Hex-NET vs HEX+CAN speed test
As this is more-or-less the "flagship" modern Windows product (as opposed to an obscure 4G modem/router) we're somewhat motivated to find out what's going on with it..
DV52
C?ID=194404
The fix.
http://forums.ross-tech.com/showthr...ro-Communication-fix-Alter-the-Power-settings
Took several days, plus i inadvertently found 2 other bugs.
Santos: You have instantly become my second favourite person at Ross Tech - you're an absolute genius !!!
Ran your auto regedit program (normally wouldn't do this- but if I can't trust RT folk, then who can I trust?), made the mod to the WIFI power settings and now HEX-NET AP mode on the Surface Pro "runs like a cut-cat" (local saying)!
Auto scan below as proof (check-out the elapsed time):
 Thursday,12,May,2016,10:53:11:16808
VCDS Version: 16.5.0.4 (x64)  HexNet CB: 0.4316.4
Data version: 20160506 DS251
VIN:             License Plate: NEXNET-SURFACE PRO
Mileage: 22767km   Repair Order: Access Point mode
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN:           Mileage: 22767km-14146miles
Address 01: Engine (J623-CHPA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 G    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H08 7862
   Revision: WAH08---
   Coding: 01250032242405082000
   Shop #: WSC 04363 002 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016G 002011
   ROD: EV_ECM14TFS01104E906016G.rod
   VCID: A600B3F0D9A62573A1-80F2
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 5240
   Revision: 00043014    Serial number: CU501212296246
   Shop #: WSC 00028 028 00025
   ROD: EV_TCMDQ200021.rod
   VCID: F6A0A3B0498615F3D1-80A2
25472 - No Communication with Gear Selector Module
          U0103 00 [072] - -
                    Fault Frequency: 7
                    Mileage: 22310 km
                    Date: 2016.04.17
                    Time: 12:26:17
                    Engine speed: 18.75 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 61 km/h
                    Control Module temperature: 11 °C
                    CURRENT pressure: -10.0 bar
                    Clutch; primary stat: Fahren
                    selected gear: GANG_5
                    Driving position: N
                    Accelerator position: 0.4 %
                    DTC memory status: 7168
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Coding: 01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
   VCID: FDB2BC9C6CB046AB90-80A8
   Part No SW: 5G0 907 044 Q    HW: 5G0 907 044 Q
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00120004200100011005004012101800
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: B52264BC14005EEB18-80E0
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
   Component: BCM MQBAB M   H14 0106
   Serial number: 00011234701612
   Coding: 03001842C24102FB0FA4400000040308100A000000000000000000000000
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: C3C60A644AD4F05BA6-8096
   Component: WWS    121120  042 0551
   Serial number:         121206042218
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y13M01D03H20M05S37S1
   Coding: 00A8DD
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231233000504
   Coding: 0031151011
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   VCID: BA3877803D1EB193F5-80EE
   Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
   Serial number: 003F5R01UHNZ
   Coding: 98CCC000000000005C00000000C800000065
   Shop #: WSC 00028 028 00061
   VCID: C0CC05685BC2EB43BB-8094
   Subsystem 1 - Part No SW: -----------    HW: 480 000 201 13
   Serial number: 357670000007612C7C0W
   Subsystem 2 - Part No SW: -----------    HW: 480 000 201 13
   Serial number: 358670000006332C7C0V
   Subsystem 3 - Part No SW: -----------    HW: 480 400 301 13
   Serial number: 3516502AF0CD5EC471C+
   Subsystem 4 - Part No SW: -----------    HW: 480 400 201 13
   Serial number: 3526502B30CD5EC2136J
   Subsystem 5 - Part No SW: -----------    HW: 480 401 112 12
   Serial number: 3556502B30CD5EC4008M
   Part No SW: 5Q0 953 507 AE    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 08011304220489
   Coding: 0500
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: F9BAA88C78987A8BBC-80AC
   Part No SW: 5G0 920 860     HW: 5G0 920 860
   Component: KOMBI         235 0555
   Coding: 27A501082380800801087E00040000
   VCID: E582F4FCE420EE6B68-80B0
   Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
   Component: GW MQB Mid    121 1109
   Revision: --------    Serial number: 0000188941
   Coding: 030100342B086400EF0006481C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear.rod
   VCID: B3265AA41A7440DB36-80E6
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
   Component: E221__MFL-DC1  H13 0035
   Serial number: 02120005290300060291
   Coding: 280000
   Serial number: 3451678601
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000046453458
   Coding: 003A02208001020000001000
   VCID: 8248CF60154E3953ED-80D6
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000000502227
   Coding: 0D0000
   Coding: 01
   VCID: BD327C9C2C3086ABD0-80E8
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000048027940
   Coding: 003A00208E01020000801000
   VCID: 814AC06C1048224BF4-80D4
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000000502825
   Coding: 050000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846
   Component: MU-S-N-ER     039 0450
   Serial number: V1F00501130081
   Coding: 02730008FF00000011510001000900001F0104960100010047
   Shop #: WSC 12345 123 61029
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: A71EBEF4DEAC3C7B9A-80F2
   Component: ABT_Std_Nav  H44 0022
   Serial number: VWZ8Z9M3400KZM
   Subsystem 2 - Part No SW: 5G0 919 866 A    HW: -----------
   Component:  ROW 2013  --- 0022
End-------------------------(Elapsed Time: 01:15)--------------------------
Thanks muchly
PS: You can take $20 out of the Ross Tech petty cash tin - tell the accountant that I said that it was OK!!:)
   #24
bigjohn84
Edinburgh/Leith
C?ID=276781
Just want to add something, I noticed that Windows defender was running in the background so was making vcds run very slow, even trying to open the program, I have to open search bar then go to Windows defender and turn it off, It works like a dream now, this was the package I bought the hex+can and Windows tablet from yourselfs, maybe when selling the product add a note and tell them to turn this program off.
Yeah, recent updates to Windows Defender / MS Security Essentials really seem to bog down VCDS. I wouldn't recommend turning it off entirely, but telling it to leave VCDS alone is probably appropriate, at least until MS fixes whatever they broke.
bigjohn84
Edinburgh/Leith
C?ID=276781
I've noticed Windows defender takes up 50% of ram so when trying to run VCDS it just Dosnt want to open, give it 3/5min and it opens, turn Windows defender off and VCDS opens in 3secs, Windows defender does turn itself back on but I just keep turning it off again, I only used the tablet for use with cars anyway and it's never connected to the net while working on cars, it's a pain in the but if I say so, if I didn't no the in and out of a computer I prob would have gave the tablet away cause it was so slow, but now it's great.
   #27
I have no idea what tablet you're using. We've never sold tablets, so it's something one of our resellers supplied.
Try this please (screen-shot is from MS Security Essentials, but I think Windows Defender is essentially the same):
Obviously, you still need to click [Add] at that point, and then [Save changes]
bigjohn84
Edinburgh/Leith
C?ID=276781
Yes bought is from one of your partners, I'll try that thanks, should have thought about doing this before hand, saves Windows scanning it everytime I open it, I'll see what it's like later and let you no :thumbs:
DV52
C?ID=194404
^^^^ bigjohn: little solace I know - but this problem doesn't seem to be an issue on my tablet (surface Pro 3 running Windows 10 -64 bit). VCDS opens-up within 3-4 seconds without any exclusion settings in Windows Defender.
   #30
bigjohn84
Edinburgh/Leith
C?ID=276781
Yeh mines is also running that, mines has only 1g of ram tho, it's just abit info incase anyone else was having this issue to maybe try that. All information is helpful on hear as you know
