I've got a 2012 1.6TDi Auto that went in to limp mode when under load up a steep hill.
After turning engine off and back on, limp mode was cleared.
AutoScan below which states Injector fault. Is this likely to be the injector itself or wiring fault?
Thank you.
Thank you.
Thursday,13,August,2020,17:51:57:41168
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZ1KZCM662853 License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72 77
VIN: WVWZZZ1KZCM662853 Mileage: 146450km-90999miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MQ HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 9051
Revision: --H43--- Serial number: 00000000000000
Coding: 10254034032501080000
Shop #: WSC 00066 000 00088
ASAM Dataset: EV_ECM16TDI02103L906023MQ 003005
ROD: GV_ECM16TDI021PQ36.rod
VCID: 015F866C518307035C5-8054
9838 - Injector: Cylinder 2 (N31)
P0202 00 [032] - Circuit Malfunction
Mileage: 146385 km
Date: 2020.08.11
Time: 16:27:05
Engine speed: 1889.75 /min
Normed load value: 71.4 %
Vehicle speed: 63 km/h
Coolant temperature: 95 °C
Intake air temperature: 45 °C
Voltage terminal 30: 14.344 V
Unlearning counter according OBD: 37
Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 0
Injector valve 4: capacity-CAPA_INJ_MAIN[3]: 23.8990 µF
Voltage load of main injection cylinder 4-CHR_INJ_MAIN[3]: 1431.2 µAs
Measured energy of main injection cylinder 4-EGY_INJ_MAIN[3]: 42.853 mJ
Supply voltage of analog output 1-VCC_1: 4.98 V
Supply voltage of analog output 2-VCC_2: 4.99 V
Injection valve 4: voltage-V_INJ_MAIN[3]: 59.88 V
Part No SW: 0AM 300 053 C HW: 0AM 927 769 D
Component: GSG DSG AG7 431 3010
Revision: 00043014 Serial number: CU501112146161
Shop #: WSC 02069 000 90108
VCID: 2C0107D88A013A6BDF3-8078
Revision: 00H31001
Coding: 133B200D092800FCC81304E9901C0091310000
Shop #: WSC 00066 000 00000
VCID: 7DA7FA9C2DFB63E338D-8028
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0304
Revision: 00001016
Coding: 0000004003
Shop #: WSC 00066 000 00121
VCID: 7F5B0094277771F32A1-802A
Part No SW: 5K0 937 084 H HW: 5K0 937 084 H
Component: BCM PQ35 B 021 0064
Revision: BA021001
Coding: 08180E3A882DE1C0400800C0340000E44B700088437D0162648087200041
VCID: 372B28B44F4789B3A21-8062
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 18121 26 0512
Coding: 009795
Component: RLS 221111 05 54 0403
Coding: 0230AD
Component: Innenraumuebe 004 0611
Fault Status: 00101010
Fault Frequency: 40
Reset counter: 172
Mileage: 145201 km
Date: 2014.11.01
Time: 11:02:53
Term 15 On
Voltage: 14.50 V
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 1K9 919 475 A HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0004
Revision: -------- Serial number: 12501132700674
Coding: 108103
VCID: 392F2E8C79539FC3545-806C
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6RA6BBBF
Coding: 00003537
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 323D19A0A4A56C9B95F-8066
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME77110667ZZZS
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME33060667ZZZP
Serial number: 3511HSME60156029ZZZA
Serial number: 3521HSME105E5F29ZZZX
Part No SW: 5K0 953 507 AE HW: 5K0 953 549
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KIC000JD
Coding: 5880140000
Shop #: WSC 00066 000 00184
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 73B3DCA41B3F25935E9-8026
Part No SW: 5K0 920 972 A HW: 5K0 920 972 A
Component: KOMBI H33 0318
Revision: X0033006 Serial number:
Coding: 470B00
ASAM Dataset: EV_KombiUDSMM9RM10 A04305
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 2E050DD0B09D487BF17-807A
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 13011201280995
Coding: 352003
VCID: 3B233484736FADD3469-806E
Part No SW: 5K0 953 234 HW: 5K0 920 972 A
Component: IMMO H33 0318
ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A8DC1C04CF5E45BEDF-803E
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0502
Revision: 12110009 Serial number: 0003609947
Coding: 0202B4
Shop #: WSC 01383 790 50316
VCID: 1C61D718D621CAEBAF3-8048
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 007 1509
Serial number: 00000006271480
Coding: 000290
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 70 3301
Revision: 00H22000
VCID: 353722BC594B7BA3B0D-8060
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0502
Revision: 14110009 Serial number: 0003765056
Coding: 0203B4
VCID: 1D67DA1CCD3BC3E358D-8048
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 007 1509
Serial number: 00000006257289
Coding: 000290
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 042 0082
Revision: 00000001 Serial number: VWZ1Z2L3273594
Coding: 05000400040007
VCID: 72BDD9A064A52C9B55F-8026
Component: Batt.regelung H43 1623
Coding: 030F1859
VCID: 71BFD6AC61A31783AC5-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900858770
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661185354
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 2615F5F0986D003B097-8072
End----------(Elapsed Time: 01:29, VBatt start/end: 14.3V/14.4V)-----------
