- Joined
- Mar 20, 2014
- Messages
- 21
- Reaction score
- 5
- VCDS Serial number
- C?ID=94920
Hi
Wondering if anyone could help me with this Golf.
VCDS Version: Release 12.12.2
Data version: 20140212
Specialist Motor Service
Monday,07,April,2014,16:05:13:49214
Chassis Type: 1H - VW Golf/Vento III (1992 > 1999)
Scan: 01 02 03 08 12 15 25 41 56
Address 03: ABS Brakes Labels: 3A0-907-379.lbl
Part No: 3A0 907 379 D
Component: ABS ITTAE 20 GI V00
Coding: 03704
VCID: 2B5EFBB2D9C50E461E5-4A52
16-10 - Signal Outside Specifications - Intermittent
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 608 K
Component: AIRBAG VW3 S V04
Coding: 00075
VCID: 3668DAC6128743AE71B-4B00
Address 25: Immobilizer Labels: 1H0-953-257.lbl
Part No: 1H0 953 257 B
Component: IMMO VWZ3Z0M2519376 V00
Coding: 09600
Shop #: WSC 35110
VCID: 2A50FEB6D63F174EE53-4AE6
00546 - Data wiring faulty
27-00 - Implausible Signal
End ---------------------------------------------------------------------
Keep getting 00546 DTC. Vehicle has been fitted with new engine ECU and immobilizer ECU. Local VW workshop coded and even they got the same code but claimed that the VW system confirmed that coding had been successful. Strangely they charged me for coding both the engine and immobilizer ECU's individually, how they achieved that without being able to communicate with the engine ecu I'm not quite sure. The engine starts and cuts out almost immediatley. Signal from immobilizer to engine ecu remains constant. I have checked all wiring and signals between the 2 ecu's and found no fault. Fuel and engine control relays have been substituted for known good units with no change in behaviour.
Any ideas would be gratefully received.
Coding: 03704
Coding: 00075
Coding: 09600
Shop #: WSC 35110
