Redirect Fail!
Kubelwagen
Verified VCDS-Lite User
6e3fe708=cb3db0f9=07ff1990=lchahh=5aa5
I'm working on a 2003 A4 1.8 AMB and getting the Redir Fail! for the engine controller. I believe the car is completely stock so this doesn't make any sense to me. Pretty sure the label file that should be loading is 06B-909-518-AMB.lbl. I did verify that this file is present in the label directory of the program. Thank you.
Tuesday, 24 February 2015, 08:18:14:52250
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56,57,65,67,69,75,76,77
Address 01: Engine       Labels: Redir Fail!
   Controller: 8E0 909 518 AF
   Component: 1.8L R4/5VT     G   0002
   Coding: 0016501
   Shop #: WSC 63351
   VCID: 749B93C957A3
16804 -  Catalyst System; Bank 1: Efficiency Below Threshold
            P0420 - 002 -  Lower Limit Exceeded - Intermittent
Address 03: ABS Brakes       Labels: 8E0-614-517.LBL
   Controller: 8E0 614 517 G
   Component: ABS/ESP front       2328
   Coding: 04275
   Shop #: WSC 06435
   VCID: 2C2B4BA9CF13
Address 08: Auto HVAC       Labels: 8E0-820-043.LBL
   Controller: 8E0 820 043 AC
   Component:   A4 Klimaautomat   1219
   Coding: 00000
   Shop #: WSC 63351
   VCID: 62B7E591FD57
01841 -  Potentiometer/Actuator for Temperature Flap; Left (G220)
            30-10 -  Open or Short to Plus - Intermittent
01274 -  Air Flow Flap Positioning Motor (V71)
            41-00 -  Blocked or No Voltage
01794 -  Control Module - Incorrect Chassis (VIN) Number
            35-00 -   -
Address 09: Cent. Elect.       Labels: 8E0-907-279-8E2.LBL
   Controller: 8E0 907 279 E
   Component: int. Lastmodul  USA 0305
   Coding: 00013
   Shop #: WSC 63351
   VCID: 341B53C91723
Address 15: Airbags       Labels: 8E0-959-655-84.LBL
   Controller: 8E0 959 655 C
   Component: Airbag 8.4EP        2000
   Coding: 0010607
   Shop #: WSC 63351
   VCID: 370164C50655
Address 16: Steering wheel       Labels: 8E0-953-549.LBL
   Controller: 8E0 953 549 L
   Component: Lenksáulenmodul     0308
   Coding: 00041
   Shop #: WSC 63351
   VCID: 3C0B7BE93F73
Address 17: Instruments       Labels: 8E0-920-9xx-8E2.LBL
   Controller: 8E0 920 950 L
   Component: KOMBI+WEGFAHRS. RB4 D35
   Coding: 02200
   Shop #: WSC 19506
   VCID: 321755D1ED37
   WAUJC68E33A211722     AUZ6Z0B0269715
00562 -  Sensor for Oil Level/Temperature (G266)
            27-10 -  Implausible Signal - Intermittent
01304 -  Radio
            49-00 -  No Communications
Address 45: Inter. Monitor       Labels: 8E0-951-177.LBL
   Controller: 8E0 951 177
   Component: Innenraumueberw.   0604
   Coding: 00001
   VCID: EBA908B58A9D
Address 46: Central Conv.       Labels: 8E0-959-433-MAX.LBL
   Controller: 8E0 959 433 BB
   Component: Komfortgerát T7B    1311
   Coding: 11788
   Shop #: WSC 63351
   VCID: 729795D12DB7
01370 -  Alarm triggered by Interior Monitoring
            35-00 -   -
00962 -  Alarm via. Tilt Sensor
            35-00 -   -
01374 -  Alarm triggered by Terminal 15
            35-00 -   -
01371 -  Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -   -
Address 55: Xenon Range       Labels: 4Z7-907-357.LBL
   Controller: 4Z7 907 357
   Component: dynamische LWR       D08
   Coding: 00060
   Shop #: WSC 63351
   VCID: 047BC3090703
End   --------------------------------------------------------------------------------------------------
Weird. It a cursory look a the VCDS-Lite Label folder also makes me think it should load 06B-909-518-AMB.lbl for your ECU. 8E-01.lbl tells it to and the file does exist.
Try renaming 06B-909-518-AMB.lbl to 8E0-909-518-AF.lbl and let us know what happens.
Kubelwagen
That worked. It loaded the new label file and the measuring blocks now have correct labels. Thank you. :thumbs:
After noticing that the other controllers had label files that matched the controller numbers exactly, I wondered if renaming that file to the engine controller would work, but I don't have a great deal of experience with the program so I was chicken to try it.
Thanks again.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
I believe this bug was fixed in newer versions, likely not for VCDS-Lite though. From my vague recollection it boils down to the redirected file name to be too long.
pachanga_22
Stuart, FL, USA
C?ID=242704
Having the same issue with a different engine. Have a TDI, the controller where the redirect fails is "038 906 012 GN"
Well, the work-around for that is easy enough: Just rename the relevant file to your ECM's exact part number. In other words 038-906-012-AGR.LBL becomes 038-906-012-GN.LBL
william_b_noble
C?ID=282280
ok, so I am now confused, different car, but the same Redirect Fail - any hints as to what to do?
I licensed VCDS Lite so I could look at the data for my daughter's Audi TT Quattro, 2001. When I try to use the measuring blocks capability, I get Label File: Redir Fail, as shown below. please see captured autoscan fragment below. What am I doing wrong? without labels, the software guesses at measuring blocks, but that doesn't really help much, I just want to look at the two lambda sensors and verify that the cat is bad, or something else is bad - and I can't find any info on which block is which sensor.
Any hints? ideas?? is there a file for the TT Quattro somewhere that would help me?
Controller: 8N0 906 018 T
Component: 1.8L R4/5VT G 0003
Coding: 06610
Shop #: WSC 01236
VCID: 42F71E775D97
16806 - Main Catalyst; Bank 1: Efficiency Below Threshold
P0422 - 35-10 - - - Intermittent
Readiness: 0010 0000
Hmm... Looks like the correct file for that engine is 06A-906-032-AMU.lbl. What's puzzling is that the an appropriate redirect exists in 8N-01.lbl.
Try renaming 06A-906-032-AMU.lbl to 8N0-906-018-T.lbl.
william_b_noble
C?ID=282280
ok, I made a copy of the file and named it as you suggested. I'll have to wait until my daughter brings her car over again to find out if it works or not. meanwhile, how did you know what file was supposed to go with that specific car? and would one draw any inference from my controller ID being so different - I know the controller has not been changed since she's owned the car (e.g. since 2004 or so) and I doubt it was changed early in its life.
Thanks - sometimes I feel like I'm stuck in a Grateful Dead song .... "what a long strange trip it's been".
I guess, if the LBL file is correct, I'll want to look at blocks 41, 43, and 46.
