- Joined
- Apr 26, 2016
- Messages
- 4
- Reaction score
- 0
- Location
- Edmonton, AB, Canada
- VCDS Serial number
- C?ID=196534
Hey guys, I'm having problems logging into my VCDS in section 11. I've been trying "01283" as that's what the program suggests I use via a little popup window, plus it seems like what most everyone else uses but I'm not having any luck. I'm not sure if it's supposed to acknowledge that I've logged in, but when I try to do some coding (section 07) it's not working.
Below is a scan of my 2001 2.0L Canadian Cabrio. From everything I know, it's 100% stock, so it shouldn't have an aftermarket chip or anything.
Do you guys have any idea? Maybe this car uses a different login code?
Thanks,
Chris
Thanks,
Chris
VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
Data version: 20160216
Tuesday,26,April,2016,20:43:19:60533
Chassis Type: XX (1V - VW Golf Cabrio (1997 > 2002))
Scan: 01 02 03 08 15 25 35 56
VIN: XXXXXXXXXXXXXXXXX
Address 01: Engine Labels: 037-906-018-ABA.lbl
Part No: 037 906 018 C
Component: 2.0l R4/2V MOTR HS V02
Coding: 00001
Shop #: WSC 00066
VCID: 152133B76F6DE396BD-4AE8
P0300 - 35-00 -
16688 - Cylinder 4
P0304 - 35-00 - Misfire Detected
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 3A0-907-379.lbl
Part No: 3A0 907 379 D
Component: ABS ITTAE 20 GI V00
Coding: 03704
VCID: 2B55F54FD9E94566FB-4A86
04-10 - Mechanical Malfunction - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605
Component: 0H AIRBAG VW5 0006
Coding: 12360
Shop #: WSC 00066
VCID: 74E72E3344575A9E6A-4B02
Address 25: Immobilizer Labels: 6X0-953-257.lbl
Part No: 6X0 953 257
Component: IMMO 0008
Coding: 00001
VCID: 7DF10B17771D1BD615-4B02
XXXXXXXXXXXXXXXXX VWZ1Z0Y1157010
End-------------------------(Elapsed Time: 01:51)--------------------------
