Can anyone help me here please. Car is Audi Q3 1.4 TFSi in the UK....Built and registered in 2014. Through VCDS I have added the lap counter function complete with oil temp display and also the boost pressure display, which all displays OK. The only issue I have now is that boost pressure bar does not animate at all, it remains an empty display.
Have I missed something?? Do I need to enable something else to display a simulation of boost pressure? Someone has suggested this is only available on the RS car, but I've seen a picture assumed from a 2.0 TDi, although this was a car from Poland.
Are there any measuring blocks for boost pressure, and if so, how do I check please...... Total newbie to VCDS, so treading carefully at the moment
VCDS scan attached
VCDS scan attached
Thursday,05,March,2015,16:46:49:57949
VCDS Version: 14.10.1.1
Data version: 20150130
VIN: WAUZZZ8U2ER103543 License Plate: YM14EEW
Mileage: 5280km-3280mi Repair Order:
Chassis Type: 8U (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 53 55 5F 62 72
VIN: WAUZZZ8U2ER103543 Mileage: 5280km-3280miles
Address 01: Engine (J623-CHPB) Labels: None
Part No SW: 04E 906 027 CL HW: 04E 907 309 AE
Component: 1.4l R4 TSI H21 7158
Revision: R9H21---
Coding: 001D0032240419082000
Shop #: WSC 00049 770 00201
ASAM Dataset: EV_ECM14TFS01104E906027CL 002006
ROD: EV_ECM14TFS01104E906027CL.rod
VCID: 70C13FBAAB414EA19E0-8025
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 058 F HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4302
Revision: 05652104 Serial number: 00001405050112
Shop #: WSC 00049 770 00155
VCID: 1D1F360EC45393C9656-8048
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BA HW: 5N0 614 109 BA
Component: J104 C6 450M VDD1 0160
Revision: --H07--- Serial number: 00000008154174
Coding: 0056756
VCID: 6BFB28D64A67AD79AB2-803E
Part No SW: 8U0 820 043 D HW: 8U0 820 043 D
Component: E87 Klimavoll 0100
Revision: 00H04000 Serial number: 8U0820043D
VCID: 3245F5B2ADCD3CB1A84-8067
Address 09: Cent. Elect. (J519) Labels: 8X0-907-063.clb
Part No SW: 8X0 907 063 R HW: 8X0 907 063 R
Component: BCM PQ35 M 113 0811
Revision: AD113811
Coding: 0E000A2CA805F1C0201841C02104894C53FF84AA216F912BE408878400C5
Shop #: WSC 00049 770 00009
VCID: 4BBB8856EA274D79CB2-801E
Subsystem 1 - Part No SW: 8U2 955 119 HW: 8U2 955 119
Component: WWS316 140423 H37 0085
Coding: 0047F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
Address 10: Park/Steer Assist (J446) Labels: 8X0-919-475.clb
Part No SW: 8X0 919 475 N HW: 4H0 919 475 AG
Component: PARKHILFE 8K H01 0050
Revision: 11001001 Serial number: 61061414302841
Coding: 08C305
ASAM Dataset: EV_EPHVA18AU21X0000 003006
ROD: EV_EPHVA18AU21X0000.rod
VCID: 51879A3E000B67A9B1E-8004
Address 15: Airbags (J234) Labels: 8X0-959-655.clb
Part No SW: 8U0 959 655 B HW: 8U0 959 655 B
Component: AirbagVW-AU10 H09 0520
Serial number: 003LRR088YML
Coding: 30393132313030303030554A305238553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001005
ROD: EV_AirbaAU10SMEAU316.rod
VCID: 46ADB962F945B01114C-8013
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3496KSME1126652EZZZX
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3506KSME1C132C2EZZZZ
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME702C652EZZZ.
Serial number: 3526KSME65654E2EZZZ3
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME5B603E2DZZZD
Address 16: Steering wheel (J527) Labels: 8X0-953-569.clb
Part No SW: 8X0 953 521 B HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010018 Serial number: 20140513100166
Coding: 1894004000
ROD: EV_SMLSNGVOLWS.rod
VCID: 3B5BD896B287FDF97B2-806E
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Address 17: Instruments (J285) Labels: 8X0-920-xxx-17.clb
Part No SW: 8U0 920 990 D HW: 8U0 920 990 D
Component: KOMBI_COLOUR H01 0240
Coding: 42CF01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
VCID: 3E5DD182A195E8D15CC-806B
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 AC HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0072
Revision: 1P130039 Serial number: 3941P145100084
Coding: FBCF1A5A000100610353
VCID: 032B607682F74539732-8056
Component: J367-BDM H07 0180
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Component: IMMO H01 0240
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels: 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H10 0415
Coding: 011E06200001000000
VCID: 528595320D0D1CB1884-8007
Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 299 3501
Revision: 00H22000
VCID: 40A1AF7A13619E212E0-8015
Address 52: Door Elect, Pass. (J387) Labels: 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H10 0415
Coding: 011E06200C01000000
VCID: 51879A3E080B67A9B1E-8004
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000018831
Coding: 0025166
VCID: 3851C79A4BB1D6E1960-806D
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 140516-0002-088
Coding: 1157941010002500
ROD: EV_HeadlRegulBasic.rod
VCID: 42A5A572D56D8C31384-8017
Part No SW: 8U0 035 192 E HW: 8U0 035 192 C
Component: RMC Nav Plus H55 0801
Coding: 0101060002C053070823020103010000000000
VCID: 364DC9A281A5209184C-8063
Subsystem 1 - Part No: 8X0 919 884 G
Component: P24-50-13.06 0001
Subsystem 2 - Part No SW: 8U0 919 603 A HW: 8U0 919 603 A
Component: DUBasic AU316 H42 0018
Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HL H07 0415
Coding: 010E06200001000000
VCID: 4F839C461E3F7159A7A-801A
Component: TSG HR H07 0415
End-------------------------(Elapsed Time: 02:42)--------------------------
