Audi A5 2011
Hi This codes comes after driving some bumps on the road . I replace the air flow sensor and the 5667 code come again , I apreciated any help
Thursday,11,June,2015,19:41:42:04429
VCDS Version: Release 14.10.2 (x64)
Address 01: Engine Labels: 06H-907-115-CAB.clb
Control Module Part Number: 8K2 907 115 AG HW: 8K2 907 115 D
Component and/or Version: 2.0l R4/4V TF H17 0002
Software Coding: 0114010A290F0160
Work Shop Code: WSC 99999 1023 2097151
ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002 (AU48)
ROD: EV_ECM20TFS0118K2907115AG.rod
VCID: 74E714BFDFAA62817A7-8021
U1113 00 [047] - -
5667 - Mass Air Flow Sensor (G70)
P0101 00 [237] - Implausible Signal
5671 - Boost Pressure Regulation
P0299 00 [237] - Control Range Not Reached
Thursday,11,June,2015,21:17:04:04429
U1113 00 [039] - -
U1113 00 [038] - -
P0101 00 [039] - Implausible Signal
Readiness: N/A
U1113 00 [047] - -
U1113 00 [039] - -
U1113 00 [038] - -
Readiness: N/A
Data version: 20150311
Thursday,11,June,2015,19:59:07:04429
Chassis Type: FR (8T0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56
77
VIN: WAULFAFR4BA028191 Mileage: 84810km-52698miles
Address 01: Engine (0-----CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H17 0002
Revision: E1H17---
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8K0 927 158 K HW: 0BK 927 156 N
Component: 0BK 20TFSIUSA H08 0007
Revision: --H08---
Coding: 001112
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMAL551211 001013
ROD: EV_TCMAL551211_AU48.rod
VCID: 3E73F697A166F8D15C3-806B
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 1D0D18
Shop #: WSC 05142 444 11820
VCID: 020B42679D1E5C3178B-8057
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 117
Mileage: 77319 km
Date: 2014.11.22
Time: 17:02:30
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0032
Hex Value: 0x0296
Hex Value: 0x00FF
Fault Status: 00101101
Reset counter: 157
Mileage: 84710 km
Date: 2015.06.10
Time: 20:11:22
Hex Value: 0x7900
Hex Value: 0x4006
Hex Value: 0x1F26
Hex Value: 0x46AC
Hex Value: 0x00FF
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H04 0430
Coding: 090000
VCID: 76E32EB7C1D67091443-8023
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H50 0071
Component: J764 ELV MLB H37 0042
Address 06: Seat Mem. Pass (J521) Labels: 8T0-959-760.clb
Part No SW: 8T0 959 760 C HW: 8T0 959 760 C
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00001002099889
Coding: 08017025002400001000
VCID: 43858763C284953933D-8016
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01230920101677
Coding: 64022000
VCID: 000F486F93124E216EF-8055
01187 - Rear Temperature Flap Positioning Motor (V137)
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Frequency: 7
Reset counter: 116
Mileage: 80571 km
Date: 2015.04.11
Time: 10:59:49
Voltage: 12.90 V
Temperature: 31.0°C
Temperature: 37.0°C
Count: 10000
Count: 8405
Bin. Bits: 01000000
Bin. Bits: 00000111
Time: 11.00 s
03037 - Rear Temperature Selection Potentiometer (G538)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 218
Mileage: 55498 km
Date: 2010.01.22
Time: 00:50:52
Voltage: 8.90 V
Voltage: 4.90 V
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000657757
Coding: 26001091003CAF010000080300003D3D0F1C528802010161000000
Shop #: WSC 06325 123 12345
VCID: 3C77FC9FBF7AEAC1727-8069
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 200910 H14 0070
Coding: 00FD11
Component: RLS H04 0003
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AN HW: 8K0 941 531 AN
Component: E1 - LDS H08 0090
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
03188 - Bulb for Side Marker Light; Front Left
Reset counter: 218
Mileage: 55498 km
Date: 2010.01.22
Time: 00:52:00
03189 - Bulb for Side Marker Light; Front Right
Reset counter: 218
Mileage: 55498 km
Date: 2010.01.22
Time: 00:52:00
03124 - Terminal 30 - 3
Reset counter: 211
Mileage: 77616 km
Date: 2015.02.05
Time: 21:50:00
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Serial number: 003GLD90GDSX
Coding: 000000000000000000004A55000000000000
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 4581997BC4B0AB091D9-8010
