Problem with Transporter T5 7E (2011 model)
VWCentral
Australia
C?ID=109844
Hi All, - (Take two after sorting out the legalities)
Huston we have a problem!!!
I have a T5 7E (2011-2012 model).
It came stock with white DIS (including trip computer operated from the right stalk), RCD210 head unit and rubber steering wheel.
I have since retrofitted RCD 510 and 9w7 kit and coded successfully.
I have bought and installed;
3c8419091BF E74 MFSW (with DSG paddles)
3c8971584 A Airbag loom
6Q0953513BA Stalk switch (inc cruise) (I reused my ring 6Q0959654D)
I have also modified the clockspring connector by adding;
1. pin 9 which runs to light switch position 15 (ignition live)
2. pin 10 which splices into pin 17 of the 73 pin plug to the BCM
I have tried coding in the MFSW using VCDS and all the coding gets accepted, however nothing works.
Could you run some magic coding please to get full functionality, I would love to get;
The buttons and DSG paddels on the MFSW to work and to control the RCD510,Telephone,Voice recognition and Cruise control on the left and the current white DIS trip computer from the right switch.
I have read some threads and it seems you were able to do just this (without the right side buttons working) for SnowMotion in 2013 (http://www.vwwatercooled.com.au/foru...n-60513-4.html)
Your help is very appreciated, thank you.
I'm adding the scan of the car below. Please note the scan was clean until we attempted to fit a Polo R6 Stalk switch/clockspring setup, to see if that would work. Now its not letting us clear the Steering sensor fault code (since there is no 44 Steering Assist in this car).
Saturday,11,July,2015,22:47:01:38359
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 15.6.1.0
Data version: 20150612
VIN: WV2ZZZ7HZCH049920   License Plate:
Mileage: 86450km-53717mi   Repair Order:
Chassis Type: 7H (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 56 69 77 0B
VIN: WV2ZZZ7HZCH049920   Mileage: 86450km-53717miles
04-Steering Angle -- Status: Not registered 0001
Address 01: Engine (J623-CCHA)       Labels: 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 DH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H43 9133
   Revision: 26H43---    Serial number: 00000000000000
   Coding: 01254012231400080000
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
   ROD: EV_ECM20TDI01103L906019DG.rod
   VCID: 74E715C9DF2EF89FED-8021
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BT 300 045 M    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H05 1712
   Revision: 00H05V01
   ROD: EV_TCMDQ500021_SE36.rod
   VCID: 3F8D8AE5A6E86BC7C0-806B
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 H    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0107
   Revision: 00H43001
   Coding: 208724AD09A8049E24AB9073AA5E10
   Shop #: WSC 02756 790 49152
   VCID: 377DE2C586D8538708-8063
                    Fault Status: 01100101
                    Reset counter: 56
                    Mileage: 86450 km
                    Date: 2015.07.11
                    Time: 22:25:47
                    Count: 16512
                    Count: 4865
                    Count: 8215
                    Count: 762
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 56
                    Mileage: 86450 km
                    Date: 2015.07.11
                    Time: 22:42:03
                    Count: 16384
                    Count: 4353
                    Count: 300
                    Count: 764
Address 08: Auto HVAC (J301)       Labels: 7E5-907-047.clb
   Part No SW: 7E5 907 047 BA    HW: 7E5 907 047 BA
   Component: Climatic-T5   H19 0404
   Revision: 00001009
   Coding: 0000000402
   ROD: EV_ClimaT5Basis_VN75.rod
   VCID: 6FED1AA5B608DB4710-803B
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 H    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0251
   Revision: BO047001    Serial number: 0429 269110622
   Coding: BAB879380E2120130028081022288CD50080410F60040040300000000000
   Shop #: WSC 35683 123 104857
   VCID: 3979E4FDB0CC45F7FE-806D
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-801.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-802.CLB
   Component: J387__TSG_BT  002 3311
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 D    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47301120800438
   Coding: 108101
   ASAM Dataset: EV_VW75XParkAssis4K A01006
   ROD: EV_VW75XParkAssis4K_VN75.rod
   VCID: 3365D6D59AA0BFA734-8067
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag00B H06 0013
   Revision: --------    Serial number: 003HL007WDMT
   Coding: 000000000000000000000000000000003042
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750_SE12.rod
   VCID: 3561E8CD94D4A1971A-8061
   Part No SW: 7E0 920 860 E    HW: 7E0 920 860 E
   Component: KOMBI         H04 0305
   Coding: 760200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
   VCID: 2A5BCBB14D6AFE6F87-807F
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H47 0251
   Revision: BO047001
   Coding: 942300
   VCID: 70EF19D9A336C4BF09-8025
                    Mileage: 86450 km
                    Date: 2015.07.11
                    Time: 22:25:10
                    Reset counter: 56
                    Mileage: 86450 km
                    Date: 2015.07.11
                    Time: 22:27:15
   Component: IMMO          H04 0305
   VCID: 6ADB0BB18DEA3E6F47-803F
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  040 0167
   Revision: 00000001    Serial number: VWZ1Z3K3531926
   Coding: 0800020101
   Shop #: WSC 10580 123 65156
   VCID: 62CB63917DDA662F8F-8037
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Revision: 3A001001    Serial number: 00000158754925
   Coding: 410D000100000000
   Shop #: WSC 02756 790 00000
   VCID: 306FD9D963B684BF49-8065
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007662471347
   Coding: 0A00000000010110
   Shop #: WSC 00015 115 12345
   ASAM Dataset: EV_UHVNA A01719
   ROD: EV_UHVNA.rod
   VCID: 26433F815972DA0FA3-8073
End-------------------------(Elapsed Time: 02:46)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Which clockspring is currently installed? The paddels will work out of the box IF your transmission supports it (done the same on my 2014 and had no issues). Since yours is a 2012, it should do that but then there are also updates available. We definitly know that 2010/2011 had a TCM software that wouldn't support it but later updates fixed that.
