Dear tech Support,
I need help with my tour 2011 that I bought from the US and shipped to Saudi Arabia where I am now. I have three issues with it.
1. the navigation data base is for north America only. I tried the local dealer in Saudi, Bahrain and the UAE but they all refer me bach to a tech center in Saudi.
I tried contacting Germany and again they forward my email back to Saudi tech center which they answered me that they CAN NOT do it and the reason is that I have Siyros Radio. and that they have to do a major retrofit that they don’t grantee it will work.
2. the AM radio tuning last digit will not change so i can only change say 1000 kHz to 1010 1020 but I can’t change to say 1011 or 1021 the last digit is not active.
3. FM radio tuning is also change in ten’s Mhz and not on less which should be.
so I think the coding needs to be changes on those but I could not do it with VCD.
the satellite radio Siyros which is installed in my car. I really don’t care about sense it is not available in Saudi, I am not willing to pay for it. so I don’t really mind if it is stopped.
4. the GCC tourag version the video works in the enffoiment screen mine dose not work from DVD or USB or Blue tooth.
So, please can you help me with these things above. I am attaching a new scan log I have done yesterday. and willing to send more data as requested from the technical team.
Friday,05,February,2016,10:27:52:43435
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 15.7.3.0
Data version: 20151216
VIN: WVGFF9BP7BD004707 License Plate:
Mileage: 72588km-45104mi Repair Order:
Chassis Type: BP (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
6C 6D 72
VIN: WVGFF9BP7BD004707 Mileage: 72588km-45104miles
Address 01: Engine (J623-CGRA) Labels: 03H-907-309-V1.clb
Part No SW: 03H 906 023 B HW: 03H 907 309
Component: 3,6 FSI ULEV2 H15 8643
Revision: M7H15---
Coding: 002A0012432600000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM36FSI01103H906023B 002005
ROD: EV_ECM36FSI01103H906023B.rod
VCID: 2149D7D9306041365E-8074
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 A HW: 0C8 927 750 A
Component: AL1000 AISIN 001 1870
Coding: 001368
Shop #: WSC 31987 001 1048576
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_VW52.rod
VCID: 2A5B30F54D56826E0F-807E
Address 03: ABS Brakes (J104) Labels: 7P0-907-379.clb
Part No SW: 7P0 907 379 H HW: 7P0 907 379 A
Component: MK25A H36 0417
Revision: -------- Serial number: 403310010EC010
Coding: 5B7613C349242557DAFBC89392D9A4407700
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A01000.rod
VCID: 428B7855D5267A2E27-8016
Slave 1:
Part No SW: 4H0 907 064 AK HW: 4H0 907 064 AK
Component: BCM2 2.0 H24 0217
Coding: 09860000000000000000
VCID: 72EBE895AD068AAE77-8026
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG H04 0051
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Address 08: Auto HVAC (J255) Labels: 7P6-907-040.clb
Part No SW: 7P6 907 040 AG HW: 7P6 907 040 AG
Component: Klima 2 Zonen H18 0613
Coding: 4606200A80
VCID: 79F9DFB9F870F9F636-802C
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 L HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0092
Revision: 15012002 Serial number: 00000000781379
Coding: 26001012973C5D010020180300005D0C431C460882010261000000020000
VCID: 316927996880F1B6CE-8064
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110204 31 0020
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag02D H05 0023
Revision: -------- Serial number: 003JX001K4A4
Coding: 000000000000000000000000000000003244
ROD: EV_AirbaVW10BPAVW526.rod
VCID: 408F725DDB2A683E31-8014
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R10A01020NB
Serial number: 3575LRB404T07OTSDPC$
Serial number: 3585LRB4053085G24GO
Serial number: 3515RRB405T0BTBEO0LC
Serial number: 3525RRB405T0BTBEE19Z
Serial number: 3555NRB405T053R0EPP1
Serial number: 3565NRB405T053R07O4G
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 A HW: 7P6 953 507
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815KB300006
Coding: 000015
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Address 17: Instruments (J285) Labels: 7P6-920-xxx-17.clb
Part No SW: 7P6 920 980 M HW: 7P6 920 980 M
Component: Kombi H12 0239
Revision: 10240061 Serial number: 658230111593046
Coding: 8B7732022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 46836445F90E460E0B-8012
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000095743
Coding: 0021032600
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 387F1ABD83FA20FE89-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650507771
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00001002288450
Coding: 0058130000004001000001010101202020202121202020
VCID: 34672E8D9792C49EA5-8060
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: TSG FA H07 0162
Revision: -------- Serial number: 0000112746528
Coding: 011D07205E00453005080000
VCID: 3C7706ADBFC20CDE6D-8068
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0142786669
Coding: 0106123A28B9509480B00620010000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Subsystem 3 - Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H07 0006
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H07 0006
Coding: 191100
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0162
Revision: -------- Serial number: 0000112639980
VCID: 3B7505B1BACC0BE664-806E
Address 53: Parking Brake (J540-) Labels: 7P0-907-801.clb
Part No SW: 7P0 907 801 E HW: 7P0 907 801 E
Component: EPB H51 1100
Revision: 00000000 Serial number: A10C17000AB
Coding: 01040000
ROD: EV_ParkbA7.rod
VCID: 3561138994E8DD9692-8060
Slave 3:
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 010A00010F000400
VCID: 7CF7C6ADF742CCDE2D-8028
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0001
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0001
Coding: 130000
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H51 0133
Revision: AB001007 Serial number: 471BY0B7557244
Coding: 020007020100000000
VCID: 2447DECD2772541E35-8070
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 D HW: 7P6 035 664
Component: H-BN-NA H43 0706
Revision: -------- Serial number: 445B.0B7510869
Coding: 010200050040E1EE41020B0C00000003F00801010000000000
VCID: 39791FB9B0F039F676-806C
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H24 0045
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
Reset counter: 7
Mileage: 72588 km
Date: 2016.02.05
Time: 10:21:55
Text: DUA001,Front,M,0,0,6
03175 - Invalid Data Set
Reset counter: 7
Mileage: 72588 km
Date: 2016.02.05
Time: 10:21:53
Voltage: 11.90 V
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000112890885
Coding: 011C07200000253005080000
VCID: 3A7B00B5B5F632EE7F-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000021647
ROD: EV_RDKBERU25_VW52.rod
VCID: 3F8D71A1A6D417C648-806A
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H04000 Serial number: 525 PA8J0Z1174
Coding: 0100001
VCID: 377D198146E42F8680-8062
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 22010001 Serial number: 023100067
Coding: 0533314002
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000112890725
End-------------------------(Elapsed Time: 04:47)--------------------------
