Scan of D2 S8 gets stuck on module 77 (telephone)
Adrian E
C?ID=258567
Hi folks
Just acquired a genuine cable and run my first scan with it on my 2002 D2 S8. The firmware and software were updated to the latest versions before running it. For some reason the scan hangs on module 77 for telephone. My car has retrofitted RNS-E, with matching OEM bluetooth and hybrid TV tuner.
My scan result below:
Wednesday,16,September,2015,14:03:30:11450
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WAUZZZ4D62N008086   License Plate: OY52HMO
Mileage: 64989   Repair Order:
Chassis Type: 4D (4D - Audi A8 D2 (1994 > 2003))
Scan: 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77
          02
Address 01: Engine        Labels: 4D0-907-560-AVP.lbl
   Part No: 4D0 907 559 AA
   Component: 4.2L V8/5V      G   0002
   Coding: 10753
   Shop #: WSC 02314
   VCID: 6DDBD37D27BD445686-5140
   WAUZZZ4D62N008086     AUZ7Z0A2018081
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4D0 907 389 E
   Component: ABS/ESP allrad      D57
   Coding: 08397
   Shop #: WSC 02313
   VCID: 31630F0DFB05E0B6E2-5140
Address 08: Auto HVAC        Labels: 4D0-820-043-MYX.lbl
   Part No: 4D0 820 043 Q
   Component: A8-Klimavollautomat D13
   Coding: 00081
   Shop #: WSC 02314
   VCID: 2A511861D6D3936E23-2580
Address 15: Airbags        Labels: 4D0-959-655-AI8.lbl
   Part No: 4D0 959 655 T
   Component: Airbag Front+Kopf  5001
   Coding: 01417
   Shop #: WSC 02335
   VCID: 438F55C551B9622600-5140
Address 17: Instruments        Labels: 4D0-919-033-MYX.lbl
   Part No: 4D0 919 035 BA
   Component: KOMBI+WEGFAHRS.VDO D39
   Coding: 00483
   Shop #: WSC 02313
   VCID: 66C9AC51024B770EC7-515E
Address 35: Centr. Locks        Labels: 8D0-862-257.lbl
   Part No: 8L0 862 257 P
   Component: CV-Pump, Alarm, RC  D17
   Coding: 16203
   Shop #: WSC 02314
   VCID: 428150C14EA36B2E0B-4F06
Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
   Part No SW: 4B0 035 192 P    HW: 4B0 035 192 P
   Component: RNS-E HIGH EU   H76 0650
   Revision:      08S    Serial number: AUZBZ7J6668006
   Coding: 0509714
   Shop #: WSC 00000 781 01234
   VCID: 2A51186186D3936E23-517C
Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
   Part No: 4D0 951 177 B
   Component: Innenraumueberw.    D06
   Coding: 00001
   VCID: 2855E269C8DFA17E35-5140
   Part No: 4Z7 907 357
   Component: dynamische LWR       D07
   Coding: 00001
   VCID: 040D96D91437A51E79-4B1C
Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
   Coding: 0509714
Address 76: Park Assist        Labels: 4D0-919-283.lbl
   Part No: 4D0 919 283
   Component: Parkingsystem A8 RDW D07
   Coding: 01108
   VCID: 68D5A269085F617EF5-5140
Address 77: Telephone        Labels:
   VCID: 55AB9B9DBF2DEC965E-5140
Address 02: Auto Trans        Labels: 01L-927-156.lbl
   Part No: 4D0 927 156 EC
   Component: AG5 01L 4.2l5V  RdW 1010
   Coding: 00101
   Shop #: WSC 02314
   VCID: 6ED9D4712ABBBF4EBF-5140
End-------------------------(Elapsed Time: 05:31)--------------------------
Any reason why it should fail? I've checked a log file from an older scan a friend did for me and previously I've got the following result for module 77, in case that helps:
   Part No SW: 8P0 862 335 AA    HW: 8P0 862 335 S
   Component: FSE_256x BT     H38 0600
   Revision: 00000000    Serial number: 00000005132518
   Coding: 0010722
Can't seem to see any reference to the hybrid TV tuner in there either - it skips over the TV module, but I'm guessing because it's all retrofitted it might be looking in the 'wrong' place for it as it's configured for the older RNS-D based analogue tuner?