As for the #19 issues, check your installation list - you need to code the gateway installation list so it will recognize the steering angle sensor.
VWCentral
Australia
C?ID=109844
Thanks Sebastian. when i add 44 (Steering angle) to the list in 19 it accepts the coding, but then there is no response from 44 when i scan.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
04 = Steering Angle Sensor
44 = Steering Aid
04 won't respond either but it NEEDS to be in the list for proper message routing.
VWCentral
Australia
C?ID=109844
Hi Sebastian,
I have played around a bit and could not clear any of the 09 Can faults without removing 44 Steering Aid (which always appears as unreachable) from the list.
After i removed it, I now only have one fault the in ABS which is the Steering angle issue, please see scan here;
Wednesday,15,July,2015,23:15:10:53046
Mileage: 86550km-53779mi   Repair Order:
VIN: WV2ZZZ7HZCH049920   Mileage: 86550km-53779miles
   Revision: 00H05V01
   Revision: 00H43001
                    Reset counter: 65
                    Mileage: 86553 km
                    Date: 2015.07.15
                    Time: 23:07:59
                    Count: 16384
                    Count: 4353
                    Count: 8215
                    Count: 764
   Revision: 00001009
   Coding: 0000000402
   Coding: BAB879380E2120130028081022288CD50080410F60040000300000000000
   Coding: 108101
   Coding: 760200
   Revision: BO047001
   Coding: 942300
   Coding: 0800020101
   ROD: EV_UHVNA.rod
End-------------------------(Elapsed Time: 03:08)--------------------------
I cannot understand why the buttons dont illuminate, even if there is a coding issue, after all i tested the airbag loom, plugged into the clockspring and am getting 12v on the pin as well as being able to trigger the horn by putting a tester on the pin.
Please help!!!
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Again, you need to register 04 - not 44. ;) As for your MFSW, the illumination is a CAN/LIN signal - I wouldn't be surprised if your problem is the wiring. Your MFSW isn't showing up as slave in #09 but it needs to. Here's an example from my own T5 (see subsystem 7)... Yes, this is from a 3C8-419-091-BF that replaced the factory MFSW which didn't come with shift paddels. ;)
   Part No SW: 7H0 937 090 B    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0XXX
   Coding: B8A2393A0A63241293280F716EEB8FD50290662F7E8D7953320002030000
   Component: RLS 010713 05  54  0403
   Coding: 02252E
   Subsystem 2 - Part No SW: 7E0 959 801 A    HW: 7E0 959 801 A  Labels: 7E0-959-801.CLB
   Component: J386__TSG_FT  003 3313
   Coding: 440000
   Subsystem 3 - Part No SW: 7E0 959 802 A    HW: 7E0 959 802 A  Labels: 7E0-959-802.CLB
   Component: J387__TSG_BT  003 3313
   Coding: 440000
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 5U0 959 537 A    HW: 5U0 959 537 A
   Coding: E30000
VWCentral
Australia
C?ID=109844
ok, so i will resolder the wire from the clockspring to the BCM (pin 17) and see what happens. Does your wheel have an internal module where left and right buttons run into? or is it a continuous, ribbon between the two buttons, with the plug from the loom, behind the left button? Like my wheel...
Sebastian
Magdeburg, Germany
HN0-nnnnnn
If you look closely at the wiring diagram, it confirms that the J453 (Control Module for MFSW) is identical with E440 (MF Buttons LEFT) while E441 (MF Buttons RIGHT) are wired straight to J453/E441. So there is no separate module like there used to be on older models.
As for your wiring, T41/10 (LIN) goes from the F350/clockspring to J519 T73b/17 (that's the WHITE connector on the BCM). Are you sure that is properly wired up?
As for T41/9 (Terminal 15), that goes to SC34 (Fusebox C, Socket 34). It does NOT go to E1 (Light Switch). The Light Switch has a 10pin connector, so not sure where you get the idea there would be a PIN 15 on there. :p While T10bb/4 is Terminal 15 via SB22 (Fuse Box B, Socket 22) I would still use the proper SC34 instead for future fault finding and reference.
