SwitchedKl30_xdu16: 13.86 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 11051303111070
   Coding: 001F0120DE00040000801000
   VCID: 3E5DCBDDA131D0B292-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000002154660
   Coding: 090000
End-------------------------(Elapsed Time: 02:50)--------------------------
Experimentos
Spain
C?ID=267380
already solved!
thanks
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Would you share with us how, please. :thanks:
Experimentos
Spain
C?ID=267380
esp first basic adjustment,
after setting basic brake pressure.
TEXA diagnostic use,
also I imagine VCD you can, the same order
Flatcap
C?ID=284841
I have similar fault codes after changing my rear brakes. Can you run through how you fixed your issues please (i am new to VCDS so please be patient). Thanks.
Address 03: ABS Brakes Labels: 5Q0-907-379-IPB-V1.CLB
Control Module Part Number: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component and/or Version: ESC H42 0623
Software Coding: 31F193A254222A6E017F070641C9698CC92A5480E08296F614 4150F88008
Work Shop Code: WSC 06385 790 00016
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036 (AU37)
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 79FE3FA1F8210889AE-802C
32800 - Supply Voltage for Left Parking Brake Motor
C100D F0 [137] - Short Circuit
Reset counter: 148
Mileage: 17017 km
Date: 2017.04.21
Time: 20:03:19
32801 - Supply Voltage for Right Parking Brake Motor
C100E F0 [137] - Short Circuit
Reset counter: 148
Mileage: 17017 km
Date: 2017.04.21
Time: 20:03:18
32830 - Parking Brake Motors
C10E1 29 [008] - Signal Implausible
Fault Frequency: 7
Reset counter: 188
Mileage: 17017 km
C10E2 54 [137] - Missing Calibration / Basic Setting
Reset counter: 147
Mileage: 17017 km
Date: 2017.04.23
Time: 13:19:20
Dana
Western PA, USA
I realize this thread is old but but we didn't have anything MQB EPB based tested and confirmed for C10E2 until recently. Ref to:
This feedback is from a 2017 RoW (UK) Golf. After cycling the parking brake several times using the button in the dash and a test drive Basic Settings:
[IDE05335-ENG114972] Electro-mechanical parking brake function test
resolved C10E2.
We instructed him to cycle the parking brake ON and OFF first using the button and keeping his foot off the brake while doing the Basic Settings.
Edit, I put a place holder for additional notes in the future here: http://wiki.ross-tech.com/wiki/index.php/C10E2
walterc
Italy
C?ID=94289
Hello. I had to disassemble the rear brake calipers and after having reassembled them I carried out a scan with the vdcs and I get the following errors on block 03 ABS:
Wednesday,26,June,2019,22:55:17:54661
VCDS Version: Release 19.6.0 (x64) Running on Windows 10 x64
Address 03: ABS Brakes Labels: 5N0-614-109-V1.clb
Control Module Part Number: 5N0 614 109 CF HW: 5N0 614 109 CF
Component and/or Version: ESC-EBC460iV1 H10 0013
Software Coding: 22F124A14928E3702077440724C792C704365700508B4885
Work Shop Code: WSC 12345 123 12345
ASAM Dataset: EV_Brake1ESCEPBTRW 006353 (AU21)
ROD: EV_Brake1ESCEPBTRW_006.rod
VCID: 71C6878AA07C9FC76A-8024
0383 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
0360 - Steering angle sensor
0522 - Inertial Sensor Package
C115E 54 [137] - Missing Calibration / Basic Setting
0559 - No Basic Setting
B2010 00 [137] - -
Reset counter: 149
Mileage: 65339 km
Date: 2019.06.26
Time: 22:07:36
Additional_Codes: 00 00 00 0D 7D 1E 00 4A 0A
DTC: 00 02 2F
Additional2: 01 04 01 07 05 00 1C 00 1C 00
can anyone tell me how to recalibrate and eliminate these errors?
Thanks a lot!
