Audi C7 S7 4.0t fuel pump codes, car died when it came to a stop. What tests?
infinkc
New Member
HC460225 (2nd hand?)
Was driving, then the came to a stop, car sputtered and died. I tried to restart and it sounded like it wanted to, but didnt. Got towed home. Inspected turbos as it has the same failure mode and pulled the codes.
When i open the driver door i hear the pump prime.
Tried to start the car and it fired right up.
Checked measuring blocks, both low and high pressure requested match actual.
I am scared to drive the car as i know it might die on me again. Are there any other checks that i can do to see if the pump is bad? the fuel controller bad? I only saw options for draining the tank or releasing the rail pressure.
thanks for any help!
Sunday,02,August,2020,20:44:58:20827
VCDS Version: Release 20.4.1 (x64) Running on Windows 7 x64
                Address 01: Engine       Labels: 06E-907-551-CGW.clb
Control Module Part Number: 4G0 906 014 E    HW: 4H0 906 014
  Component and/or Version: 4.0l V8TFSI / H62 0006
           Software Coding: 1A2500326546000E1000
            Work Shop Code: WSC 30687 002 1048576
              ASAM Dataset: EV_ECM40TFS0114G0906014E 001004 (AU57)
                       ROD: EV_ECM40TFS0114G0906014E.rod
                      VCID: 244C6A522F8AA4A64F-8070
8 Faults Found:
10061 - Fuel Pump
          P3043 00 [044] - Mechanical Malfunction
                    Fault Frequency: 134
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:21:17
                    Engine speed: 767.00 /min
                    Normed load value: 8.6 %
                    Coolant temperature: 95 °C
                    Intake air temperature: 70 °C
                    Voltage terminal 30: 13.428 V
                    Fuel pump: specified value: 72.218 %
                    Low fuel pressure: specified value: 596.7 kPa
                    Fuel temperature: 88.5 °C
                    Adaptation of Fuel Pump (FP): -94.9 kPa
                    High fuel pressure: specified value: 3.6580 MPa
2636 - Low Pressure Fuel regulation
          P310B 00 [101] - Fuel Pressure Outside Specification
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:21:29
                    Engine speed: 773.50 /min
                    Coolant temperature: 96 °C
                    Voltage terminal 30: 13.617 V
                    Engine status: COENG_RUNNING
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [101] - -
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:21
                    Engine speed: 632.00 /min
                    Normed load value: 16.1 %
                    Intake air temperature: 71 °C
                    Voltage terminal 30: 13.052 V
                    Unlearning counter according OBD: 77
10595 - Cylinder 5
          P0305 00 [101] - Misfire Detected
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:30
                    Engine speed: 736.00 /min
                    Normed load value: 15.7 %
                    Voltage terminal 30: 13.523 V
10598 - Cylinder 8
          P0308 00 [101] - Misfire Detected
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:46
                    Engine speed: 657.00 /min
                    Normed load value: 20.4 %
                    Vehicle speed: 1 km/h
                    Voltage terminal 30: 13.193 V
10596 - Cylinder 6
          P0306 00 [101] - Misfire Detected
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:21
                    Voltage terminal 30: 13.452 V
10597 - Cylinder 7
          P0307 00 [101] - Misfire Detected
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:21
10205 - Cylinder Disabling
          P130A 00 [032] - -
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:46
                    Normed load value: 20.0 %
PetrolDave
Westbury, UK
C?ID=1423
Please post the full unedited VCDS Auto-Scan, it makes it easier to comment on the way forward - see my sig for a link to a How-To
infinkc
New Member
unfortunately i cleared the full scan and didnt save it as it was a few days before i cleared it prior to the issue because my readiness was not setting for my emissions test and had a fault for my rear glass sensor that i fixed, it was only the engine codes and something for the sunroof module and radio. The only thing i have is the copy of the engine scan
8 Faults Found:
10061 - Fuel Pump
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:21:17
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:21:29
          P0300 00 [101] - -
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:21
10595 - Cylinder 5
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:30
10598 - Cylinder 8
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:46
10596 - Cylinder 6
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:21
10597 - Cylinder 7
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:21
          P130A 00 [032] - -
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:22:46
Viking
C?ID=151455
Run a new scan and post that please...
Viking
C?ID=151455
Well, it shows information that may help with the answer to your question. If you want assistance, a full Autoscan is required.
PetrolDave
Westbury, UK
C?ID=1423
there are no codes, so not sure the reason for it?
The scan gives information on the hardware and software versions of the modules in your car which can make a difference to what suggestions we offer as not all versions have the some options for coding and adaption channels.
