- Joined
- Apr 9, 2014
- Messages
- 2,309
- Reaction score
- 2,257
- Location
- Tartu, Estonia
- VCDS Serial number
- C?ID=195131
Hi
Bit confused. I have a request to retrofit cruise to Caddy. While doing autoscan and other needed tasks to identify compatibility I've ran into confusion.
As you can see from autoscan, it has 549(without index) controller, which according to WIKI is lowline and doesn't support anything. But when enabling cruise in LC, it does allow it and will give you error about missing cruise signal.
Does it or does it not then support it?
Wednesday,02,December,2015,18:29:31:36026
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
VIN: WV1ZZZ2KZDX120509 License Plate: CADDY 2013
Mileage: 91890km-57097mi Repair Order:
Chassis Type: 2K (7N0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZDX120509 Mileage: 91890km-57097miles
Address 01: Engine (J623-CAYE) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PA HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 4989
Revision: --H43--- Serial number: 00000000000000
Coding: 00114014030400080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023PA 003007
ROD: EV_ECM16TDI02103L906023DB.rod
VCID: F4A4979C5F37159EFF-80A0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 423C200D092403FA421004E49022C041300000
Shop #: WSC 35110 377 08192
VCID: FCB4BFBC7F675DDEB7-80A8
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 BN HW: 7N0 907 426 BN
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010004002
ROD: EV_ACManueBHBVW36X_SE36.rod
VCID: 814ACE4810853036E4-80D4
9473905 - Motor for Temperature Flap
B108F 71 [008] - Actuator stuck
Reset counter: 111
Mileage: 90745 km
Date: 2015.11.13
Time: 05:41:55
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 R HW: 5K0 937 085 R
Component: BCM PQ35 B+ 021 0068
Revision: BB021001
Coding: 411A583A8025F32908800082900000640301728852028060648000000040
VCID: C2C801445D03EB2EBD-8096
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 13031 26 0512
Coding: 009795
Subsystem 2 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 94
Mileage: 65999 km
Date: 2015.04.13
Time: 13:22:10
Voltage: 14.15 V
Reset counter: 94
Mileage: 65999 km
Date: 2015.04.13
Time: 13:22:10
Voltage: 14.15 V
Fault Status: 00101010
Reset counter: 119
Mileage: 90938 km
Date: 2015.11.17
Time: 18:36:09
Voltage: 9.80 V
Reset counter: 131
Mileage: 65999 km
Date: 2015.04.13
Time: 13:14:34
Voltage: 12.55 V
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag024 H07 0013
Revision: -------- Serial number: 003HL00GUV9+
Coding: 000000000000000000000000000000003234
ROD: EV_AirbaVW10BPAVN750_SE12.rod
VCID: B5226A9814CD4C9608-80E0
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 1K5 953 507 M HW: 5K0 953 549
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90440MCL000FM
Coding: 0080160000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: BB367CA032E99AE6FE-80EE
229163 - Turn Signal Switch
B1144 13 [009] - Open Circuit
Reset counter: 91
Mileage: 91893 km
Date: 2015.12.02
Time: 18:25:41
229179 - Turn Signal Stalk; Switch for Cruise Control
B1144 F3 [009] - Electrical Malfunction
Reset counter: 91
Mileage: 91893 km
Date: 2015.12.02
Time: 18:25:41
Part No SW: 2K0 920 865 J HW: 2K0 920 865 J
Component: KOMBI H06 0705
Coding: 180001
ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 E
Component: Zuheizer 051 2940
Revision: 00051000 Serial number: 09024297000000
Coding: 0000011
Shop #: WSC 35110 377 00170
VCID: B6206D94C1CB478E01-80E2
00664 - Fuel gauge
Reset counter: 123
Mileage: 91462 km
Date: 2015.11.28
Time: 11:38:52
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 230313F2001461
Coding: 357400
VCID: F4A4979C5737159EFF-80A0
Component: IMMO H06 0705
VCID: EA9889E40DF3D36E55-80BE
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 03 0173
Coding: 0000000
VCID: F6A0AD94814B078EC1-80A2
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 140 3305
Revision: 00H22000
VCID: B73E6090C6C1BE861A-80E2
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Coding: 0000000
VCID: F5A2AA989C4D0C96C8-80A0
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 156 A HW: 5K0 035 156 A
Component: Radio 553 0555
Revision: R0553007 Serial number: VWZ5Z1N0824433
Coding: 0000020001
VCID: A502BAD8AC6D3C16B8-80F0
End-------------------------(Elapsed Time: 01:23)--------------------------
Coding: 0080160000
Reset counter: 91
Mileage: 91893 km
Date: 2015.12.02
Time: 18:25:41
Reset counter: 91
Mileage: 91893 km
Date: 2015.12.02
Time: 18:25:41
Wednesday,02,December,2015,18:30:04:36026
Control Module Part Number: 1K5 953 507 M
Component and/or Version: Lenks.Modul 008 0090
Software Coding: 0080160000
Work Shop Code: WSC 35110
Advanced Identification/FAZIT
Identification: KO3-KLO
Revision: --------
Date: 21.03.13
Manufacturer number: 0302
Test stand number: 0562
Flash Status
Programming Attempts(application): 0/0
Successful Attempts(application): 0/0
Programming Attempts(data): 0
Successful Attempts(data): 0
Programming Status: 00000000
Flash Date: 00.00.00
Flash Tool Code(data): 00000 000 00000
Software
UDS: 00.00.01
UDS: 14.03.00
LIN 2.0: 01.02.05
CAN: 00.1E.02
CAN: 00.07.00
Theft prot.: 01.02.15
OSEK-OS: 00.1E.03
Theft prot.: 00.0A.00
Generic Net Mgt: 03.70.03
OSEK-Com: 00.1E.03
Theft prot.: 00.0D.00
Generic Net Mgt: 02.50.00
LIN 2.0: 00.1E.02
Misc.
Hardware number: 5K0 953 549
Workshop System Name: J527
Equipment/PR Code: 0000000000000000
ASAM Dataset Revision: A05001
VCDS Info:
