How to confirm Mileage, ECU is stock, resetting OBD counter
tomastomas
Philippines
1A132000004
hi,
would anyone know how to do the following for the golf gti mk7:
1. confirm if the mileage showing is the cluster has not been tampered
2. how to check if the ecu has not been tuned or altered
3. is there away to reset the obd counter when modifying the ecu to make it untraceable
thank you
Jef
HQ
1 - unknown at this time.
2 - test drive the car.
3 - unlikely with VCDS.
I don't know of any way except to judge whether the wear and tear on the rest of the car is commensurate with the odometer reading.
On any turbo engine, log requested manifold pressure and compare the peak values with those from a known stock car.
You mean the flash counter? Depends on the techniques used by the tuner. Personally, I wouldn't put any faith in that counter.
Keithuk
Stoke on Trent, England
C?ID=122432
I know the dealers machine can check if its been flashed while its in for warranty work that way they make the claim void.
The dealer's tool may compare the CVN (see generic OBD-II specs for Mode 9) (or a similar checksum) against their database, which knows the CVN for each ECU software part number and version. In principle one could use a similar technique with VCDS; get the CVN in generic OBD-II mode and compare it with that from a known stock ECU of the same part number and software version.
However... At least some ECU tuners are aware of this and probably have the skill to fake this out, by having non-stock software return a stock CVN. After all, it's just another checksum and they must already "fix" all manner of checksums in what they do, otherwise they tunes won't be functional at all.
roth
C?ID=242642
Sometimes you can see mileage in other modules engine / trans / etc. You have to go 1 by 1 and look.
Andy
mtl
Slovenia
C?ID=153305
How to check mileage in DSG transmission for example?
roth
C?ID=242642
Told you bro, you have to go trough all MVBs 1 by 1 to see the mileage.
Andy
mtl
Slovenia
C?ID=153305
Sadly in newer DSG transmissions (DSG6 in MQB platform for example) it is not possible to check this mileage. Is this due to change from VW and measuring value is not present or could this still be implemented in VCDS.
Transmission details of DSG that does not have this measuring value (or any other regarding this mileage). It does have some mileage data, but not total mileage.
Part No SW: 0D9 300 041 P HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4507
Revision: 05853104 Serial number:
Shop #: WSC 73430 031 00000
ROD: EV_TCMDQ250021_SE37.rod
VCID: 254BC5B124FAA0128A-8070
I don't see an obvious solution to implementing this. My guess is that it's in there somewhere, but since it's not documented in the ODX data available for the module, finding it would be the proverbial needle in a haystack problem.
mtl
Slovenia
C?ID=153305
Is there a way that we could help? I have access to this car and could ''play around''.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Many of the DSGs have "Snapshot" Measuring Values which are stored when a DTC is triggered, so even if there isn't a specific "Control Module Mileage" value - you will likely be able to see some data which may help with further investigation. In addition, you can always use the search function in advanced measuring values and look for "mileage", "odometer" or similar wordings and you'll likely find some useful hits. Obviously, without an Auto-Scan and seeing which modules are actually in the car, there isn't much more help we could provide.
mtl
Slovenia
C?ID=153305
Thx for your answer.
I have already checked all advanced measuring values and all that I considered ''usefull'' in determining mileage are these values:
But they do not look so usefull.
Can you say more about ''Snapshot'' Measuring Values and DTC triggering?
