hello i have some problems with retrofiting headlights,i have both headlight range control unit but cant code it.error 22,and i cant found security acces code for this module.can anyone help me what is wrong?high beams and cornering light doesnt work,all over light working correctly.
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
Address 01: Engine (J623-CLHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 AL HW: 04L 907 309 B
Component: R4 1,6L EDC H22 5516
Revision: 84H22---
Coding: 02190012030401092000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM16TDI01104L906021AL 002009
ROD: EV_ECM16TDI01104L906021AL.rod
VCID: 6FEDFCA7B6E853402E-803A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 12F162A220280A75017A060601CB2548460450806080A4F20059000405
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 7DF1D6EFEC8431D0AC-8028
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 HW: 8V0 820 043
Component: AC Automat H12 0031
Revision: 20020000 Serial number: 00000000085242
Coding: 03000104002000001000000000001000
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 084 M HW: 5Q0 937 084 M
Component: BCM MQBAB B H14 0106
Serial number: 00011311700980
Coding: 04000842C24102F503A44000000407080000000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 428B6513D5FA8E2891-8017
Slave 1:
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119
Component: WWS370 130428 041 0580
Serial number: 130430201941
Coding: 0A47F7
Slave 2:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Serial number: 21292588
Coding: 00006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 P HW: 8V0 941 531 P
Component: E1 - LDS MQB H05 0032
Serial number: 05 03 2013 00000764
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231312702542
Coding: 0010050041
ASAM Dataset: EV_EPHVA18AU3700000 002016
ROD: EV_EPHVA18AU3700000.rod
VCID: 3A7B1DF3BD2AC6E8C9-806F
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R01G5C2
Coding: 98CCC0000C0000005C540000004800000065
VCID: 4B954837E2B04F6062-801E
Subsystem 1 - Part No SW: ----------- HW: 480 000 705 13
Serial number: 357670000005B4A40D0W
Subsystem 2 - Part No SW: ----------- HW: 480 000 705 13
Serial number: 35867000000944A40D0U
Subsystem 3 - Part No SW: ----------- HW: 480 401 804 13
Serial number: 3516502C50FEADA3F03-
Subsystem 4 - Part No SW: ----------- HW: 480 401 804 13
Serial number: 3526502C50FEADA172B.
Subsystem 5 - Part No SW: ----------- HW: 480 401 203 13
Serial number: 3556502C50F8ABF4623V
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 402 604 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502B71050653D1B2
Pedestrian protection crash sensor; front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 402 404 13
Component: PedP_Sensor_P 001 6149
Serial number: 2296502BD1012332D1A0
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 402 604 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502B91050653D2F2
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 10051308490333
Coding: 8408
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 77FDC4C7CEB81B80F6-8022
Part No SW: 8V0 920 860 B HW: 8V0 920 860 B
Component: KOMBI H22 0570
Coding: 07840A00228000080D00E800000000
VCID: 397902FFB82CCDF0C0-806C
Address 19: CAN Gateway (J533) Labels: Redir Fail!
Part No SW: 5Q0 907 530 H HW: 5Q0 907 530 E
Component: GW MQB Mid 124 1126
Revision: -------- Serial number: 0000569150
Coding: 030100F40B08760000000200000B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 008010
ROD: EV_GatewLear_AU37.rod
VCID: 366309C3893222882D-8063
Subsystem 2 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051297363
197169 - Controls in Steering Wheel
Reset counter: 223
Mileage: 8796 km
Date: 2015.03.28
Time: 17:24:45
Part No SW: 5Q0 959 393 A HW: 5Q0 959 393
Component: TSG FS 012 0006
Serial number: 02051302090026
Coding: 00100E204100040000001002
VCID: 3D7116EFAC04F1D0EC-8068
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Component: FOND_FHSG_DRV 005 0004
Serial number: 00000000000000125237
Coding: 110000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 01
ROD: EV_SteerAssisMQB.rod
Part No SW: 5Q0 959 392 A HW: 5Q0 959 392
Component: TSG BFS 012 0006
Serial number: 01051301100422
Coding: 001006204100040000001002
VCID: 3C771BEBB71EF8D8DB-8069
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000211918
Coding: 090000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 0000000000000000
ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
VCID: 3F8D6CE7A608E3C0FE-806A
Subsystem 1 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7000
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo rechts H01 7000
Coding: E00100
13705481 - Databus
U1121 00 [137] - Missing Message
Reset counter: 223
Mileage: 8796 km
Date: 2015.03.28
Time: 17:24:44
5275220 - Headlight
Reset counter: 223
Mileage: 8796 km
Date: 2015.03.28
Time: 17:24:45
13636352 - Control module not coded
U1013 00 [137] - -
Reset counter: 223
Mileage: 8796 km
Date: 2015.03.28
Time: 17:24:45
10490624 - No End-of-Line Programming
B2013 00 [137] - -
Reset counter: 223
Part No SW: 8V0 035 864 A HW: 8V0 035 864
Component: MU-S-N-ER 039 0370
Serial number: A3F01305130409
Coding: 01730301FF00000021110001000A00002F0004440100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_AU37.rod
Seat Adjustment Driver Side:
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H47 0013
Serial number: AUZ8Z9DG600U3T
Sound System:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000019031300020125
End-------------------------(Elapsed Time: 03:09)--------------------------
