Which gateway to choose
bonoman68
C?ID=262596
When auto scanning my 16 golf r i get the message unable to find gateway, which gateway should i choose manually I don't see golf mk7 ,other golf? special golf?
Thx
Andy
Sector 7G
HC424490
Got the ignition turned on? That message is not normal.
bonoman68
C?ID=262596
yes ignition is on
Zenerdiode
Newcastle, England
C?ID=24330
Are you able to select an individual module? Such as ECU-01 or even the CAN Gateway-19?
Dana
Western PA, USA
I see you noted a 2012 JSW in addition to the 2016 R. If the R won't communicate at all please try the JSW since that vehicle is also CAN.
bonoman68
C?ID=262596
jetta works i did some coding already trying to get R to work with VCDS uploading ASAM updates; hopefully that will do it
thx
bonoman68
C?ID=262596
BTW what is ASAM ?
bonoman68
C?ID=262596
No luck on R
In self test unable to ping network
once i get to cloud functions i get server error or i get to coding (7) but there are no disruptions for codes like i see in jetta
thx
Santos
What happens when you click [select] [Can Gateway] ? Does it display information?
bonoman68
C?ID=262596
yes in can gateway it displays info in bytes that are used
bonoman68
C?ID=262596
i can access control modules but there is no info decrying what the byte does like its done when i do it in jetta
bonoman68
C?ID=262596
was able to autoscan all systems another asam update uploading keeping my fingers crossed
bonoman68
C?ID=262596
lol i found the definition American Society of Addiction Medicine
bonoman68
C?ID=262596
I updated all ASAMs still no description of bytes to code. Do you have VCDS update coming for newer cars?
We're into our 16th year of updates for newer cars. :)
Please post an Auto-Scan so we can see what you have.
bonoman68
C?ID=262596
Hi Uwe,
All is great you guys are awesome
Thx !!
abishoff
C?ID=248712
im having the same issues after updating using the java client fyi i did just have my whole nav unit replaced due to many faults
using vcds windows client in network mode
VCDS Version: Release 15.7.4 Running on Windows 8.1 x86
Data version: 20160216
Saturday,19,March,2016,01:53:34:49139
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 75 77
VIN: 1VWCV7A37FC009301   Mileage: 71510km-44434miles
05-Acc/Start Auth. -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Sporadic communication error 1000
15-Airbags -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CVCA)       Labels: None
   Part No SW: 04L 906 016 AF    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 8417
   Revision: 8AH20---
   Coding: 011D0012032410089000
   Shop #: WSC 41657 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906016AF 001014
   ROD: EV_ECM20TDI01104L906016AF.rod
   VCID: ED9289163C2E8D5625-80B8
4113 - Camshaft Position Sensor (G40)
          P0341 00 [100] - Implausible Signal
                    Mileage: 71512 km
                    Date: 2016.03.19
                    Time: 00:40:24
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4509
   Revision: 05652104    Serial number: 00001404052843
   Shop #: WSC 09003 957 00200
   VCID: A502B1366C5E7516AD-80F0
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU - Intermittent
                    Reset counter: 39
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -  - Intermittent
                    Reset counter: 39
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Reset counter: 39
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                    Reset counter: 39
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
01196 - Engine-Transmission Data Bus
                    Reset counter: 39
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: C54BC0F549220003A30E03E4921A0042A1100012
   VCID: FEB0BE5A694806CE8C-80AA
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Count: 12
                    Count: 8208
                    Count: 45312
                    Count: 255
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Count: 2
                    Count: 12
                    Count: 8194
                    Count: 45312
                    Count: 255
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Count: 2
                    Count: 12
                    Count: 8226
                    Count: 45312
                    Count: 255
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Count: 2
                    Count: 12
                    Count: 8262
                    Count: 45312
                    Count: 255
02214 - Tire Pressure Warning
                    Reset counter: 228
                    Mileage: 71446 km
                    Date: 2016.03.01
                    Time: 09:42:24
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 50494
                    Count: 255
