Hello everyone,
Recently I bought VCDS to work on and tweak my new car, a 2012 Audi A6 C7 3.0 TDI. I've been able to enable the Green Menu, but it seems a lot different to me than in the tutorials, in retrospect after some digging I seem to have a 'MMI basic' rather than an MMI 3G+.
Does anyone know how to enable Bluetooth on these? I wasn't able to find a guide or any info anywhere.
Scan, as instructed.
Thursday,30,July,2020,14:44:55:55068
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4526.4
VIN: WAUZZZ4G7DN049646 License Plate: 1-YCE-421
Mileage: 250424km-155606mi Repair Order: 3
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 3B 42 44 46 52 53 5F 62 72
VIN: WAUZZZ4G7DN049646 Mileage: 250424km-155606miles
03-ABS Brakes -- Status: Cannot be reached 0100
04-Steering Angle -- Status: Cannot be reached 0100
Address 01: Engine (J623-CDUD) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 Q HW: 4G0 907 401
Component: 3.0TDI EDC17 H39 0002
Revision: 53H39---
Coding: 12254012040601020000
ASAM Dataset: EV_ECM30TDI0114G0907401Q 001003
ROD: EV_ECM30TDI0114G0907401Q.rod
VCID: 313F102931A42B43EC5-8064
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [039] - -
Mileage: 250424 km
Date: 2020.07.30
Time: 14:43:11
Coolant temperature: 25 °C
Intake air temperature: 29 °C
Voltage terminal 30: 11.720 V
Cruise Control System (CCS): status-Bits 0-7: 4
selected gear-Bits 0-7: 0
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G1 927 156 T HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0007
Revision: --H03---
Coding: 000001
Shop #: WSC 04940 001 00001
ROD: EV_TCMDL501021.rod
VCID: 3E253B15F0FAC43B617-806A
8007 - No Communications with Steering Angle Sender (G85)
U0126 00 [039] - -
[Lost Communication With Steering Wheel Angle Sensor Control Module]
Reset counter: 40
Mileage: 250424 km
Date: 2020.07.30
Time: 14:43:11
Engine speed: 0 /min
Transmission input speed: 0 /min
Transmission output speed: 0 /min
Engine torque: -64 Nm
Transmission fluid temperature: 27 °C
Accelerator position: 0.0 %
Clutch status: Beide Kupplungen offen
Voltage terminal 30: 11.600 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.915 V
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 27A68701E465E180CB00
VCID: 36352335D8CA0C7BB97-8062
Part No SW: 4H0 907 064 FG HW: 4H0 907 064 CG
Component: BCM2 2.0 H32 0560
Coding: 01A93046000000000000
Shop #: WSC 02541 002 1048576
VCID: 73B3DA218BB859535E9-8026
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AB HW: 4G0 820 043 AB
Component: KLIMA 2 ZONEN H11 0076
Serial number: 17081200111212
Coding: 3602000821
ASAM Dataset: EV_AirCondiBasisUDS 002040
VCID: 5F9BA69117B0ED330A1-800A
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CA HW: 4H0 907 063 A
Component: BCM1 2.0 H12 0130
Revision: 12012002 Serial number: 00000001396446
Coding: 690000108034A7E00105008000005F5F0F9CC60826080201000004406001
VCID: 698FB849D9749383E45-803C
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 120720 H36 0080
Serial number: 120801172522
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 20502262
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
Component: E1 - LDS H07 0044
Serial number: 09 08 2012 00000384
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: EF480446000000000001
Reset counter: 99
Mileage: 250424 km
Date: 2020.07.30
Time: 14:43:00
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG009WBVZ
Coding: 30323436313330303333554A304C34473053
Serial number: 3575HRB40571G1DM9GGD
Serial number: 3585HRB405N1D5MK6PJ4
Serial number: 3515JRB405V1DKAS4GE2
Serial number: 3525JRB405N1AP6088ND
Serial number: 3554VRB405L1GCDMEHIE
Serial number: 3564VRB400G4UIV8RP80
1049600 - Databus
U1121 00 [137] - Missing Message
[CAN: 0x084 ESP_06 Timeout]
Reset counter: 99
Mileage: 250424 km
Date: 2020.07.30
Time: 14:43:10
1050112 - Databus
[CAN: 0x086 LWI_01 Timeout]
Reset counter: 99
Mileage: 250424 km
Date: 2020.07.30
Time: 14:43:10
Part No SW: 4H0 953 568 E HW: 4H0 953 568 E
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372KLB00009
Coding: 000011
Shop #: WSC 45816 000 1048576
VCID: 35372439C54C0763B0D-8060
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H09 0009
Serial number: 15 06 2012 33245472
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 900 J HW: 4G8 920 900 J
Component: MDieRdw H34 0306
Revision: 26450232 Serial number: 658100812592001
Coding: 13021100034100080D0000
ASAM Dataset: EV_RBC7KMID 004045
ROD: EV_RBC7KMID.rod
Part No SW: 4G5 907 468 B HW: 4G5 907 468
Component: J533--Gateway H11 0035
Revision: -------- Serial number: 00000000635891
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001016
VCID: 3431193DCEB61E6B873-8060
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790837701
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 080612000000000003A2
4230 - No Communications with Steering Angle Sender (G85)
U0126 00 [009] - -
Reset counter: 99
Mileage: 250424 km
Date: 2020.07.30
Time: 14:43:09
Voltage terminal 30: 11.5 V
Voltage terminal 15: 11.6 V
Control Module temperature: 41 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
4228 - No Communication with ABS Brake Control Module
U0121 00 [009] - -
Reset counter: 99
Mileage: 250424 km
Date: 2020.07.30
Time: 14:43:09
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H02 0053
Revision: -------- Serial number: EJ1BPA7200ZVB.
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
VCID: 33331A21CBB819539E9-8066
Component: TSG FA H03 0506
Coding: 011C16004000620002080002
VCID: 47CB5EF1AFA085F3D21-8012
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0030761498
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D1F2534A2105B95F-8066
3158276 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Ausfall Botschaft "PDU_LWI_01"]
Reset counter: 99
Mileage: 250424 km
Date: 2020.07.30
Time: 14:43:09
Write only channel
Revision: 00002001 Serial number: 0180941091
Coding: 0100062020B90000832009040001040F0000000000000000000000000000
Reset counter: 99
Mileage: 250424 km
Date: 2020.07.30
Time: 14:43:07
Component: TSG BF H03 0506
VCID: 46D553F5A8AA9CFB297-8012
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000433749
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B03024113884193D69-807E
Part No SW: 4G0 035 180 F HW: 4G0 035 180 E
Component: RMC H53 0775
Coding: 0100010001411947002B040001010000000000
VCID: 221DEF6564C280DB65F-8076
Subsystem 1 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Serial number: 9464H/0C2544673
Subsystem 2 - Part No SW: 4G1 919 610 B HW: 4G1 919 610 B
Component: E380 BDT C7 H11 0204
Serial number: 90349LHE000GI
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0506
Coding: 010814004000620002080002
VCID: 49CF58C9B9B47383C45-801C
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0506
End----(Elapsed Time: 01:45, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
