Audi S3 - Transmission fault
Anyone know what this '10763 - Starter Enable from Selector Lever Sensor System' fault is? If I clear it is returns immediately the car is started.
VCDS Version: 15.6.1.0 (x64)
Data version: 20150612
VIN: WAUZZZ8V7F1066210 License Plate:
Mileage: 2776km-1724mi Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F 6C
A9
VIN: WAUZZZ8V7F1066210 Mileage: 2776km-1724miles
Address 01: Engine (J623-CJXF) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00322426010B3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259A 001004
ROD: EV_ECM20TFS0208V0906259A.rod
VCID: 3E5DCC60A1C53CCFCB-806A
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4517
Revision: 05853104 Serial number: TFK01408301182
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021_AU37.rod
VCID: 1F6311E4060F55C7E0-804A
[COLOR="#FF0000"]1 Fault Found:
P1734 00 [002] - -
[/COLOR]
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62634000003039
Coding: 31F193A254262A720179030141C3698CC92A5480C08296F6024150B88608
VCID: 45AFA38CC4136F178A-8010
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0347138261
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A55C070BDED10EFF7-806E
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0052
Revision: 20026000 Serial number: 00000000442259
Coding: 03100014110000011000000000001500
VCID: 334BED549A87E1A734-8066
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011425503786
Coding: 07151C46C24106FD03804004B10807A80800000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 002172989BB18A3FF9-8054
Slave 1:
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A
Component: WWS371 140906 041 0585
Serial number: 140922103007
Coding: 0A47F7
Slave 2:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Serial number: 23188426
Coding: 00006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 G HW: 8V0 941 531 G
Serial number: 16 07 2014 00000964
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY14211163U
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000030601259
Subsystem 6 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.014 H02 0007
Serial number: WOO3286189B
Coding: 901E00
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 G HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0051
Revision: -------- Serial number: 39411424702132
Coding: 0130160051
ASAM Dataset: EV_EPHVA2CAU3700000 003019
ROD: EV_EPHVA2CAU3700000_AU37.rod
VCID: 43ABBD94CA275127A4-8016
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 C HW: 8V0 907 376 C
Component: DAEMPFUNGS-SG H08 0066
Serial number: 100414013
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide_AU37.rod
VCID: 41A7B79CD03B4337B6-8014
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 014 0385
Serial number: 003MMR024MU3
Coding: 98CCC000000000005C54000000C800000065
Subsystem 1 - Part No SW: ----------- HW: 480 002 209 14
Serial number: 35767000000FD4E0211Z
Subsystem 2 - Part No SW: ----------- HW: 480 002 209 14
Serial number: 35867000000D77B0211S
Subsystem 3 - Part No SW: ----------- HW: 480 401 209 14
Serial number: 3516502B7176A6C5B1BO
Subsystem 4 - Part No SW: ----------- HW: 480 401 209 14
Serial number: 3526502B7176A6C411FI
Subsystem 5 - Part No SW: ----------- HW: 480 400 808 14
Serial number: 35565029D16FC222914G
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 CP HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 25091404401008
Coding: A018
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 0A3550B0AD8DC06FA7-805E
Part No SW: 8V0 920 871 D HW: 8V0 920 871 D
Component: KOMBI H02 4291
Coding: 23AD181A3B9000080101EA001000000000000000
VCID: 3D5FCB6CACC327D7D2-8068
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 M
Component: GW MQB High 212 2186
Revision: -------- Serial number: 19091410801337
Coding: 030100042F085A005B0002689C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti.rod
VCID: 42A5B890D53D582FAF-8016
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 04 09 2014 D0009098
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 0654124403
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Component: Haldex4Motion H52 7076
Serial number: HA1-00011.08.14
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
VCID: 46ADA480F915640F83-8012
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000254147001
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3449EE489F89E69F2D-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 30081406070208
Coding: 005D1E204101040000001002
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 40A1B298DB314A3FB9-8014
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8303
ROD: EV_SteerAssisMQB.rod
VCID: 354FD34C94F3FF971A-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 14091402090331
Coding: 005D16204D01040000001002
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3FA3B164A6CF35C7C0-806A
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 01A600002B200200
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 G HW: 7PP 941 472 G
Component: LED LeiMo re. H07 7540
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo rechts H01 7040
Coding: E00100
Part No SW: 8V0 035 045 C HW: 8V0 035 045 C
Component: MU-H-N-RW H43 0357
Serial number: A307I0EB004045
Coding: 017301080000000021510002000A00002F000226010001005E
ROD: EV_MUHig6C3HBAS_AU37.rod
VCID: 3245E850659DE8AF3F-8066
Engine Control Module 2:
Subsystem 1 - Part No SW: V03 959 800 TE HW: -----------
Component: ROW 2015/2016 --- 0049
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0013
Serial number: AUZ8Z9EY201MP2
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000001081400040288
Door Electronics Rear Left:
Component: Gracenote --- 4006
Address 6C: Back-up Cam. (J772) Labels: 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ROD: EV_CamSysRearPANAAU914.rod
VCID: 3041E2586B91DABF49-8064
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 140904201221
VCID: 7DDF0B6CEC43E7D792-8028
End-------------------------(Elapsed Time: 03:54)--------------------------
