Hi
Need some help. I've searched the entire internet and tried a bunch of different things but nothing seems to work. Little bit of a long story.
I installed a highline reverse camera/backup camera in my MK6 Gti (2014). http://www.carsystems.pl/vw-golf-mk6-rear-emblem-high-line-camera-kit-with-guidance-line,id467.html
I've installed 2 regular ones before so the wiring and panel removing wasnt such a big deal for me. Once everything was connected, it worked! Lines moved with the steering wheel and everything. Then, the next day, I stuck it in reverse and I got this message "rear view camera system is not available at present" on the screen. I've got an RNS510. The camera pops out from under the emblem but nothing happens on the screen.
Wiring:
power from camera to fuse box for a constant 12v
16 pin female connector from camera to RNS
Yellow wire from camera to reverse light +
4 wires from 16pin cable, ground, can +, can -, power
I did all the VCDS settings as it was instructed... installation list, 6c, offroad... everything. I didnt change a single thing from when it was working to when it stopped working.
I tried to install a relay thinking that it might be a power issue with the reverse light or something of the sort.
Relay pins:
pin 30 - 12V from rear cig lighter
pin 85 - Gnd from rear cig lighter
pin 87 - + from camera (tapped)
pin 86 - reverse light (tapped) and yellow signal wire from camera
made no difference. I hard restarted the RNS also.
I had another thought that it might be my CAN Gateway but its not THAT old, 2013. 7N0 907 530 AF (I think the newest is AR)
Here's my scan: (its the open circuit that im dealing with. I know how to do the calibration)
Wiring:
Relay pins:
Saturday,13,August,2016,19:36:20:20005
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWHD7AJ1EW010614 License Plate:
Mileage: 34090km-21182mi Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 52 55 56 62
6C 72 77
VIN: WVWHD7AJ1EW010614 Mileage: 34090km-21182miles
Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AT HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0020
Revision: E3H26--- Serial number:
Coding: 040301081C070160
Shop #: WSC 00642 210 45725
VCID: 78D11B500B9D6EFE46-802C
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 058 P HW: 02E 927 770 AL
Component: GSG DSG AG6 521 3513
Revision: 05652104 Serial number: 00001309030775
VCID: 2773082C96A331061F-8072
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492300FA881106E5921D0041B60C00
VCID: 7DDF0A44E4BF4BD615-8028
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 05311 115 00000
ROD: EV_ClimaBasis_VW36.rod
VCID: 75CF1264D48F13965D-8020
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 T HW: 1K0 937 086 T
Component: BCM PQ35 M 111 0709
Revision: AC111709
Coding: 29180A3FE0652AC4008800C165008BE848FD2186432C0D60E48420040040
VCID: 41A7B6B4D8C7EF3631-8014
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 10091 26 0512
Coding: 009795
Component: RLS 200914 05 54 0403
Coding: 0730AD
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R02LTXB
Coding: 00004737
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 3C59C740B72582DE62-8068
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00008UF000
Serial number: 3572MSME6E4F407EZZZE
Serial number: 3582MSME0228107DZZZR
Serial number: 3512QSME78083512ZZZP
Serial number: 3522QSME56094243ZZZP
Component: F.Sens.Fahr --- ----
Serial number: 35527SME796E7D2FZZZ6
Component: F.Sens.Beif --- ----
Serial number: 35627SME64437D2FZZZV
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90440MIP000ZE
Coding: 1892140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76CD1568C989188E54-8022
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0036
Serial number: 0106245
Coding: 830000
Part No SW: 5K6 920 973 C HW: 5K6 920 973 C
Component: KOMBI H05 0705
Coding: 170D01
VCID: 3753D86C8E03A1868F-8062
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 200913F1000196
Coding: 356002
Shop #: WSC 49176 001 104857
VCID: 74C92F60D7F50A9E6A-8020
Component: IMMO H05 0705
VCID: 6AF531188D31CC6EC0-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7665289674
Coding: 020100
VCID: 2B7BF41C4A4B1566FB-807E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 T HW: 1T0 035 680 R
Component: RNS-MID H30 6276
Revision: AB001001 Serial number: VWZ6Z7N5324078
Coding: 08010400040000820000
VCID: 3FA3B04CAE3399C647-806A
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
Component: Tuer-SG 009 2105
Coding: 0001271
VCID: 3753D86C4603A1868F-8062
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 74 3501
Revision: 00H22000
VCID: 3957DE547017B7F679-806C
Address 4C: Tire Pressure II
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 H HW: 5K0 959 702 H
Coding: 0001270
VCID: 3851DB504B1DAEFE86-806C
Component: AFS-Steuergeraet 0148
Coding: 1446940
VCID: 3449EF6057754A9EAA-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001232
Shop #: WSC 01357 011 1012551
VCID: 354FD2645C0F53969D-8060
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 5N0 907 441 A HW: 5N0 907 441 A
Component: J772__Rearview 0030
Revision: 00H13000 Serial number: 525PA8-J393492
Coding: 0000110
Shop #: WSC 98765 666 38384
VCID: 2D7FFA04B45F1B56E5-8078
03006 - Back-up Camera System not calibrated
Reset counter: 73
02203 - Audio / Video Input 1
Reset counter: 73
Mileage: 34099 km
Date: 2016.08.13
Time: 03:26:20
Reverse ON
Count: 9
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001232
VCID: 364DD5684109588E94-8062
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105243608
Coding: 020100010100010000000100
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_SE36.rod
VCID: 256F022424AF23162D-8070
End-------------------------(Elapsed Time: 02:10)--------------------------
