P2542
thanosxx
Greece
C?ID=298538
Hello.There is a a fault code P2542.Do you know about possible solution?
Thursday,06,August,2020,12:39:49:57658
VCDS Version: 20.4.2.0  HEX-V2 CB: 0.4513.4
VIN: WVWZZZ1KZ4P065890   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52
VIN: WVWZZZ1KZ4P065890   Mileage: 370980km-230516miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 H    HW: Hardware No
   Component: MED 9.5.10       00 5634
   Revision: 00000000    Serial number: VWZ7Z0D9552601
   Coding: 0000071
   Shop #: WSC 00028 028 00001
   VCID: 280AF2789EFD08EB3A3-807C
18974 - Low Pressure Fuel Sensor (G410)
            P2542 - 001 - Short to Plus - Intermittent
Readiness: 1010 0001
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 N
   Component: ASR FRONT MK70      0103
   Coding: 0017025
   VCID: 3D24332C617FBD43795-8068
   Part No: 1K0 820 047 CR
   Component: Climatic PQ35   081 0404
   VCID: 76B6EC0004C92E1B78F-8022
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000623857
   Coding: 008D0F0600041800001400001400000000
   VCID: 3FD849246B73AF536B9-806A
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
   Component: 0L AIRBAG VW8   022 0500
   Revision: 04022000    Serial number: 0033FD0B0RF1
   Coding: 0012364
   VCID: 2A0E087080F13AFB2C7-807E
   Subsystem 1 - Serial number: 6332MSME72256402
   Subsystem 2 - Serial number: 6342MSME703E5102
   Subsystem 3 - Serial number: 6351HSME39452202
   Subsystem 4 - Serial number: 6361HSME1E582202
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 012 0030
   VCID: 6FB8D9647B931FD3BB9-803A
   Part No: 1K0 920 850 P
   Component: KOMBIINSTRUMENT VDD 3556
   Coding: 0001101
   Shop #: WSC 80093 222 69422
   VCID: 3432160852357C0B86B-8060
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 210010431540B6
   Coding: 3D0F0300070000
   VCID: 2708F14493E30793339-8072
   Component: IMMO                3556
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0117
   Coding: 0000052
   VCID: 303A1A18A62D402BE23-8064
   Part No: 1K1 909 144 F
   Component: EPS_ZFLS Kl.0       1301
   VCID: 2E060460BC1956DBF0F-807A
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 B
   Component:    KSG              0201
   Coding: 00E802087F2D8404084A0100
   VCID: 2F381964BB135FD3FB9-807A
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 313C1F1CAD274923EDD-8064
End----------(Elapsed Time: 00:45, VBatt start/end: 12.5V/12.5V)-----------
What have you done to investigate this electrical fault so far?
thanosxx
Greece
C?ID=298538
The car loss power with this problem? Is the problem the G410 sensor?
Dr Sheldon
Windsor UK
C?ID=334979
Im guessing this sensor has 3 wires. Is that correct ?
What is the voltage on all three wires to at least decimal points on each wire. An Engine code will help me to help you.
Do that test on the wires at Ignition on, then idle and again at wide open throttle.
Do you have Fuel pressure measurement equipment ?
Jef
HQ
Intermittent... so if you clear the code out does it keep coming back? Did you maybe unplug the G410 sensor while the ignition was turned on at some point?
thanosxx
Greece
C?ID=298538
The engine code is BKG If I clear the code the engie work normal but I let it with engine running in idle and after of half an hour or 45 minutes I have again this fault code
also I check the wiring in terminal 1and 3 I have 4,95volt(unplug ) 1and 2 terminal I have 0,5volt with ignition on(plug) and when engine is idle I have 2,90volt also when I unplug the g410 I have the fault code18971 P2539 open circuit
Jef
HQ
I would suggest you verify all the electrical paths (wiring harness, terminals, ect) for the G410 are 100% to factory design..... wiggle test things. If that checks out good, I'd replace the G410 sensor with a new unit FROM THE VW DEALER. You want to avoid this hassle.
Dr Sheldon
Windsor UK
C?ID=334979
Goes against the description of the DTC but the LP &HP pumps are a common failure on these. Also the LP Pump Module
Time to scope the wiring, signals and measure fuel pressure at the point of failure to ascertain between Symptom and Root Cause of the fault.
The ECU cannot measure Fuel pressure, or get a second opinion. It IS at the mercy of the Sensor or Messenger which is another word for sensor.
It will Shoot the messenger with no Mercy !!!
thanosxx
Greece
C?ID=298538
I change the sensor G410 but when the engine work in idle without problem (about half an hour) the engine stop from G28 crankshaft sensor This problem I found before some days in this car but now I order new sensor and I will test tommorow
Maybe some insight related too for lift pump and incorrect assignment in data input of diagnostic stack for DTC by OEM?
Multiple boo boos, however, did you JPPSG and use a decade box to qualify if as aforementioned?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
PartVersion
mot_01.stt03C906056H @ 7375.2 to 03C997057C via 03C997057C__7330.sgo
03C997057C_7330
mot_01.stt03C906056BM @ 7375.2 to 03C997057C via 03C997057C__7330.sgo
03C997056J @ 7375.2 to 03C997057C via 03C997057C__7330.sgo
18975/P2543 - Low Pressure Fuel Sensor (G410)
Possible Symptoms
  • MIL on
  • Driveablity issues
Possible Causes
  • Restriction in fuel line system
  • Failed Lift Pump in Fuel Tank
Possible Solutions
  • Replace restricted fuel lines
  • Replace restricted fuel filter
  • Replace failed Lift Pump
Special Notes
  • When found on FSI engines, MVB 106.2 shows the duty cycle of the lift pump, this value should be below 60% at idle. The higher the number, the more the lift pump has to run to maintain fuel pressure to the High Pressure Fuel Pump.
thanosxx
Greece
C?ID=298538
I change the G410 and G28 the engine work but after of a half hour about with engine in idle the P2542 appear again without problem
thanosxx
Greece
C?ID=298538
Finally I take out thelow pressure fuel pump for inspection I check the fuel pressure,install the same fuel pump and the problem dissapear
