- May 20, 2014
- 9
- 0
- C?ID=21215
I've had an issue with VCDS 12.12.2 freezing during an autoscan (CAN Auto Detect) on B8 S4's only when there are fault codes in the AWD module. When flashing these with aftermarket ECU software you get ECU communication faults in many modules due to the ECU resetting during the flashing process. We clear them by running an autoscan then doing a clear all. I've noticed twice in the last two weeks it freezing at the AWD module on two different cars and also two different PC's. If I go to the AWD module itself and clear the codes the autoscan will then run fine through the whole car.