Happy days :)
Adrian
Any functional issues with the telephone module? It's possible the module itself has become dodgy.
Did you buy your genuine cable 2nd hand?
Adrian E
C?ID=258567
Hiya
No, bluetooth phone prep is working perfectly :)
Yes, cable is 2nd hand from a Mr Cook here in the UK.
Does it fail consistently? I.e. what happens if you just do [Select] -> [77-Telphone] ?
Adrian E
C?ID=258567
Hiya
It doesn't access it then either - it connects and fills some of the black text description at the top and then hangs. It's locked in the garage now but if there's anything I can try I'm all ears!
Cheers
Adrian
[Options] -> Set Debug Level to 1024
[Apply]
[Select]
[77-Telephone]
Wait for it to "hang". Try to exit gracefully, but if that's not possible, do what you need to exit.
Look in the Debug sub-folder, typically C:\Ross-Tech\VCDS\Debug\ for a file named Debug77.dlm. Send it to Support@... and include a link to this thread.
No promises that this will get us anywhere, but it's worth trying.
Adrian E
C?ID=258567
Thanks Uwe
Will give that a try when I have the car out next
Adrian
Adrian E
C?ID=258567
OK, managed to try this earlier on - left the module sitting there for a lot longer without me attempting to force the issue and eventually it finished the auto scan.
Logged into module 77 directly and again it took quite a while to access it (over a minute) but it seems that having done so once it is now able to access it quicker if I go fully out of it and then back in.
Will try it again the next time I have a chance, but might be that it's resolved itself? No debug file generated :)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
We've seen these issues about 10 years ago when the first came out and were factory installed in the B6 or B7 A4s, at the time some workarounds were added to VCDS, but I honestly don't remember the details. Maybe Uwe and/or Eric do? :)
Adrian E
C?ID=258567
I tried an auto scan again today and it was back to taking ages to first access module 77. Took about a minute, maybe longer, before the module boxes filled with green text and it confirmed no stored faults.
Moving this to Product Support now that Adrian is a Verified User.
I do have a fuzzy recollection of these modules being a total PITA but I don't remember what the exact issue was. Do make us a debug file at some point please.
Adrian E
C?ID=258567
Hiya
I did look in the debug folder and there wasn't anything showing? Is there a process to generate one, or does it need to fall over completely before one is generated?
Cheers
A
I explained the process in Post #6 of this thread. ;)
It does not need to fail in any way to generate the file.
Adrian E
C?ID=258567
The debug folder is empty apart from a 'readme' text file saying to ignore the folder contents. Thought it might have hidden files, but changed that and nothing else shows up....
Then you did something wrong. Perhaps you closed VCDS between setting the debug level and accessing the module? Debug level does not persist once VCDS is closed. Perhaps you have more than one version of VCDS installed and are looking in the wrong tree?
Adrian E
C?ID=258567
I probably did in that case - I assumed once generated a log file would be accessible after disconnecting from the car. I will have another go on Wednesday when I'm using the car next.
Adrian
LN-TAL
Norway
C?ID=13729
The files is saved "forever", but I think Uwe meant that you probably did put in the 1024 debug option, closed VCDS (which reset the debug option) and did the scan ?
Adrian E
C?ID=258567
Not sure what I did, but repeated it now and derived a debug file :) it's quite a bit bigger than the 2-3kb ones that work fine lol
E-mail sent to support
Thanks all
A
Eric
HC800000
Yeah, that debug file isn't pretty at all. Looks like some sort of race condition triggered by the module being really stupidly slow. I'll see if I can think of something to fix this without breaking everything else :)
Eric
HC800000
This took me way longer than it should have but I think I understand what's happening and have a fix for it. Is the hotmail.com address we have on file for you good to send you a link to a test build?