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R10000014VK
Serial number: 6334MSME575621616
Serial number: 6344MSME54614A5DM
Serial number: 6352QSME0870502CB
Serial number: 6362QSME59734C36R
Serial number: 63732SME07362568-
Serial number: 63832SME26711E20X
13 Faults Found:
B1006 1B [129] - Resistance Too High
9442587 - Igniter for battery interrupt
B1015 1B [129] - Resistance Too High
B1007 1B [129] - Resistance Too High
9441563 - Rear; driver's side; side-airbag igniter
B1011 1B [129] - Resistance Too High
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [129] - Resistance Too High
9442331 - Passenger's Belt Force Limiter Igniter
B1014 1B [129] - Resistance Too High
9441307 - Rear; passenger's side; side-airbag igniter
B1010 1B [129] - Resistance Too High
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
B1009 1B [129] - Resistance Too High
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
B1008 1B [129] - Resistance Too High
9441819 - Safety belt tensioner igniter; rear; center
B1012 1B [129] - Resistance Too High
13697280 - Component Protection
U1101 00 [129] - Active
13697024 - Component Protection
U1100 00 [129] - No Basic Setting
13636352 - Control module not coded
U1013 00 [129] - -
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
Component: Lenks.Modul H06 0156
Revision: 00000000 Serial number: 20100920000037
Coding: 000036
VCID: 4999954BE0A84F69F91-801C
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 951 A HW: 8T0 920 951 A
Component: KOMBIINSTR. H33 0258
Revision: 00200000 Serial number: EHN332F9A
Coding: 831701000300D705020000
VCID: 377DE3B3865CC9999F5-8062
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G109048296
Coding: 00C303
VCID: 01094D6B98184729611-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Fault Frequency: 150
Reset counter: 117
Mileage: 55498 km
Date: 2010.01.22
Time: 00:01:26
Bin. Bits: 10111
Voltage: 11.50 V
Count: 6
Text: 3F33746CFFFFFF80FFFFFFA20000
Inj. Quantity: -9.10 mg/str
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020302
VCID: 3979E58BB048DFE9691-806C
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00001002111977
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C03224000120102
VCID: 53A5B72332E405B983D-8006
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0134893477
Coding: 0106049A00FA440480B0003200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010102
VCID: 74E714BFD7AA62817A7-8021
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
VCID: 52ABB2270DFE0CB188B-8007
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000615999
VCID: 3467D4BF972A2281BA7-8061
Reset counter: 157
Mileage: 84710 km
Date: 2015.06.10
Time: 20:11:23
Voltage: 13.90 V
Count: 58
Speed: 120.0 km/h
Hex Value: 0x0270
Hex Value: 0x0004
Hex Value: 0x0101
Fault Status: 11101101
Reset counter: 234
Mileage: 78359 km
Date: 2015.03.17
Time: 11:34:18
Voltage: 11.40 V
Count: 80
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
03200 - Switch for Electric Parking Brake (E538)
Fault Status: 00101011
Reset counter: 131
Mileage: 83342 km
Date: 2015.05.18
Time: 19:33:53
Voltage: 13.20 V
Count: 38
Hex Value: 0x02F0
Hex Value: 0x0001
Hex Value: 0x0202
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
VCID: 3979E58B7048DFE9691-806C
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000009 Serial number: AUZ5Z6J1467465
Coding: 040200020104850043D9070800
VCID: 46839E77F1B6A011143-8013
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Reset counter: 199
Mileage: 77319 km
Date: 2014.11.22
Time: 17:31:56
Fault Frequency: 98
Reset counter: 156
Mileage: 77332 km
Date: 2014.11.26
Time: 11:33:02
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Part No SW: 8T0 862 336 E HW: 8T0 862 336 E
Component: FSE_256x BT H42 0650
Revision: 00000000 Serial number: 00000005092522
Coding: 0010370
VCID: 3D71F19B6460E3C9459-8068
01523 - Microphone for Telephone (R38)
Reset counter: 215
Mileage: 77655 km
Date: 2015.03.04
Time: 18:38:39
End-------------------------(Elapsed Time: 03:27)--------------------------
