07 A4 3.2L P0172 rich code
Captkrunch
Canada
C?ID=170740
Hi there,
first time poster :) Never had to use my VCDS since 2007! Crazy huh?!?!
So I'm getting the infamous P0172 error. Normally it's either, from what I could read, a vaccum leak or something dumb like that.
This is the full scan of the car: could anyone help me figure it out?
Thanks in advance :)
Wednesday,25,May,2016,18:24:47:55111
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUEH78E87A046474   License Plate:
Mileage: 201620km-125280mi   Repair Order:
          67 69 75 76 77
VIN: WAUEH78E87A046474   Mileage: 201620km-125280miles
Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
   Part No SW: 8E1 910 559 F    HW: 8E0 907 559 J
   Component: 3.2l V6 FSI         0080
   Revision: --H19---    Serial number:
   Coding: 01040109190F0120
   Shop #: WSC 93009 999 04862
   VCID: 3169D31DA8FE1DB6C1-8064
004376 - Oxygen (Lambda) Sensor Heating; B1 S2
               P1118 - 009 - Open Circuit - Intermittent
                    Fault Status: 00000100
                    Reset counter: 36
                    Mileage: 201190 km
                    RPM: 768 /min
                    Mass Air / Rev.: 179.9 mg/str
                    Temperature: 69.0°C
                        Idle
                    Voltage: 12.44 V
                    Bin. Bits: 00000001
004407 - Fuel Trim: Bank 1 (Add)
               P1137 - 007 - System too Rich - Intermittent
                    Reset counter: 38
                    Mileage: 201193 km
                    RPM: 768 /min
                    Mass Air / Rev.: 207.1 mg/str
                    Temperature: 93.0°C
                        Idle
                    Time: 256.0 s
                    Bin. Bits: 00000010
004506 - Fuel Pressure Sensor (G247)
               P119A - 007 - Malfunction - Intermittent
                    Fault Status: 00000010
                    Reset counter: 38
                    Mileage: 201210 km
                    RPM: 2752 /min
                    Mass Air / Rev.: 615.9 mg/str
                    Temperature: 90.0°C
                        Part Throttle
                    Pressure: 77.0 bar
                    Speed: 93.0 km/h
008304 - Intake Manifold Tuning Valve (Bank 1)
               P2070 - 006 - Stuck Open - Intermittent
                    Fault Status: 00100001
                    Reset counter: 40
                    Mileage: 201620 km
                    RPM: 864 /min
                    Temperature: 30.0°C
                        Idle
                    Absolute Pres.: 441.6 mbar
004386 - Oxygen (Lambda) Sensor Heating; B2 S2
               P1122 - 009 - Open Circuit
                    Reset counter: 40
                    Mileage: 201620 km
                    RPM: 768 /min
                    Mass Air / Rev.: 130.8 mg/str
                    Temperature: 57.0°C
                        Idle
                    Voltage: 13.16 V
                    Bin. Bits: 00000001
000310 - Oxygen (Lambda) Sensor B1 S2
               P0136 - 007 - Malfunction in Circuit
                    Reset counter: 40
                    Mileage: 201623 km
                    RPM: 768 /min
                    Mass Air / Rev.: 103.6 mg/str
                    Temperature: 93.0°C
                        Idle
                    Load: 14.9 %
   Part No SW: 8E1 910 156 L    HW: 09L 927 156 B
   Component: AG6 09L 3,2 FSI USA 0010
   Revision: --H01---    Serial number:        4207022
   Shop #: WSC 06335 000 00000
   VCID: 306FD619A3F414BECE-8064
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004532
   VCID: 2E53C861B9C0024EDC-807A
            000 -  -  - Intermittent
                    Reset counter: 39
                    Hex Value: 0x0000
                    Hex Value: 0x0202
                    Hex Value: 0x0024
                    Hex Value: 0x0192
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: 6DD10F6D2746B956A5-5124
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 01023
   Shop #: WSC 06335
   VCID: 3D71FF2D37A6E9D655-4B00
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N0023U5T
   Coding: 0033607
   VCID: 3C77F2297FBCE0DE62-8068
   Subsystem 1 - Serial number: 6332DRB4039A46AC.
