Long Code for 2010 JSW
Hobs
C?ID=213947
I am trying to get my LED lights on my HID conversion work as DLRs.
I have a 2010 JSW, any help would be appreciated.
Here is my scan...
VCDS Version: Release 12.12.2
Data version: 20140212
Tuesday,22,April,2014,21:04:43:35374
Chassis Type: AJ (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
VIN: 3VWPL7AJXAM661245
   Part No SW: 03L 906 019 CL    HW: 03L 906 022 TS
   Component: R4 2,0L EDC G000SG  7966
   Revision: 12H03---    Serial number:
   Coding: 0050072
   Shop #: WSC 01404 444 83851
   VCID: 77D3034006476AA6AAD-8022
001151 - Exhaust Pressure Control Valve
               P047F - 000 - Stuck Open - Intermittent
                    Mileage: 89777 km
                    Date: 2046.14.15
                    Time: 16:44:16
                    RPM: 989 /min
                    Speed: 20.0 km/h
                    Load: 100.0 %
                    Lambda: 100.2 %
                    Temperature: 48.0°C
                    Temperature: 27.0°C
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 114B600C492800FB880D06E8921E0042300000
   Shop #: WSC 00066 000 00000
   VCID: 78D1007CCB5965DEA37-802D
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00197
   ROD: EV_ClimaBasis_SE36.rod
   VCID: 75CF0948D44B18B6B81-8020
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 34
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 15:06:55
   Part No SW: 5K0 937 085 G    HW: 5K0 937 085 G
   Component: BCM PQ35 B++  111 0128
   Revision: BI111001
   Coding: 2D380E1A902F3EC480080081400000C401000086535D8560648020000000
   VCID: 3753C34086C7AAA66AD-8062
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 15021  21  0512
   Coding: 009795
12 Faults Found:
                    Fault Status: 00101010
                    Reset counter: 34
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 14:21:08
                    Voltage: 11.75 V
                    Reset counter: 34
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 16:17:17
                    Voltage: 11.80 V
                    Reset counter: 34
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 14:21:08
                    Voltage: 11.70 V
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 34
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 14:21:08
                    Voltage: 11.70 V
                    Reset counter: 34
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 16:17:16
                    Voltage: 11.65 V
                    Reset counter: 34
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 16:17:16
                    Voltage: 11.65 V
                    Fault Status: 00100001
                    Reset counter: 34
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 15:06:50
                    Voltage: 11.85 V
                    Fault Status: 00100111
                    Reset counter: 34
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 14:50:39
                        Term 15 Off
                    Voltage: 12.30 V
                    Fault Frequency: 13
                    Reset counter: 41
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 16:41:18
                    Voltage: 14.10 V
                    Fault Frequency: 16
                    Reset counter: 41
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 16:17:24
                    Voltage: 11.75 V
                    Fault Status: 01101010
                    Reset counter: 249
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 14:21:07
                    Voltage: 11.65 V
                    Reset counter: 249
                    Mileage: 89799 km
                    Date: 2046.14.20
                    Time: 16:17:16
                    Voltage: 11.80 V
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   021 0706
   Serial number: 003C4D0ACS84
   Coding: 00003044
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3957C578B8D3BCD69C9-806C
   Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
   Component: BF-Gewichtss.  007 0001
   Serial number: ---0000R--000530M700
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME5F44334EZZZ2
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME4E46314EZZZ1
   Serial number: 3511HSME7703151FZZZK
   Serial number: 3521HSME2402151FZZZC
   Serial number: 35527SME211F1120ZZZ%
   Crash sensor for front airbag; passenger side:
   Serial number: 35627SME0C467F1FZZZ.
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Coding: 0000532
   VCID: 78D1007C0B5965DEA37-802D
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 171209F1002716
   Coding: E9807F07001602002002
   VCID: 69F7553840F3CC562C9-803C
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223T6X9E04
   Coding: 0000002
   VCID: FEDD9664A97DDBEE69B-80AB
   Component: IMMO          H03 0305
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EAF5AA340DF5474EA53-80BF
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0000371623
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 277313005E673A26FAD-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000004609071
   Coding: 000490
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 3147FD58A8A37496249-8064
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0307
   Revision: 15101005    Serial number: 0000341681
   Coding: 0004B4
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 2871103C5379355EF37-807D
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000004588934
   Coding: 000490
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7K3058511
   Coding: 0500040004
   VCID: 61E74D1878C38416F49-8034
                    Reset counter: 244
                    Mileage: 73513 km
                    Date: 2040.14.20
                    Time: 18:05:19
Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
   Component: RDK           111 0821
   Coding: 018705
02904 - Hard Warning 3
                    Mileage: 40627 km
                    Date: 2024.14.16
                    Time: 17:06:37
                    Text: 3445299725
                    Pressure: 1.60 bar
                    Pressure: 2.40 bar
                    Temperature: 19.2°C
                    Text: E0
                    Speed: 6.0 km/h
02801 - Hard Warning
                    Mileage: 72788 km
                    Date: 2040.14.19
                    Time: 08:57:41
                    Text: 3445299737
                    Pressure: 1.90 bar
                    Pressure: 2.40 bar
                    Temperature: 10.0°C
                    Text: 00
                    Speed: 63.0 km/h
02903 - Hard Warning 2
                    Mileage: 78982 km
                    Date: 2041.14.28
                    Time: 16:16:20
                    Text: 3454362541
                    Pressure: 2.20 bar
                    Pressure: 2.40 bar
                    Temperature: 22.0°C
                    Text: A0
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000329359718
   Coding: 412100
   Shop #: WSC 01404 444 53924
   VCID: 2A75EA344575074EE53-807F
Hobs
C?ID=213947
