Audi RS7 Data Collection?
PanEuropean
Toronto, Canada
C?ID=11844
Hello:
My neighbor has a 2014 Audi RS7. This thing appears to be a modernized version of a Karmann Ghia, except that it is wicked fast and horribly expensive.
I remember that many years ago, when the Phaeton and the Bentley Continental vehicles were new, I went around collecting very detailed controller scans of these vehicles and submitting the results to Ross-Tech in order to assist in creating label files for these cars. I can't remember the exact process, but the data collection process was more complex than a normal diagnostic scan - I think there is some kind of check-mark that needs to be placed in a box somewhere in the options dialog in order to collect the highly detailed information from each controller.
Anyway - do you folks need one of these super-detailed scans for a NAR version of an Audi RS7? If so, let me know and I will go collect the data.
Also, this same neighbor (who is the automotive editor of Canada's national newspaper) will have a new Golf R - the 2015 version that is due to appear in North America at the end of this year - for a couple of days around the middle of May. I'm not sure if it will be built to NAR or ROW spec (it will be a VW press car). Do you need an enhanced controller scan of this?
Michael
PanEuropean
Toronto, Canada
C?ID=11844
Attached is the scan from my neighbors 2014 Audi RS7. I am not sure if this is a NAR spec or ROW spec car - it is Audi Canada's press car.
The car has more controllers in it than the Starship Enterprise. I think there must be something wrong with the muffler controller, though - the engine makes a heck of a racket if you press the gas pedal hard. Considering that the car costs $130,000-, I figure Audi ought to at least supply a decent muffler with it.
I ran the scan with the debug level set to 2, and as a result, a number of PLB and other files were generated. Please advise how I should transmit these other files to you - I don't think I can easily attach them here in the forum.
Michael
The Scan
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Friday,09,May,2014,17:21:47:25683
Chassis Type: FC (4G0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 28 36 3B 3C 42 44
          46 47 52 53 55 56 5F 62 65 6C 6D 72 82 84 85 8B 8E 8F 90 BA
VIN: WUAW2CFC4EN900629
Address 01: Engine (------CRDB)       Labels: None
   Part No SW: 4G0 906 560 B    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0003
   Revision: NCH62---
   Coding: 1A2A003265460A0E1000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM40TFS0114G0906560B 001003
   ROD: EV_ECM40TFS0114G0906560B.rod
   VCID: 27579E645E894726FAD-8072
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 4G0 927 158 BE    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIUSA H16 1006
   Revision: --H16---
   ROD: EV_TCMAL551211_AU57.rod
   VCID: 72E1BF30A5CB728E9D3-8027
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379.clb
   Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
   Component: ESP PREMIUM   H09 0100
   Coding: 63B71303C6EDC8C04B00
   ASAM Dataset: EV_ESPPremiAU57X 004036
   ROD: EV_ESPPremiAU57X.rod
   VCID: 3E795B00A113E6EEA9B-806B
Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.CLB
   Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 DR
   Component: BCM2 2.0      H35 0510
   Coding: 0D8A204E000000000000
   Shop #: WSC 06765 128 28888
   VCID: 7CFD9108FF8F34FEC7F-8029
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0088
   Serial number: 02071300041657
   Coding: 680320B85D
   ASAM Dataset: EV_AirCondiComfoUDS 002043
   ROD: EV_AirCondiComfoUDS.rod
   VCID: 62C1CF70752BE20EED3-8037
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.CLB
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001750153
   Coding: 0D072096073E9FE2A90008C7A0003820CF9CD308A2090221800308457B00
   VCID: 6FE7B644BEF95F6672D-803A
   Subsystem 1 - Part No SW: 4G1 955 119     HW: 4G8 955 119
   Component: WWS57X 130628  H36 0080
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
   Component: E1 - LDS  H07 0044
   Component: USHL4.2  H30 0030
   Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H02 0002
   Subsystem 6 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H02 0002
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Subsystem 9 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A32 LED Mod2L  H02 0002
   Subsystem 10 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A28 LED Mod2R  H02 0002
Address 10: Park/Steer Assist (J446)       Labels: None
   Part No SW: 4H0 919 475 AC    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0091
   Revision: 11001001    Serial number: 61031317601980
   Coding: A8E90D
   ROD: EV_EPHVA18AU57X0000.rod
   VCID: 73EFBA34DAD17B86965-8026
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7601010101
   ROD: EV_AdaptCruisContrAU57X.rod
   VCID: 28559D585397485EF37-807D
88064 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
                    Reset counter: 231