   Subsystem 2 - Serial number: 6342DRB4039D4F9D7
   Subsystem 3 - Serial number: 6352ARB40162AD0FT
   Subsystem 4 - Serial number: 6362ARB4016018177
   Subsystem 5 - Serial number: 63729RB40173B171E
   Subsystem 6 - Serial number: 63829RB40173B181G
01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
                    Reset counter: 39
01316 - ABS Control Module
                    Reset counter: 39
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 04141
   Shop #: WSC 06335
   VCID: 418983DD4B5E8D3631-4AE8
   Part No SW: 8E0 920 901 E    HW: 8E0 920 901 E
   Component: KOMBI+WFS 4     H14 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0023361
   Shop #: WSC 93204 999 83903
   VCID: 275D3D45953A53061F-5140
   Coding: 0023361
   VCID: 275D3D45953A53061F-5124
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71E9131D3B7E5DB681-4B00
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 CG
   Component: Komfortgerát T7B    4135
   Coding: 11820
   Shop #: WSC 06335
   VCID: 78FF2E3958040CFE46-4B00
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
00962 - Alarm via. Tilt Sensor
            35-00 -  -
01369 - Alarm triggered by Hood Switch
            35-00 -  -
            35-00 -  -
            35-00 -  -
            35-00 -  -
00956 - Key 2
            35-00 -  -
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000019
   VCID: 29593B7D802E657609-807C
   Component: AFS-Modul links H03 0010
   Component: AFS-Modul rechtsH03 0010
Address 56: Radio        Labels: 8J0-035-1xx-56.clb
   Part No SW: 8E0 035 195 AC    HW: 8E0 035 195 AC
   Component: R Symphony2+    H02 0070
   Revision: 00H02000    Serial number: AUZ1Z4F2825142
   Coding: 0610112
   VCID: 68DF7E7958A49C7ED6-5140
No Faults Found
   Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
   Component: FSE_255x BT     H21 0290
   Revision: 00000001    Serial number: 00000000497438
   Coding: 0001677
   VCID: 3D71FF2D67A6E9D655-5140
No Faults Found
End-------------------------(Elapsed Time: 06:10)--------------------------
OBD DTCs erased
OBD DTCs erased
Please check fuses and isolate faulty OXS heater/sensors and all shared tracks.
Is this car tuned?
Some of those fault codes are definitely electrical in nature, not just a vacuum leak.
Captkrunch
Canada
C?ID=170740
hi, i must say i'm a learner in the field :)
I just got p0036 pending as well.
the car is absolutely bone stock!
OXS shared tracks? ill have to look it up because i dont know what is.
OXS = Oxygen sensor and it can be searched in WD very easy.
Captkrunch
Canada
C?ID=170740
it appears both of my o2 sensor post-cat gets a reading of 7.2 ohms (reading with the 200ohms) if that makes sense. Looks to be good!
Captkrunch
Canada
C?ID=170740
Oh my ... I should've read the whole auto-scan before posting! I have like 8 service engine soon codes.
What's the logical steps here? If the o2 sensors are good.
Captkrunch
Canada
C?ID=170740
One more thing that I would like to add. Sometimes, no always, I'll get a rough cold start. The engine will stumble and then it will be ok.
Ahhh you have DTC's for open circuits...........
Don't rely on block values at this time and find the shorted, open or missing link.
Consider changing the OXS sensors if fuses and wiring are good.
Captkrunch
Canada
C?ID=170740
Considering that I have a P0032, which is bank 1 sensor 2 and the fuel mixture too rich, my first play would be to change that OXS. It's 140$ CAD so i'm in luck :)
Thanks once more Jack!
Correct but don't forget this is "ADD trim" which means you could have other underlined conditions such as a stuck N80 etc..
Conduct 071 and 070 tests to win the prize.
0x01-04-071/070
Captkrunch
Canada
C?ID=170740
as I said, i'm a noob :)
I found info about this test in one of your older posts:
This test in VCDS is 0x01-04-071 to pump the tank mechanically with air, using vacuum to operate pulsed by a solenoid.
If air leaks out there is a leak!
That air that pumps in is recycled via the N80 to the intake to burn off the vapors.
I'll have to read up on how to perform this test :)
Thanks once more for helping, really appreciate it. I love learning about this stuff.
Captkrunch
Canada
C?ID=170740
would dirty connection do the trick? i cleaned all my OXS with electro cleaner and no more errors?!?!?!?!?!
It's possible, however, to have these faults on multiple banks I'm not thinking so.
I'd clean the MAF and check air filter........+ check MAF part # to be correct for FOD.
Captkrunch
Canada
C?ID=170740
latest and greatest.
Monday,23,May,2016,19:52:54:55111
                Address 01: Engine  (8E1 910 559 F)
19:52:41 Group 032: Lambda Control (Mixture Adaptation)
  -19.7 %  Adaptation (Idle) Bank 1 Sensor 1
  -2.3 %  Adaptation (Partial) Bank 1 Sensor 1
  -11.4 %  Adaptation (Idle) Bank 2 Sensor 1
  -2.8 %  Adaptation (Partial) Bank 2 Sensor 1
19:52:41 Group 033: Lambda Control
  -0.4 %  Lambda Control Bank 1 Sensor 1
  2.035 V  Sensor Voltage Bank 1 Sensor 1
  2.1 %  Lambda Control Bank 2 Sensor 1
  2.021 V  Sensor Voltage Bank 2 Sensor 1
Thursday,26,May,2016,13:46:37:55111
Mileage: 201680km-125318mi   Repair Order:
          67 69 75 76 77
VIN: WAUEH78E87A046474   Mileage: 201680km-125318miles
                    Reset counter: 38
                    Mileage: 201623 km
                    RPM: 768 /min
                    Mass Air / Rev.: 109.0 mg/str
                    Temperature: 91.5°C
                        Idle
                    Voltage: 13.87 V
                    Bin. Bits: 00000010
                    Reset counter: 39
                    Mileage: 201623 km
                    RPM: 768 /min
                    Mass Air / Rev.: 114.5 mg/str
                    Temperature: 91.5°C
                        Idle
                    Absolute Pres.: 340.5 mbar
000611 - Fuel Injector #1 (N30)
               P0263 - 007 - Contribution/Balance Fault
                    Reset counter: 40
                    Mileage: 201623 km
                    RPM: 768 /min
                    Temperature: 91.5°C
                        Idle
                    Load: 15.7 %
   Coding: 0004532
                    Reset counter: 35
                    Hex Value: 0x0000
                    Hex Value: 0x0202
                    Hex Value: 0x0024
                    Hex Value: 0x0192
                    Hex Value: 0x0001
   Coding: 00000
   Coding: 01023
   Shop #: WSC 06335
   Coding: 0033607
                    Reset counter: 39
                    Reset counter: 39
   Coding: 04141
   Shop #: WSC 06335
   VCID: 418983DD4B5E8D3631-4B00
   Coding: 0023361
   Coding: 0023361
   Coding: 00002
   Coding: 11820
   Shop #: WSC 06335
   VCID: 78FF2E3958040CFE46-4AE8
7 Faults Found:
            35-00 -  -
            35-00 -  -
            35-00 -  -
            35-00 -  -
            35-00 -  -
00955 - Key 1
            35-10 -  -  - Intermittent
00956 - Key 2
   Coding: 0000019
   Coding: 0610112
   Coding: 0001677
End-------------------------(Elapsed Time: 07:17)--------------------------
Suspect Vehicle is FOD!
Please verify controller not tampered.
Check MAF and change the OXS sensors.......
Captkrunch
Canada
C?ID=170740
Unfortunetely, there is no MAF on this car but a manifold absolute pressure device.
Captkrunch
Canada
C?ID=170740
The car is not trowing any more codes!?! Well, at least there is pending codes but no longer logged codes. I went for a very long drive, about 60kms and no lights. I've posted the output in my previous posts.
Captkrunch
Canada
C?ID=170740
wait do you mean my engine is damaged?
Reset counter: 38
Mileage: 201210 km
Shared tracks........
Opps forgot than have a look at these.........That dam D51 caught me in WD for going to G70
G42 - Intake Air Temperature (IAT) Sensor
G71 - Manifold Absolute Pressure (MAP) Sensor
G247 - Fuel Pressure Sensor
