Retrofitted Golf Mk7 mfsw to a 2009 Mk6 Golf
JCCN
Portugal, Lisbon
C?ID=238545
Someone can help me, please?
I have a Passat B6/3C 2007 highline , I liked to put a wheel of Golf 7 / Scirroco R -Line, but do not know what the reference of the compatible module.
New wheel :
5G0419091CQ R-Line
Module that is in my Passat Source:
3C0953549M
Thank you.
Sorry for my English
João Neto
   #23
Spacewalker
Poland
C?ID=159607
Thats bad news, i though that the plug is for the illumination.
Any thoughts on how to make the buttons lit up?
you should post autoscan with working buttons as we spoke .
then we can look what you have
JCCN
Portugal, Lisbon
C?ID=238545
New wheel :
5G0419091CQ R-Line
3C0953549M
Does anyone have any idea? please!
Thank you.
João Neto
   #25
Guys, I'm moving this thread to the Retrofits section. Those of you who aren't verified members yet will need to get verfied if you want to continue to participate.
Vdub
C?ID=57533
Caddy 2015 MFSW fully working in my 10 years old Touran ;)
https://youtu.be/lU3CNWHqj0A
Is it the same MFSW as in the Golf7 or the Polo? I have retrofitted an MK7 GTI MFSW and none of the buttons work as they should except for the Paddles.
What did you change in the wiring? I have an Sharan 2012 Gateway, Touran 2010+ Color Instrumentpanel, 653C Clockspring, 549CH Steeringcolumnmodule
   #28
Spacewalker
Poland
C?ID=159607
6C0 fully working with 5K0 SWCM
But January "17 I will have converter to run MFSW with CCS and also to run MK7 MFSW with CCS in older car
   #29
DV52
C?ID=194404
Vdub:I'm not sure about your Sharan, but the major change that the boffins @ VW made to the steering wheel for the mk7 was the inclusion of the multifunction steering wheel in a network.
Here's an extract from the mk7 SSP
While the multifunction steering wheel control unit J453 was previously a LIN slave to the steering column electronics control unit J527, it is now connected directly to the diagnostic interface for data bus J533 as a LIN slave. As is visible in the network, the signals from the multifunction steering wheel are, as previously the case, transmitted via the coil connectors and the steering column electronics control unit, but for wiring reasons only. They do not have any effect on functions there​
Here's a diagrammatic depiction of the different network arrangement
Is the network arrangement for your Gateway from the 2012 Sharan the same as the mk7?
EDIT: ok - I was finally able to find a Sharan 2012 autoscan HERE. Looks like the Gateway has no LIN modules (alas). Note that the multi-function steering wheel module on the Sharan is the more traditional setup- it hangs off J527 (i.e the module @address hex16 like the pre mk7 diagram above). Whereas the portion of an auto-scan from my mk7 (below) shows the multi-function steering wheel module being a slave on the J533 Gateway.
Sorry for being the harbinger of bad news - but this suggests a fundamental compatibility problem (I think)
   Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
   Component: GW MQB Mid    121 1109
   Revision: --------    Serial number: 0000188941
   Coding: 030100342B086400EF0006481C0F00010001000000000000000000000000
   Shop #: WSC 00028 028 00025
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   VCID: 3365F3749A38A9DA04-8066
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J
   Component: E221__MFL-DC1  H13 0035
   Serial number: 02120005290300060291
   Coding: 280000
Vdub
C?ID=57533
I have a Caddy '06 by the way.. Does it help changing the cable from the wheel to one from a Golf6 or newest VW Polo?
Why is everything working fine in your Touran?
   #31
berndh
C?ID=66436
I have a 5K0953569T SWCM with a 5G0419091xx (Passat B8) steering wheel. Added the Bronken module, but then only audio buttons work and the paddles. Buttons are illuminated. I read there is no way to get this working without a converter module that converts the new style lin2.0 messages to old style (RNS510) lin2.0 messages.
My steering wheel is also heated. Would be nice to get that working too. I was thinking of replacing the slipring from the B8 into the B7 SWCM and then connect these two wires outside of the SWCM, since my 5K0953569T does not have SW to support heating.
   #32
Spacewalker
Poland
C?ID=159607
My latest DIY in 2016!!!!
Happy New Year everybody !!!!
berndh
C?ID=66436
really cool. happy new year.
   #34
h.vanwijk
C?ID=340525
That’s really nice. I have a problem with my caddy 2007 and a mk7 steering wheel. It is not working.
   #35
The place to start would be to post an Auto-Scan, and the part number of the steering wheel you have installed wouldn't hurt either.