                    Mileage: 3090 km
                    Date: 2013.12.12
                    Time: 04:13:27
88320 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
                    Reset counter: 228
                    Mileage: 2750 km
                    Date: 2013.12.03
                    Time: 04:32:56
12032 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [009] - -
                    Reset counter: 108
                    Mileage: 1185 km
                    Date: 2013.10.25
                    Time: 16:56:46
Address 14: Susp. Elect.        Labels: NONE
   Part No SW: 4G0 907 376     HW: 4G0 907 376 A
   Component: J250 DRC FahrwerH01 0040
   Revision: 00000000    Serial number: 00894015034400
   Coding: 0000000
   Shop #: WSC 00485 128 999999
   VCID: EBDF2254CAE12346DE5-80BE
Address 15: Airbags (J234)       Labels: None
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D80037VDZ
   Coding: 30314531313130303036554A304C34473853
   VCID: 336F7A349A513B86565-8066
   Serial number: 3575HRB401850GM0GPII
   Crash sensor for side airbag; passenger side:
   Serial number: 3585HRB400M50HLEGPG1
   Crash sensor for side airbag; rear driver side:
   Serial number: 3515JRB400O50IC4FAA1
   Crash sensor for side airbag; rear passenger side:
   Serial number: 3525JRB400M50KB4LPR$
   Serial number: 3554VRB400E50KB4LI3E
   Crash sensor for front airbag; passenger side:
   Serial number: 3564VRB400K50K2IL1FL
Address 16: Steering wheel (J527)       Labels: NONE
   Revision: --------    Serial number: 90372MG8000IL
   Coding: 0000FC
   VCID: 37774E248629D7A66AD-8062
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   Part No SW: 4G8 920 932 P    HW: 4G8 920 932 P
   Component: TBenRdwAccNv  H80 0621
   Revision: 30460230    Serial number: 658220613596009
   Coding: 0B8F010C8FD30008020500
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K.rod
   VCID: 3C7D5108B70FF4FE87F-8069
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0050
   Revision: --------    Serial number: 00000001010907
   Coding: 00E1034800
   ROD: EV_GatewPkoUDS.rod
   Serial number: 3349260803
Address 22: AWD (J492)       Labels: None
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0200
   Serial number: 001706130001423
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
Address 28: HVAC, Rear (E265)       Labels: 4G0-919-158.clb
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0088
   Serial number: 04071300041718
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
   ROD: EV_ClimaContrUnitRearUDS.rod
   VCID: 37774E248E29D7A66AD-8062
Address 36: Seat Mem. Drvr (J136)       Labels: NONE
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000064498726
   Coding: 00581B0000002001000001010101102030303232203232
   VCID: F7F70E2446A997A62AD-80A2
   Component: SARA 6D red   H02 0056
   Revision: --------    Serial number: EJ1BPA7E00JU6R
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2_AU57.rod
Address 3C: Lane Change        Labels: NONE
   Part No SW: 4G0 907 566 L    HW: 4G0 907 566
   Component: J769  SWA MasterH04 0010
   Revision: 00H04000    Serial number: 6PZ 010 287-10
   Coding: 0000006
   VCID: 38754D184B37D8DE637-806D
   Subsystem 1 - Part No: 4G0 907 568 L
   Component: J770  SWA Slave H04 0010
   Subsystem 2 - Serial number: 6PZ 010 287-30
   Subsystem 3 - Serial number: 5F28.06.1300H04000AMS15128ÿ
   Subsystem 4 - Serial number: S15128ÿ
Address 42: Door Elect, Driver (J386)       Labels: NONE
   Component: TSG FA        H04 0507
   Coding: 011F5F025E00628002000413
   VCID: 458B34ECCCC5B536E81-8010
Address 44: Steering Assist (J500)       Labels: None
   Component: RCEPS         H38 0010
   Revision: 00001000    Serial number: 0003643051
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS.rod
   VCID: 32617F30654B328E5D3-8067
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.CLB
   Revision: 00002001    Serial number: 0311051686
   Coding: 0126023A20FAF08580B00A80020114000000000000000000000000000000
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
Address 47: Sound System (J525)       Labels: NONE
   Part No SW: 4G0 035 465 C    HW: 4G0 035 465 B
   Component: BO G3 C7      H09 0160
   Revision: 11000000    Serial number: 0017233
   VCID: 254B946C2C855536C81-8070
   Subsystem 1 - Part No SW: 4G0 035 466     HW: 4G0 035 466
   Component: BO C7 SLAVE  H51 0100
Address 52: Door Elect, Pass. (J387)       Labels: NONE
   Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
   Component: TSG BF        H04 0507
   Coding: 011F5F025E00628002000402
   VCID: 448D29E8C7FF8C3EFFF-8011
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000747611
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2C5D6148476F647E17F-8079
Address 55: Xenon Range (J431)       Labels: None
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Serial number: 130704-0002-058
   Coding: 1223A6601002A200
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2D5B6C4C7C756D76001-8078
Address 56: Radio (R)       Labels: REDIR FAIL!