Fuel filter?
Fuel level?
Contamination in tank clogging the pickup intermittently?
If you've ever run an Auto-Scan, it will have been archived in the Scans sub-folder whether you explicitly saved it or not. An Auto-Scan really does provide a lot of context.
infinkc
New Member
here is the scan from yesterday
Tuesday,04,August,2020,20:09:38:20827
VCDS Version: 20.4.1.0 (x64)
VIN: WAUW2AFC1EN141600   License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
          46 47 52 53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90 A9 BA
VIN: WAUW2AFC1EN141600   Mileage: 161769km-100518miles
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 E    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0006
   Revision: NCH62---
   Shop #: WSC 30687 002 1048576
17876 - Exhaust Pressure Control Valve 2
          P049F 00 [036] - Malfunction
                    Mileage: 161769 km
                    Date: 2020.08.04
                    Time: 19:59:10
                    Coolant temperature: 50 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 12.038 V
                    Engine status: COENG_READY
Readiness: 1110 1101
   Part No SW: 4G9 927 156 C    HW: 0B5 927 156 K
   Component: 0B5 40TFSINAR H02 0006
   Revision: --H02---
   Coding: 000001
   ROD: EV_TCMDL501021.rod
   VCID: 356AA71694102D2EE8-8060
   Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
   Coding: 65B65703A66DEAC04B00
   VCID: 3B7EB12EB234FB5E1E-806E
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:44:26
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 08
                    Uz: 73
0606 - Tire Pressure Warning
          C102D 00 [009] - -
                    Fault Frequency: 21
                    Reset counter: 127
                    Mileage: 161718 km
                    Date: 2020.07.31
                    Time: 15:48:49
                    VzRef: 29
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2E
                    Uz: B6
0631 - Tire Pressure Warning
          C102D 00 [009] - -
                    Fault Frequency: 21
                    Reset counter: 127
                    Mileage: 161698 km
                    Date: 2020.07.31
                    Time: 15:31:25
                    VzRef: 4D
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 32
                    Uz: B8
0732 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:42:12
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 08
                    Uz: 7E
   Part No SW: 4H0 907 064 ER    HW: 4H0 907 064 ER
   Component: BCM2 2.0      H36 0521
   Coding: 0D8A2046000000000000
   VCID: 7DFA7F36E4A0356E60-8028
   Serial number: 0214000044243005
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Fault Frequency: 10
                    Reset counter: 167
                    Mileage: 161511 km
                    Date: 2020.07.30
                    Time: 14:11:37
   Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
   Component: KLIMA 4 ZONEN H14 0093
   Serial number: 26031400040364
   Coding: 680320784D
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6AD0446A8D2EB2D6B5-803E
   Revision: 11012002    Serial number: 00000001721222
   Coding: 0D072091073E9FE2A90000C7A0003820CF9CD208A2090221800308457B00
   VCID: 6FE6557EBECC57FEE2-803A
   Component: WWS57X 140309  H37 0080
   Serial number:         140312232226
   Coding: 0045F7
   Serial number: 22397827
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 21 03 2014  00000676
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RAPAA03
   Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H02 0002
   Serial number: 00000000001403073020
   Subsystem 6 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H02 0002
   Serial number: 00000000001312100141
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA107529000006283780
   Coding: 020300
   Serial number: 17188C17000000000001
   Subsystem 9 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A32 LED Mod2L  H02 0002
   Serial number: 00000000001403101124
   Subsystem 10 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A28 LED Mod2R  H02 0002
   Serial number: 00000000001403101679
   Revision: 11001001    Serial number: 61031408502205
   Coding: A8E909
   VCID: 71E25306A0F8410EF4-8024
13635840 - Supply voltage
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:03
          U1400 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:03
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7601010101
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   ROD: EV_AdaptCruisContrAU57X_002.rod
   VCID: 28547E6253A240C663-807C
16384 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:28
                    Control Module temperature: 45 °C
                    Voltage terminal 15: 8.044 V
                    Velocity_vehicle_reference: -0.02 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.01 m/s²
16640 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 167
                    Mileage: 161511 km
                    Date: 2020.07.30
                    Time: 14:13:40
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 9.043 V
                    Velocity_vehicle_reference: -0.01 m/s
105984 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:44:26
                    Voltage terminal 15: 9.119 V
140288 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:44:26
144896 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:14
                    Control Module temperature: 44 °C
                    Voltage terminal 15: 9.340 V
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8003ZLZW
   Coding: 303145313131303030324A55304C34473853
