VW Golf 2012 1.6Tdi auto. Went to Limp mode.
invernesspl
C?ID=345478
Hi,
I've got a 2012 1.6TDi Auto that went in to limp mode when under load up a steep hill.
After turning engine off and back on, limp mode was cleared.
AutoScan below which states Injector fault. Is this likely to be the injector itself or wiring fault?
Thank you.
Thursday,13,August,2020,17:51:57:41168
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ1KZCM662853   License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72 77
VIN: WVWZZZ1KZCM662853   Mileage: 146450km-90999miles
   Part No SW: 03L 906 023 MQ    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 9051
   Revision: --H43---    Serial number: 00000000000000
   Coding: 10254034032501080000
   Shop #: WSC 00066 000 00088
   ASAM Dataset: EV_ECM16TDI02103L906023MQ 003005
   ROD: GV_ECM16TDI021PQ36.rod
   VCID: 015F866C518307035C5-8054
9838 - Injector: Cylinder 2 (N31)
          P0202 00 [032] - Circuit Malfunction
                    Mileage: 146385 km
                    Date: 2020.08.11
                    Time: 16:27:05
                    Engine speed: 1889.75 /min
                    Normed load value: 71.4 %
                    Vehicle speed: 63 km/h
                    Coolant temperature: 95 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 14.344 V
                    Unlearning counter according OBD: 37
                    Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 0
                    Injector valve 4: capacity-CAPA_INJ_MAIN[3]: 23.8990 µF
                    Voltage load of main injection cylinder 4-CHR_INJ_MAIN[3]: 1431.2 µAs
                    Measured energy of main injection cylinder 4-EGY_INJ_MAIN[3]: 42.853 mJ
                    Supply voltage of analog output 1-VCC_1: 4.98 V
                    Supply voltage of analog output 2-VCC_2: 4.99 V
                    Injection valve 4: voltage-V_INJ_MAIN[3]: 59.88 V
   Part No SW: 0AM 300 053 C    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 3010
   Revision: 00043014    Serial number: CU501112146161
   Shop #: WSC 02069 000 90108
   VCID: 2C0107D88A013A6BDF3-8078
   Revision: 00H31001
   Coding: 133B200D092800FCC81304E9901C0091310000
   Shop #: WSC 00066 000 00000
   VCID: 7DA7FA9C2DFB63E338D-8028
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0304
   Revision: 00001016
   Coding: 0000004003
   Shop #: WSC 00066 000 00121
   VCID: 7F5B0094277771F32A1-802A
   Part No SW: 5K0 937 084 H    HW: 5K0 937 084 H
   Component: BCM PQ35 B    021 0064
   Revision: BA021001
   Coding: 08180E3A882DE1C0400800C0340000E44B700088437D0162648087200041
   VCID: 372B28B44F4789B3A21-8062
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 18121  26  0512
   Coding: 009795
   Component: RLS 221111 05  54  0403
   Coding: 0230AD
   Component: Innenraumuebe  004 0611
                    Fault Status: 00101010
                    Fault Frequency: 40
                    Reset counter: 172
                    Mileage: 145201 km
                    Date: 2014.11.01
                    Time: 11:02:53
                    Voltage: 14.50 V
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 1K9 919 475 A    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0004
   Revision: --------    Serial number: 12501132700674
   Coding: 108103
   VCID: 392F2E8C79539FC3545-806C
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    013 0613
   Serial number: 003G6RA6BBBF
   Coding: 00003537
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 323D19A0A4A56C9B95F-8066
   Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME77110667ZZZS
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME33060667ZZZP
   Serial number: 3511HSME60156029ZZZA
   Serial number: 3521HSME105E5F29ZZZX
   Part No SW: 5K0 953 507 AE    HW: 5K0 953 549
   Revision: --------    Serial number:  90440KIC000JD
   Coding: 5880140000
   Shop #: WSC 00066 000 00184
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 73B3DCA41B3F25935E9-8026
   Part No SW: 5K0 920 972 A    HW: 5K0 920 972 A
   Component: KOMBI         H33 0318
   Revision: X0033006    Serial number:
   Coding: 470B00
   ASAM Dataset: EV_KombiUDSMM9RM10 A04305
   ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
   VCID: 2E050DD0B09D487BF17-807A
   Part No SW: 7N0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway H43 1623
   Revision:   H43       Serial number: 13011201280995
   Coding: 352003
   VCID: 3B233484736FADD3469-806E
   Part No SW: 5K0 953 234     HW: 5K0 920 972 A
   Component: IMMO          H33 0318
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
   VCID: 6A8DC1C04CF5E45BEDF-803E
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0502
   Revision: 12110009    Serial number: 0003609947
   Coding: 0202B4
   Shop #: WSC 01383 790 50316
   VCID: 1C61D718D621CAEBAF3-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  007 1509
   Serial number: 00000006271480
   Coding: 000290
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 70     3301
   Revision: 00H22000
   VCID: 353722BC594B7BA3B0D-8060
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0502
   Revision: 14110009    Serial number: 0003765056
   Coding: 0203B4
   VCID: 1D67DA1CCD3BC3E358D-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  007 1509
   Serial number: 00000006257289
   Coding: 000290
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: Radio RCD310  042 0082
   Revision: 00000001    Serial number: VWZ1Z2L3273594
   Coding: 05000400040007
   VCID: 72BDD9A064A52C9B55F-8026
   Component: Batt.regelung H43 1623
   Coding: 030F1859
   VCID: 71BFD6AC61A31783AC5-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900858770
   Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661185354
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 2615F5F0986D003B097-8072
End----------(Elapsed Time: 01:29, VBatt start/end: 14.3V/14.4V)-----------
dulux72
C?ID=336242
Having only just gone through this myself its mostly to be the injector
Word of warning they're not cheaper and once you've done one you'll probably end up having to replace them all in a short space of time.
Make sure you code the new injectors to the ECU and prime the fuel pump for 30 seconds before trying to restart the car as they don't like being run dry
invernesspl
C?ID=345478
Thanks, and you aren't wrong! £340 each injector, and that's with a good trade discount at TPS. :(