   Revision: AB001007    Serial number: 156G.0D7826060
   Coding: 020007010000000001
   VCID: 244D896827BFAC3EDFF-8071
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6XX-5F.CLB
   Part No SW: 4G0 035 664 E    HW: 4G0 035 664 E
   Component: H-BN-NA       H40 0735
   Revision: --------    Serial number: 193G%0D7507770
   Coding: 0B0200040303EDEF7D16CB2E00000003F00001020000000000
   VCID: 28559D585B97485EF37-807D
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: CD-Database  5298
Address 62: Door, Rear Left (J388)       Labels: NONE
   Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
   Coding: 010F1F024000628002000002
   VCID: 47973EE4F6C9A7261AD-8012
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 4H0 907 273     HW: 4H0 907 273
   Component: RDKBERU25     H09 0700
   Serial number: 10000000003189
   ROD: EV_RDKBERU25_AU57.rod
   VCID: E8D55D581317085EB37-80BD
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0096547
   Coding: 0206000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI.rod
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 165301172
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571_AU57.rod
   VCID: 448D29E8CFFF8C3EFFF-8011
Address 72: Door, Rear Right (J389)       Labels: NONE
Address 82: Heads Up Display (J898)       Labels: None
   Part No SW: 4G8 919 604 K    HW: 4G8 919 604 K
   Component: HeadUpDisplay 004 0201
   Coding: D60000
   ASAM Dataset: EV_HUDContiC7 001023
   ROD: EV_HUDContiC7.rod
   VCID: 3B7F5214B201F3C68E5-806E
Address 84: Night Vision (J853)       Labels: 4H0-907-547.clb
   Part No SW: 4H0 907 547 F    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H10 0042
   Serial number: 0K84AE40099217
   Coding: 1411
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H09 0008
   Serial number: 00000000001313400025
Address 85: On Board Cam. (J852)       Labels: None
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2649936059835E2EC1B-8073
Address 8B: Adaptive Cruise 2 (J428)       Labels: None
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7601010101
   ROD: EV_AdaptCruisContr2AU57X.rod
          C1103 00 [009] - -
                    Reset counter: 107
                    Mileage: 1572 km
                    Date: 2013.11.05
                    Time: 22:16:18
Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H31 0041
   Serial number: 005000122806137
   Coding: 03C19A1A0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3163703C604D0996249-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H05 0006
   Revision: 00001001    Serial number: 97804002215804
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X.rod
   VCID: E6C9536019031E2E81B-80B3
The vehicle itself
Very cool, thank you! Is this the same neighbor that used to have a Bentley?
Please ZIP (or RAR) 'em up and send the file to Support@...
Thanks again!
PanEuropean
Toronto, Canada
C?ID=11844
Yep, same person. I was out of town when he brought the Veyron home last year - sorry about that...
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Believe it or not, it might be fake. VW is now using this 'Soundaktor' device (Google it) to augment engine sound. It's apparently some sort of resonator attached to the firewall, not really a speaker. My loaner Turbo Beetle has one. I researched a bit and found that Audi allegedly uses one on the S7, not sure about the RS7 though.
A lovely picture. Would have been even more lovely to grab a scan of that Veyron... there's enough VAG DNA in there that I bet it would talk to us.
Uwe, is that what that "21-Engine III" button is for? I've always wondered. :)
Jason