Here is a full autoscan of this car (sadly it is quite old and done with 14.10 version: if needed I can do a new one, but it will take a few days to get the car):
Monday,01,December,2014,08:57:11:07078
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: TMBAJ7NE4F   License Plate:
Mileage: 3850km-2392mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F A5
VIN: TMBAJ7NE4F   Mileage: 3850km-2392miles
Address 01: Engine (J623-CKFC)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7545
   Revision: 83H22---
   Coding: 111D001A036401091000
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
   ROD: EV_ECM20TDI01104L906021DT_AU37.rod
   VCID: 7AF1C6CDFDC4FFF121F-802F
   Revision: 05853104    Serial number: TFK01409160087
   VCID: 254BC5B124FAA0093CD-8070
          P1734 00 [002] - -
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 62724000001304
   Coding: 1A0762912420096D007A060741C5245846249000608224F0F661F070C002
   Shop #: WSC 73430 031 00063
   ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
   VCID: 4689623DF9BC4B11157-8013
   Revision: 00021000    Serial number: 0347609152
   Coding: 030C0C
   Shop #: WSC 73430 790 00000
   ROD: EV_KessyHellaMQBAB_SK37.rod
   VCID: 3A7106CDBD443FF161F-806F
   Part No SW: 5E0 907 044 P    HW: 5E0 907 044 P
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 01010104004101011005004100101000
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 32612EED6534C7B1A9F-8067
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011426303179
   Coding: 0C011B66424722FB07A04082B11C07280C00000000000000000000000000
   Shop #: WSC 73430 790 12345
   ROD: EV_BCMBOSCH_SK37.rod
   VCID: 0005B4259B18A5216FB-8055
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119
   Component: WWS371 140905  041 0570
   Serial number:         140924041441
   Coding: 065DDD
   Component: RLHS  037 0059
   Serial number: S5Y14M10D07H22M41S01
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY142031PK3
   Serial number: 00000000000060424345
534549 - Databus
                    Reset counter: 106
                    Mileage: 3850 km
                    Date: 2014.12.01
                    Time: 08:46:47
535060 - Databus
                    Reset counter: 66
                    Mileage: 3850 km
                    Date: 2014.12.01
                    Time: 08:47:40
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0048
   Revision: --------    Serial number: 39231428004523
   Coding: 0001150011
   ROD: EV_EPHVA14AU3700000_AU37.rod
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 14091403211058
   Coding: 00081600FE0739
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 38751CC583482DE197B-806D
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003P4PL802TV
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F0737D9E6E6DAD9161-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 809 14
   Serial number: 3576U000000E2A490116
   Subsystem 2 - Part No SW: -----------    HW: 454 002 109 14
   Serial number: 3586U000000F9B8D311R
   Subsystem 3 - Part No SW: -----------    HW: 454 802 909 14
   Serial number: 3516R3D34DC040000008
   Subsystem 4 - Part No SW: -----------    HW: 454 802 909 14
   Serial number: 3526RCA3DDC04000000O
   Subsystem 5 - Part No SW: -----------    HW: 454 801 209 14
   Serial number: 3556VF1DDA604000000Q
   Part No SW: 5Q0 953 507 EJ    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 05101404220884
   Coding: 6C10
   ROD: EV_SMLSKLOMQB_SK37.rod
   VCID: 0201BE2D9514B73179F-8057
   Part No SW: 5E0 920 751     HW: 5E0 920 751
   Component: KOMBI         304 4270
   Coding: 07A502186D80000801882A031000000000000000
   Shop #: WSC 73430 031 12345
   ROD: EV_DashBoardVDDMQBAB_SK37.rod
   VCID: 62C19EAD7554173119F-8037
Address 18: Aux. Heat (J364)       Labels: 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Component: STH-MQB       006 0069
   Coding: 9309
   VCID: 366912FD895CDB91857-8063
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000000959070
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1188
   Revision: --------    Serial number: 0002549744
   Coding: 030100040F087300EF00025A1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear.rod
   VCID: 42817E2DD594773139F-8017
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000B1894230914
   Serial number: 4977624603
   Revision: 00000000    Serial number: 14000267699004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 346D28F59F20C981BB3-8061
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000120566063
   Coding: 00150020D000040000001100
   VCID: 448D7835CF8079010B3-8011
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000004003919
   Coding: 010200
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 9102
   ROD: EV_SteerAssisMQB_SE37.rod
   VCID: 41837121D0926C29205-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000120646816
   Coding: 00150020DC00040000001100
   VCID: 438F7B29CA8E7E39329-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000003923673
   Coding: 190200
   Coding: 03CA02003F000000
   Shop #: WSC 73430 790 00063
   VCID: 40857425DB9865212FB-8015
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B
   Coding: 3E0000
   Part No SW: 5E0 035 840 A    HW: 5E0 035 840 A
   Component: MU-S--ER      041 0435
   Serial number: S3E00510140218
   Coding: 03730100FF00000011110001000000002F0000940100010002
   ROD: EV_MUStd4CPASE_SE37.rod
   VCID: 1F47D75906A67AD9761-804A
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
   Component: ABT_Std_Plus  H60 0030
   Serial number: SKZ8Z9PT100A8B
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 10000140789
   Coding: 0100010001030300000400000100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B7F03C9B27E06F97A9-806E
End-------------------------(Elapsed Time: 05:22)--------------------------
vu2gte
India
C?ID=262838
Maybe a fault has been logged with mileage.