   VCID: 336E990E9A64331EC6-8066
   Component: BF-Gewichtss.  H15 0046
   Serial number: 6940000Y1400012W0A0H
   Serial number: 3575HRB405R2DE2S7P5Z
   Serial number: 3585HRB405R2ATKK8P4F
   Serial number: 3515JRB400250UUENHO5
   Serial number: 3525JRB400450UJ8GPOZ
   Serial number: 3554VRB400K50UJCS1F5
   Serial number: 3564VRB400A50UJCAOI4
9483264 - Seat Occupied Recognition
          B10B4 00 [008] - Function Restriction due to Undervoltage
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:54
   Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
   Revision: --------    Serial number: 90372NCK0000O
   Coding: 0000FC
   VCID: 3776AD1E861CDF3EFA-8062
   Serial number: 11 01 2014  11334523
   Part No SW: 4G8 920 985 H    HW: 4G8 920 985 H
   Component: TBenUsaAccNv  H58 0622
   Revision: 29460237    Serial number: 658170314596013
   Coding: 0BCF01079F53D705020300
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3C7CB232B73AFC6617-8068
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Revision: --------    Serial number: 00000001327261
   Coding: 00E1034800
   VCID: 72E05C0AA5FE7A160D-8026
   Serial number: 3096192803
          U140B 00 [008] - -
                    Fault Frequency: 7
                    Reset counter: 167
                    Mileage: 161511 km
                    Date: 2020.07.30
                    Time: 14:10:55
                    Voltage terminal 30: 9.9 V
                    Voltage terminal 15: 10.0 V
                    Control Module temperature: 36 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 1
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0013
   Serial number: 001603140001159
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   VCID: 27567D5E5EBC4FBE6A-8072
0405 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 60
                    Mileage: 153660 km
                    Date: 2019.06.07
                    Time: 13:34:01
0377 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 60
                    Mileage: 153660 km
                    Date: 2019.06.07
                    Time: 13:34:01
0002 - Supply voltage
                    Reset counter: 60
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:41:10
   Part No SW: 4G0 919 158 M    HW: 4G0 919 158 M
   Component: KLIMA FOND    H08 0093
   Serial number: 25031400040477
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: 3972AB26B808C94E0C-806C
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E58887A71461EF6A9-807A
   Revision: AA000000    Serial number: 00000094141570
   Coding: 00581B0000002001000001010101102030303232203232
   VCID: 77F66D1EC69C1F3E3A-8022
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7E00Y0DJ
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3776AD1E8E1CDF3EFA-8062
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH05 0060
   Revision: 00H05000    Serial number: 6PZ 010 287-08
   Coding: 0000003
   VCID: 3668A01A41162636E1-8062
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H05 0060
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F19.03.1400H05000AMS14452ÿ
   Subsystem 4 - Serial number: S14452ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F5F025E00628002000413
   VCID: 458AD7D6CCF0BDAE78-8010
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0019404066
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 32609C0A657E3A16CD-8066
   Revision: 00002001    Serial number: 0330938950
   Coding: 0126063A20FAF08580B00A8002030D000000000000000000000000000000
   Component: GTO BF  H01 0081
   Serial number: 00000000000000210265
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO28155926
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00006388426
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA107669000006533417
   Subsystem 6 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93189470
01403 - Glass-Break Sensors; Rear
                    Fault Status: 00101011
                    Fault Frequency: 43
                    Reset counter: 164
                    Mileage: 161250 km
                    Date: 2020.07.05
                    Time: 12:15:28
03128 - Switch 1 for Sunroof
                    Fault Status: 00101100
                    Reset counter: 162
                    Mileage: 161420 km
                    Date: 2020.07.20
                    Time: 10:51:36
00204 - Sunroof Button (E325)
                    Reset counter: 162
                    Mileage: 161420 km
                    Date: 2020.07.20
                    Time: 10:51:36
03700 - Control Module for Rear Spoiler Positioning
                    Reset counter: 167
                    Mileage: 161511 km
                    Date: 2020.07.30
                    Time: 14:11:33
03394 - Play protection for rear spoiler adjustment active
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.08.04
                    Time: 19:35:14
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000007416
   Coding: 030000
   VCID: 1C3C52B21FFA9C66F7-8048
00529 - Engine Speed Signal Missing
                    Fault Status: 00110000
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:23:47
03994 - Noise reduction function limitation
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 17:23:47
                    Bin. Bits: 00000001
   Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
   Component: TSG BF        H04 0507
   Coding: 011F5F025E00628002000402
   VCID: 448CCAD2C7CA84A66F-8010
   Component: EPB-4         H03 0015
   Revision: --------    Serial number: 00000001009571
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D5A8F767C4065EE90-8078