                    Count: 257
   Revision: 00092000    Serial number: 0332322625
   Coding: 130C0C
   ROD: EV_KESSYPQ35G.rod
   VCID: B73E6B7E0EF2F7860F-80E2
   Part No SW: 561 907 044 AP    HW: 561 907 044 AP
   Component: Climatronic   H03 0707
   Revision: 00001K01
   Coding: 0010019012
   VCID: E582F136E4DEB5166D-80B0
   Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
   Component: BCM PQ35 H+   122 0174
   Revision: BL122001
   Coding: EF200E3B982B08D4098802013600854800F1A01E45A005B064806000BC70
   VCID: F8BCA8424B6C38FEC6-80AC
   Component: RLS 290514 05  54  0403
   Coding: 02300A
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD018ST9
   Coding: 00004D32
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   VCID: F2A89A6A251052AEF8-80A6
   Serial number: 6940000Y1400016MTW0J
   Coding: 303047
   Serial number: 3572MSME6E6B6A44ZZZB
   Serial number: 3582MSME312C6A44ZZZ-
   Serial number: 3516KSME7B12782EZZZ+
   Serial number: 3526KSME050D572DZZZZ
   Serial number: 3556LSME0703372EZZZU
   Serial number: 3566LSME1D6B352EZZZ7
   Part No SW: 1K5 953 521 BR    HW: 5K0 953 569 AH
   Revision: FF010042    Serial number: 20140530200383
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: FEB0BE5A614806CE8C-80AA
   Component: E221__MFL-YVJ  H07 0022
   Coding: E20000
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Component: KOMBI         H04 0813
   Coding: 231C01
   VCID: 9E709EDA8108A6CEEC-80CA
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 28061403000506
   Coding: 461000
   VCID: 804CC0A213BC703EFE-80D4
13 Faults Found:
                    Fault Status: 00110100
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Reset counter: 228
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 228
   Component: IMMO          H04 0813
   Coding: 000007
   VCID: EA98820A0DC09A6E40-80BE
   Revision: 00000000    Serial number: 14000125876005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: B02C5062EB9C20BE4E-80E4
Address 2E: Media Player 3
   Part No SW: 561 959 760 B    HW: 561 959 760 B
   Component: MEM-FS        H04 0182
   Revision: AA000000    Serial number: 00000105342645
   VCID: A208AA2ABD70822EC8-80F6
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
   Part No SW: 3C0 035 684 P    HW: 3C0 035 684 P
   Component: RNS-MID       H27 5382
   Revision: AB001001    Serial number: VWZ6Z7R7224015
   Coding: 04090042010000A6000B
   Shop #: WSC 23052 002 1048576
   VCID: B02C5062E39C20BE4E-80E4
   Component: NAR V8  8112
            000 -  -  - Intermittent
                    Reset counter: 228
                    Mileage: 71464 km
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0525
   Revision: 12110009    Serial number: 0008552180
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 9C7494D29714B4DE02-80C8
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630140613191023
   Coding: 800000
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 215    3501
   Revision: 00H22000
   VCID: B93A6D46F0E6E1F6F9-80EC
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Voltage: 12.50 V
                        DU
                    Temperature: 31.0°C
                    RPM: 1498 /min
                    Reset counter: 228
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:45:11
                    Voltage: 12.50 V
                        DU
                    Temperature: 31.0°C
                    RPM: 1498 /min
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K 6815
   Revision: --------    Serial number: EAA098A0144697
   VCID: A600B63AD9587E0EA4-80F2
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
   Component: EZE_2         H55 1653
   Coding: 01030108
   VCID: EFAE931E3E227F4617-80BA
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0005
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0525
   Revision: 14110009    Serial number: 0008587165
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 9D7299D68C0EBDD6F5-80C8
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631140627144210
   Coding: 800000
                    Reset counter: 228
                    Mileage: 71464 km
Address 75: Telematics (J949)       Labels: None
   Component: OCULowUSA     014 0102
   Serial number: 000003554140523
   Coding: 02140102C2423A007F1606000000
   ROD: EV_OCULow.rod
   VCID: D3E63FEEBA4A3BA613-8086
0041 - Databus
                    Reset counter: 228
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 188
                    Mileage: 71466 km
                    Date: 2016.03.08
                    Time: 17:47:39
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007666170901
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: AE104E1AF1A8364E5C-80FA
End-------------------------(Elapsed Time: 02:31)--------------------------
