roadrunner_oz
Australia
C?ID=237916
Audi S3 - Transmission fault
Anyone know what this '10763 - Starter Enable from Selector Lever Sensor System' fault is? If I clear it is returns immediately the car is started.
VCDS Version: 15.6.1.0 (x64)
Data version: 20150612
VIN: WAUZZZ8V7F1066210   License Plate:
Mileage: 2776km-1724mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F 6C
          A9
VIN: WAUZZZ8V7F1066210   Mileage: 2776km-1724miles
Address 01: Engine (J623-CJXF)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0A1D00322426010B3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259A 001004
   ROD: EV_ECM20TFS0208V0906259A.rod
   VCID: 3E5DCC60A1C53CCFCB-806A
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4517
   Revision: 05853104    Serial number: TFK01408301182
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 1F6311E4060F55C7E0-804A
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
   Component: ESC           H31 0471
   Revision: 00000000    Serial number: 62634000003039
   Coding: 31F193A254262A720179030141C3698CC92A5480C08296F6024150B88608
   ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
   VCID: 45AFA38CC4136F178A-8010
   Revision: 00021000    Serial number: 0347138261
   Coding: 030C0C
   VCID: 3A55C070BDED10EFF7-806E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000442259
   Coding: 03100014110000011000000000001500
   VCID: 334BED549A87E1A734-8066
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011425503786
   Coding: 07151C46C24106FD03804004B10807A80800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 002172989BB18A3FF9-8054
   Slave 1:
   Subsystem 1 - Part No SW: 8V2 955 119 C    HW: 8V2 955 119 A
   Component: WWS371 140906  041 0585
   Serial number:         140922103007
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Serial number: 23188426
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
   Serial number: 16 07 2014  00000964
   Serial number: 000000000ZY14211163U
   Serial number: 00000000000030601259
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO3286189B
   Coding: 901E00
   Part No SW: 5Q0 919 298 G    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0051
   Revision: --------    Serial number: 39411424702132
   Coding: 0130160051
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_AU37.rod
   VCID: 43ABBD94CA275127A4-8016
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 C    HW: 8V0 907 376 C
   Component: DAEMPFUNGS-SG H08 0066
   Serial number:       100414013
   ROD: EV_AudiMagneRide_AU37.rod
   VCID: 41A7B79CD03B4337B6-8014
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    014 0385
   Serial number: 003MMR024MU3
   Coding: 98CCC000000000005C54000000C800000065
   Subsystem 1 - Part No SW: -----------    HW: 480 002 209 14
   Serial number: 35767000000FD4E0211Z
   Subsystem 2 - Part No SW: -----------    HW: 480 002 209 14
   Serial number: 35867000000D77B0211S
   Subsystem 3 - Part No SW: -----------    HW: 480 401 209 14
   Serial number: 3516502B7176A6C5B1BO
   Subsystem 4 - Part No SW: -----------    HW: 480 401 209 14
   Serial number: 3526502B7176A6C411FI
   Subsystem 5 - Part No SW: -----------    HW: 480 400 808 14
   Serial number: 35565029D16FC222914G
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 25091404401008
   Coding: A018
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 0A3550B0AD8DC06FA7-805E
   Part No SW: 8V0 920 871 D    HW: 8V0 920 871 D
   Coding: 23AD181A3B9000080101EA001000000000000000
   VCID: 3D5FCB6CACC327D7D2-8068
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 19091410801337
   Coding: 030100042F085A005B0002689C0B00000001010000000000000000000000
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti.rod
   VCID: 42A5B890D53D582FAF-8016
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 04 09 2014  D0009098
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 0654124403
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Serial number: HA1-00011.08.14
   Coding: 0001
   VCID: 46ADA480F915640F83-8012
   Revision: 00000000    Serial number: 14000254147001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3449EE489F89E69F2D-8060
   Serial number: 30081406070208
   Coding: 005D1E204101040000001002
   VCID: 40A1B298DB314A3FB9-8014
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8303
   ROD: EV_SteerAssisMQB.rod
   VCID: 354FD34C94F3FF971A-8060
   Serial number: 14091402090331
   Coding: 005D16204D01040000001002
   VCID: 3FA3B164A6CF35C7C0-806A
   Component: AFS-ECU       H01 0091
   Coding: 01A600002B200200
   ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
   Subsystem 1 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J
   Coding: E00100
   Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G
   Component: LED LeiMo re.  H07 7540
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo rechts  H01 7040
   Coding: E00100
   Part No SW: 8V0 035 045 C    HW: 8V0 035 045 C
   Component: MU-H-N-RW     H43 0357
   Serial number: A307I0EB004045
   Coding: 017301080000000021510002000A00002F000226010001005E
   ROD: EV_MUHig6C3HBAS_AU37.rod
   VCID: 3245E850659DE8AF3F-8066
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 800 TE    HW: -----------
   Component: ROW 2015/2016  --- 0049
   Seat Adjustment Driver Side:
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY201MP2
   Sound System:
   Serial number: C1000001081400040288
   Door Electronics Rear Left:
   Component: Gracenote  --- 4006
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Coding: 027300010201000300
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 3041E2586B91DABF49-8064
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 140904201221
   VCID: 7DDF0B6CEC43E7D792-8028
End-------------------------(Elapsed Time: 03:54)--------------------------
Jef
HQ
Ugh.. UDS modules :banghead::banghead::banghead::banghead:
First thing I'd want to look at is that data from the Gear Selector is matching up to what gear you have selected. In Advance Measuring Values, look for something like "Selector lever position - Shift Position" and this should show data based on the Gear Selector. Does the data match up?
roadrunner_oz
Australia
C?ID=237916
Yes, if I log I can see the position values changes from P, R, N, D.
Seems that if the vehicle engine is turned on the fault code appears once the gear selector is moved, but they then they auto clear when the ignition is turned off and I rescan for faults. See below 3 faults, then clears after ignition cycled.
Monday,02,February,2015,19:57:13:45705
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
UDS Adaptation Channel: (1)-Acknowledgement signals-Akustische Rueckmeldung entriegeln
Stored value not active
Friday,24,July,2015,13:03:58:45705
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
                Address 02: Auto Trans       Labels: 0D9-927-770.clb
Control Module Part Number: 0D9 300 012 L    HW: 02E 927 770 AQ
  Component and/or Version: DQ250-6A MQB  H53 4517
           Software Coding: 0014
            Work Shop Code: WSC 04742 780 00200
              ASAM Dataset: EV_TCMDQ250021 001001 (AU37)
                       ROD: EV_TCMDQ250021.rod
                      VCID: 1F6311E4060F55D9775-804A
          P1734 00 [002] - -
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21159 - Gear R
Friday,24,July,2015,13:11:54:45705
Is there an actual performance/problem issue you are exhibiting or just is this data that is being displayed in VCDS while making observations?
roadrunner_oz
Australia
C?ID=237916
No problem or dash warning. The car self clears the faults when the ignition is off for a minute or so, and only re-appears when started.
I think you maybe picking up the shadow in UDS on network.
VCDS seems to dig deeper I have seen in UDS controllers, that the VAS scanner seems to ignore.
I see that the 0x19 Gateway is reporting everything OK in the installation list, so I would ignore this behavior.
If there was an imperative issue you would see faults elsewhere I believe in other controllers.
roadrunner_oz
Australia
C?ID=237916
Thanks for you help