mtl
Slovenia
C?ID=153305
This is what I've first checked, but this is also what mileage ''tweakers'' delete first ;).
Blazs_A4ABC
Hungary
C?ID=217092
Hey all,
I'm new to this forum.
I'm also interested in finding a way to validate the mileage shown on the instrument cluster. I understand that apart from the EDC15-16 check (-> some diesels only), there are really no options to have a reliable reading of the mileage.
But there are quite good guesstimations based on the overall operation time of certain other ECUs (head units, climate control units etc.) that store such information. E.g. some Audi MMI units have an optime counter in their hidden service menus.
Assuming a typical average Bordrechner speed of a car of around 35..60 km/h overall (assuming city and highway averages), one can calculate a 'virtual' mileage that, if much more (e.g. 20% more) than the indicated mileage, is sign that the car reverses a lot. :D
Now, I'm looking for the same type of information on other VW brands like Skoda and VW. No mileages just some operation time info on head units or other ECUs that could store it.
Could such data be read out read out with VCDS? Or could this be possible in future releases?
I assume, within the VW group, head units are often re-used so there not too many models to cover.
Like the EDC counter, this would prove nothing but gives an indication for double-checking.
Blazs
I don't recall seeing Hobbs Meter type values anywhere, but I haven't really looked for them either.
The results from the Ross-Tech fleet of cars would be interesting no doubt. They don't spend much time reversing, but they do spend a lot of time connected to Shore Power with the ignition switched on while we do development and testing. ;)
Blazs_A4ABC
Hungary
C?ID=217092
Finding any sources would be superb! :)
Car dealers where I live (Eastern EU) are blackbelt pros in faking and lying so any clue that the story they want to sell is made up, could prevent buying a lemon (here, lemon = can't be tracked what was serviced and when, what to service next and when). On EDC cars, I've seen 200k+ km reversing records between two inspections, the dealer lying without turning a hair when asking about it (odometer tampering is a crime but no one can prove who did it)... Here, people still remember the older Eastern bloc cars that needed major repairs just after 60-80k kms, after 120k they were considered FUBAR. The low mileage as a benchmark of good deal/reliability remained, so <100k is a selling point, >200k makes a price breakdown. But these cars still look and feel good, so the odometer stops rolling on used cars near 200k, no matter if 5 or 10 years old. They wouldn't buy a 300k car no matter how good it is or how genuine the service history... Any signs of a rollback would invalidate all statements about the servicing history, belt jobs etc. and it becomes the part of the deal (some major repairs assumed and discounted from the price), something dealers or sellers don't want. Since most cars are manual here (auto trannies are avoided due to repair costs and reliability issues), we have one less option to get info about the mileage.
Btw, knowing that older DSGs still contains this little clue, I might consider those cars too. :)
(p.s. I took part in some ECU software development and the ECU I was working on, contains such a counter. ;) )
Blazs
Gavra
Melbourne/Belgrade
C?ID=240855
hi,
thank you
1. No
2. read flash and post to check turbo pressure limiter, injection map and DTC table
3. more than 5 that I am aware off
Some tools allow you to send hex command directly to module.......so do not rely on any digital signature in the modern vehicles ;)
