- Apr 23, 2014
- 3
- 0
- C?ID=213947
I am trying to get my LED lights on my HID conversion work as DLRs.
I have a 2010 JSW, any help would be appreciated.
Here is my scan...
Here is my scan...
VCDS Version: Release 12.12.2
Data version: 20140212
Tuesday,22,April,2014,21:04:43:35374
Chassis Type: AJ (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
VIN: 3VWPL7AJXAM661245
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CL HW: 03L 906 022 TS
Component: R4 2,0L EDC G000SG 7966
Revision: 12H03--- Serial number:
Coding: 0050072
Shop #: WSC 01404 444 83851
VCID: 77D3034006476AA6AAD-8022
001151 - Exhaust Pressure Control Valve
P047F - 000 - Stuck Open - Intermittent
Mileage: 89777 km
Date: 2046.14.15
Time: 16:44:16
RPM: 989 /min
Speed: 20.0 km/h
Load: 0.0 %
Load: 100.0 %
Lambda: 100.2 %
Temperature: 48.0°C
Temperature: 27.0°C
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C492800FB880D06E8921E0042300000
Shop #: WSC 00066 000 00000
VCID: 78D1007CCB5965DEA37-802D
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00197
ROD: EV_ClimaBasis_SE36.rod
VCID: 75CF0948D44B18B6B81-8020
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 34
Mileage: 89799 km
Date: 2046.14.20
Time: 15:06:55
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: BCM PQ35 B++ 111 0128
Revision: BI111001
Coding: 2D380E1A902F3EC480080081400000C401000086535D8560648020000000
VCID: 3753C34086C7AAA66AD-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 15021 21 0512
Coding: 009795
12 Faults Found:
Fault Status: 00101010
Reset counter: 34
Mileage: 89799 km
Date: 2046.14.20
Time: 14:21:08
Term 15 On
Voltage: 11.75 V
Reset counter: 34
Mileage: 89799 km
Date: 2046.14.20
Time: 16:17:17
Term 15 On
Voltage: 11.80 V
Reset counter: 34
Mileage: 89799 km
Date: 2046.14.20
Time: 14:21:08
Term 15 On
Voltage: 11.70 V
Reset counter: 34
Mileage: 89799 km
Date: 2046.14.20
Time: 14:21:08
Term 15 On
Voltage: 11.70 V
Reset counter: 34
Mileage: 89799 km
Date: 2046.14.20
Time: 16:17:16
Term 15 On
Voltage: 11.65 V
Reset counter: 34
Mileage: 89799 km
Date: 2046.14.20
Time: 16:17:16
Term 15 On
Voltage: 11.65 V
Fault Status: 00100001
Reset counter: 34
Mileage: 89799 km
Date: 2046.14.20
Time: 15:06:50
Term 15 On
Voltage: 11.85 V
Fault Status: 00100111
Reset counter: 34
Mileage: 89799 km
Date: 2046.14.20
Time: 14:50:39
Term 15 Off
Voltage: 12.30 V
Fault Frequency: 13
Reset counter: 41
Mileage: 89799 km
Date: 2046.14.20
Time: 16:41:18
Term 15 On
Voltage: 14.10 V
Fault Frequency: 16
Reset counter: 41
Mileage: 89799 km
Date: 2046.14.20
Time: 16:17:24
Term 15 On
Voltage: 11.75 V
Fault Status: 01101010
Reset counter: 249
Mileage: 89799 km
Date: 2046.14.20
Time: 14:21:07
Term 15 On
Voltage: 11.65 V
Reset counter: 249
Mileage: 89799 km
Date: 2046.14.20
Time: 16:17:16
Term 15 On
Voltage: 11.80 V
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0ACS84
Coding: 00003044
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3957C578B8D3BCD69C9-806C
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--000530M700
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME5F44334EZZZ2
Crash sensor for side airbag; passenger side:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME4E46314EZZZ1
Crash sensor for side airbag; rear driver side:
Serial number: 3511HSME7703151FZZZK
Crash sensor for side airbag; rear passenger side:
Serial number: 3521HSME2402151FZZZC
Serial number: 35527SME211F1120ZZZ%
Crash sensor for front airbag; passenger side:
Serial number: 35627SME0C467F1FZZZ.
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
VCID: 78D1007C0B5965DEA37-802D
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Coding: 00000130
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 171209F1002716
Coding: E9807F07001602002002
VCID: 69F7553840F3CC562C9-803C
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T6X9E04
VCID: FEDD9664A97DDBEE69B-80AB
Component: IMMO H03 0305
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EAF5AA340DF5474EA53-80BF
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000371623
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 277313005E673A26FAD-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004609071
Coding: 000490
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 3147FD58A8A37496249-8064
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000341681
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 2871103C5379355EF37-807D
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004588934
Coding: 000490
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7K3058511
Coding: 0500040004
VCID: 61E74D1878C38416F49-8034
Reset counter: 244
Mileage: 73513 km
Date: 2040.14.20
Time: 18:05:19
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
02904 - Hard Warning 3
Mileage: 40627 km
Date: 2024.14.16
Time: 17:06:37
Text: 3445299725
Pressure: 1.60 bar
Pressure: 2.40 bar
Temperature: 19.2°C
Text: E0
Speed: 6.0 km/h
02801 - Hard Warning
Mileage: 72788 km
Date: 2040.14.19
Time: 08:57:41
Text: 3445299737
Pressure: 1.90 bar
Pressure: 2.40 bar
Temperature: 10.0°C
Text: 00
Speed: 63.0 km/h
02903 - Hard Warning 2
Mileage: 78982 km
Date: 2041.14.28
Time: 16:16:20
Text: 3454362541
Pressure: 2.20 bar
Pressure: 2.40 bar
Temperature: 22.0°C
Text: A0
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000329359718
Coding: 412100
Shop #: WSC 01404 444 53924
VCID: 2A75EA344575074EE53-807F
