Good Morning
I have a problem with a Q5, I replace the mechatronic unit,( they beat the crankcase and replace faults asked ), I need procedure of adaptation, also tells me that you also heve to adaptation the inmovilizer, send autoscan , please can you help me.
VCDS Version: Release 15.7.4 Running on Windows 7 x86
Data version: 20160216
Thursday,16,June,2016,10:12:26:49232
Chassis Type: 8R (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 2E 42 46 47 52 53 55 56
62 72 77
VIN: WAUZZZ8R2CA000761 Mileage: 41290km-25656miles
Address 01: Engine (CL0MA-CDNC) Labels: 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 D HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H20 0005
Revision: E1H20---
Coding: 01210010240F0060
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_ECM20TFS8R0907115D A01005
ROD: EV_ECM20TFS0118K2907115AJ.rod
VCID: 3561004F948126969D-8060
2937 - Please Check Fault Codes in Transmission Control Module
U1026 00 [036] - -
Mileage: 41294 km
Date: 2010.01.22
Time: 01:42:17
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8R0 927 156 D HW: 0B5 927 156 E
Component: 0B5 30 TDIRdW H03 0015
Revision: --H03--- Serial number: 0000001189
Coding: 000001
Shop #: WSC 06192 000 00000
ASAM Dataset: EV_TCMDL501 A02203
ROD: EV_TCMDL501.rod
VCID: 3C77156BB7ABF7DE62-8068
7971 - Transmission Control Unit
P1701 00 [167] - Locked
Reset counter: 40
Mileage: 41294 km
Date: 2010.01.22
Time: 00:11:13
8446 - Transmission Control Module
P0614 00 [167] - Incorrect Software Version
Reset counter: 40
Mileage: 41294 km
Date: 2010.01.22
Time: 00:11:14
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 H HW: 8R0 907 379 H
Component: ESP8 quattro H06 0110
Coding: 025548
VCID: 4581708FCC61B6160D-8010
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 72
Mileage: 41294 km
Date: 2010.01.22
Time: 00:25:54
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x000B
Hex Value: 0x2495
Hex Value: 0x00FF
Part No SW: 8K0 907 064 CT HW: 8K0 907 064 CT
Component: BCM2 2.0 H05 0435
Coding: 010500
Shop #: WSC 06335 000 00000
VCID: 0407AD8B87DB4F1E5A-8050
Subsystem 1 - Part No SW: 8T0 959 754 HW: 8T0 959 754
Component: FBSAUDIB8 IDG H60 0072
Component: J764 ELV MLB H37 0042
02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted
Reset counter: 72
Mileage: 41294 km
Date: 2010.01.22
Time: 00:25:53
Part No SW: 8T1 820 043 AM HW: 8T1 820 043 AM
Component: KLIMA 1 ZONE H08 0180
Revision: A0000000 Serial number: 01180420110433
Coding: 64012000
VCID: 7CF7D56BFF2B37DE22-8028
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H30 0392
Revision: 09030001 Serial number: 00000001031339
Coding: 2600D0914074AF010001000000001D0D0F1C470802010101000000
VCID: 3A7B1373B59FC9EE70-806E
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 110328 H11 0050
Coding: 01DD13
Component: RLS H04 0003
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0080
Revision: 11001001 Serial number: 36891110849195
Coding: 000105
VCID: 4A9B43B3E57F596EE0-801E
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H44 0610
Serial number: 003JPD08ZLYT
Coding: 30463331313030303030554A304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 489F79BBF373AB7EF6-801C
Serial number: 6334MSME5F14146EN
Serial number: 6344MSME5F133567J
Serial number: 6352QSME1D094D66T
Serial number: 6362QSME7C1E576E1
Serial number: 63732SME281E3F469
Serial number: 63832SME272E3C6EH
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KDG000IE
Coding: 000033
VCID: 3D71186FA4B1FED655-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 900 M HW: 8R0 920 900 M
Component: KOMBIINSTR. H12 0258
Revision: 00000000 Serial number: EJR418E4C
Coding: 0F06220002000008010000
VCID: 3B751677BAA5F0E66B-806E
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AC HW: 8T0 907 468 J
Component: GW-BEM 6CAN H06 0117
Revision: HB800053 Serial number: 5300H11329816E
Coding: 00C303
VCID: 020BAB939DCF412E68-8056
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0140
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 D HW: 8K0 857 511
Component: FLA H04 0004
Revision: AA001002
Coding: 02012064747464545425363E
VCID: 326B3B536DEF31AEB8-8066
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020202
VCID: 39790C7FB099C2F679-806C
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0000006032231
Coding: 011D02204100440004
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0148601575
Coding: 013A062220B900148530053280000000
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
Component: DSP STD H11 0440
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 2F6D32277EDD1C46D7-807A
02247 - Subwoofer (R148/R157)
Reset counter: 72
Mileage: 41294 km
Date: 2010.01.22
Time: 00:14:42
Voltage: 12.00 V
Temperature: 21.0°C
Bin. Bits: 00000000
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0000006025628
VCID: 49997CBFE0795276E9-801C
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000923234
VCID: 34673D4B97FB3F9EAA-8060
Part No: 8K0 907 357 D
Component: Dynamische LWR H02 0010
Coding: 0000006
VCID: 3663074341872D8E94-8062
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 AC HW: 8T1 035 195 AC
Component: Symphony3 US H07 0351
Revision: 00000010 Serial number: AUZ5Z4K1325904
Coding: 0402008201058500015B070800
VCID: 78FFC97BCB131BFE46-802C
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000115349406
Coding: 010C02204000240004
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000115349415
Part No SW: 8T0 862 335 E HW: 8T0 862 335 E
Component: FSE_256x BT H42 0650
Revision: 00000000 Serial number: 00000005288066
Coding: 0010390
VCID: 3C77156B7FABF7DE62-8068
:banghead::thanks:
End-------------------------(Elapsed Time: 03:23)--------------------------