10554390 - Supply voltage
                    Reset counter: 127
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:25
                    Voltage terminal 30: 8.9 V
                    Internal Fault ID: 40
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Auto Adjust: not active
   Serial number: 140328-0002-029
   Coding: 12236F601002A400
   ROD: EV_HeadlRegulBasic.rod
   Component: Radio U SIRIU H60 0133
   Revision: AB001007    Serial number: 156C%0E7985521
   Coding: 020007010000000001
   VCID: 244C6A52278AA4A64F-8070
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:33
                    Voltage: 9.10 V
   Part No SW: 4G0 035 746 F    HW: 4G0 035 746 E
   Component: H-BNT-NA      H41 0757
   Revision: --------    Serial number: 194C%0E7607393
   Coding: 0A0200040203F9EF7D12CB3E00000003100001000000000000
   VCID: 2A50846A45AE72D675-807E
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD0042XQ7
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Serial number: 90349NCL000AR
   Component: CD-Database  5571
   Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
   Coding: 010F1F024000628002000002
   VCID: 4796DDDEF6FCAFBE8A-8012
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0140657
   Coding: 0206000001010100000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007.rod
   VCID: 2C5C8272475A6CE687-8078
9617697 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 167
                    Mileage: 161511 km
                    Date: 2020.07.29
                    Time: 07:57:52
                    Voltage terminal 30: 7.0 V
   Part No SW: 4G8 959 107 R    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0043
   Revision: 12013001    Serial number: 063401420
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 448CCAD2CFCA84A66F-8010
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2648705A59B656B651-8072
0232 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:46
                    Outside air temperature: -32.0 °C
                    Voltage terminal 15: 8.5 V
                    Control Module temperature: 38.0 °C
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7601010101
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   ROD: EV_AdaptCruisContr2AU57X_002.rod
          U1400 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:28
                    Control Module temperature: 46 °C
                    Voltage terminal 15: 8.068 V
                    Longitudinal_acceleration_vehicle_reference: -0.00 m/s²
          U1400 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:04
                    Voltage terminal 15: 9.152 V
          U1113 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:44:26
                    Voltage terminal 15: 8.939 V
          U1113 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:44:27
                    Voltage terminal 15: 9.234 V
          U1113 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:14
                    Voltage terminal 15: 9.385 V
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000121903147
   Coding: 03C19A1A0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0049 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:58
                    Outside air temperature: 36.0 °C
                    Voltage terminal 15: 9.2 V
                    Control Module temperature: 43.0 °C
0165 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:42:12
                    Voltage terminal 15: 9.5 V
                    Control Module temperature: 41.0 °C
0173 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 167
                    Mileage: 161769 km
                    Date: 2020.07.31
                    Time: 20:43:15
                    Voltage terminal 15: 9.0 V
   Coding: 0066E608031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 316293066078010EB4-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 140305200165
Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H07 0008
   Revision: 00001001    Serial number: 97812003423801
   ASAM Dataset: EV_AEMLearAU64X 002016
   ROD: EV_AEMLearAU64X.rod
0017 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 167
                    Mileage: 161511 km
                    Date: 2020.07.30
                    Time: 14:11:27
1293 - Actuator 2 for Drivetrain Mounts
          C1132 07 [009] - Mechanical Failure
                    Reset counter: 119
                    Mileage: 161248 km
                    Date: 2020.07.04
                    Time: 11:17:19
1294 - Actuator 1 for Drivetrain Mounts
          C1131 07 [009] - Mechanical Failure
                    Reset counter: 119
                    Mileage: 161248 km
                    Date: 2020.07.04
                    Time: 11:17:19
End-------------------------(Elapsed Time: 07:17)--------------------------
You've got low voltage codes with absurdly low voltages in the freeze-frame data all over this car.
Are you sure the fuel pressure issues aren't due to low voltage supply to the fuel pump?
Yes, I can see that the freeze-frames associated with the engine codes you posted at first don't show such low voltages.
If this were my car, pore over the wiring diagrams to see where low pressure pump gets its power and see if there's a potential common point of failure with the modules that have low voltage codes; a point of failure that's not common to the ECU itself.
infinkc
New Member
Low voltage was cause I had the car hazards on for over 4 hours waiting for a tow and then having the car on doing diagnostics. Not to mention multiple tries to start the car. Yes the voltage was ok as shown when the code came up.