VWCentral
Australia
C?ID=109844
Thanks Sebastian, MFSW issue resolved. Unfortunately I spliced the wrong LIN cable, because i didn't select the White connector (really pissed at myself). Anyway, we have now a fully functional MFSW with paddles and the right switch controls the trip computer in the DIS (a little coding adjustment in 17 instruments).
so the outstanding issues are;
1) Cruise control
In (01 Engine), Byte 5 bit 5-6 00 Cruise Control System (CCS) not installed and won't let me change that.I have granted security access and tried but i get "Coding rejected, Error 22: Conditions not correct or request sequence error"
I have Cruise control activated in 09 Electrics.
What else am I missing?
Incidentally in (01 Engine) Byte 5, Bit 0 Right-Hand-Drive(RHD) won't let me select this either with coding error.
2) I still cannot clear the Steering angle fault codes, I am adding an updated scan.
Please help, Mark
Sunday,19,July,2015,14:28:54:53046
Mileage: 86630km-53829mi   Repair Order:
VIN: WV2ZZZ7HZCH049920   Mileage: 86630km-53829miles
   Revision: 00H05V01
   Revision: 00H43001
                    Fault Status: 00100011
                    Reset counter: 69
                    Mileage: 86553 km
                    Date: 2015.07.16
                    Time: 08:07:53
                    Count: 16640
                    Count: 257
                    Count: 300
                    Count: 748
                    Fault Status: 00101110
                    Fault Frequency: 10
                    Reset counter: 69
                    Mileage: 86557 km
                    Date: 2015.07.16
                    Time: 08:20:01
                    Count: 16384
                    Count: 4353
                    Count: 292
                    Count: 758
                    Reset counter: 66
                    Mileage: 86556 km
                    Date: 2015.07.16
                    Time: 08:12:57
                    Count: 19456
                    Count: 257
                    Count: 293
                    Count: 762
                    Reset counter: 65
                    Mileage: 86553 km
                    Date: 2015.07.15
                    Time: 23:07:59
                    Count: 16384
                    Count: 4353
                    Count: 8215
                    Count: 764
   Revision: 00001009
   Coding: 0000000402
   Subsystem 3 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Coding: E30000
   Coding: 108101
   Coding: 760200
   Revision: BO047001
   Coding: 942300
   Coding: 0800020101
   ROD: EV_UHVNA.rod
End-------------------------(Elapsed Time: 03:22)--------------------------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Pretty certain that you messed up the G85 while installing the wheel. It's either faulty and needs replacement or you might get away with fixing the installation position... Common issue when not following the instructions in the repair manual.
VWCentral
Australia
C?ID=109844
Hi Sebastian,
"fixing the installation position... " please explain.
VWCentral
Australia
C?ID=109844
Thanks for the link Sebastian. My german is not that great (2 years in high school) are you able to find the actual page please and give me the link, much appreciated.
VWCentral
Australia
C?ID=109844
Sebastian, are you suggesting that the clock spring position might have altered (spun by one or more revolutions)? I did tape it... how to check the Measuring Value Blocks if i don't have 44 Steering Aid controller?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Please read my posts, specifically #5 and #7.
1) There is NO Steering Aid (#44) in ANY T5/T6!
2) You need to fix the Installation List!
3) Remove #44 from the Installation List.
4) Add #04 to the Installation List.
The Steering Angle Sensor is fully diagnosable via #03, whatever makes you think that you need a #44 to do this - please delete that entire though process from your thinking.
If you need to read up on vehicle electrics, databus and system functionality - please see the erWin page Uwe and I linked to. Once you access said site you can switch it to English (as well as most other relevant languages).
VWCentral
Australia
C?ID=109844
thanks guys, I'll go into it now.
any feedback on the cruise control set up?
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Fix the ESP issues, then look at CCS. It's not uncommon for CCS to be blocked if crucial systems report errors. In other words, CCS may be all good but due to the other mess it's disabled for safety reasons.
VWCentral
Australia
C?ID=109844
Hi Guys,
Thanks for your help.
I have run the reset procedure for G85 and it has cleared the fault.
The only outstanding issue is the Cruise control, as i still cannot enable the bit in 01 Engine, it comes back with error 22
here is the latest scan, your help is very appreciated.;
Thursday,23,July,2015,23:07:49:53046
Mileage: 86700km-53872mi   Repair Order:
VIN: WV2ZZZ7HZCH049920   Mileage: 86700km-53872miles
   Revision: 00H05V01
   Revision: 00H43001
   Revision: 00001009
   Coding: 0000000402
   Coding: E30000
   Coding: 108101
   Coding: 760A00
   Revision: BO047001
   Coding: 942300
   Coding: 0800020101
   Coding: 0A00000100010110
   ROD: EV_UHVNA.rod
End-------------------------(Elapsed Time: 03:13)--------------------------
