Both DPFs went back on today, along with the frame cross member. Left side is way easier than the right as far as hardware access goes. "May your bank 1 DPF clog" is my new subtle way of saying "...and the horse you rode in on"
Oh. Stupid pet tricks with air ride.
When we had the gas V8 I did most work under the car without jacking it up. I just barely fit.
The tdi is full boat, so the other day i thought, hey i can just put it in the highest position and get the room i need. Ignition on, lift the car, turn it off. Almost immediately however, it lets itself down.
So i lifted the car, placed jack stands under the right side, then turned the car off and watched the show. It is no Citroen DS, but the end result is a jacked up car with no jack. The Citroen btw, sop for tire changes is to lift the car, place a jack stand and then lower the car. It lifts the wheel off the ground like a dog peeing on a tree.
Today i finished up and thought i would just energize the ignition and the car would lift itself. Nope. It energized and stayed there, as if waking up and deciding that leaning right is the "new level"
I wasn't quite ready to fire up the engine, so i used an 8 ton bottle jack to lower it to all fours.
Anyway, with the underneath put together i pulled the top tubes off, and pulled the butterflies off. I cleaned up everything and reinstalled.
I fired it up and took it for a drive. What a scream it is when it pulls hard.
I still want to pull those upper manifolds off but for the moment I'm quite happy with the improvement.
