Enabling Bluetooth Audi A6 C7 2012 RCM 'MMI Basic'
Renier
Belgium
C?ID=411980
Hello everyone,
Recently I bought VCDS to work on and tweak my new car, a 2012 Audi A6 C7 3.0 TDI. I've been able to enable the Green Menu, but it seems a lot different to me than in the tutorials, in retrospect after some digging I seem to have a 'MMI basic' rather than an MMI 3G+.
Does anyone know how to enable Bluetooth on these? I wasn't able to find a guide or any info anywhere.
Thursday,30,July,2020,14:44:55:55068
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4526.4
VIN: WAUZZZ4G7DN049646   License Plate: 1-YCE-421
Mileage: 250424km-155606mi   Repair Order: 3
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 3B 42 44 46 52 53 5F 62 72
VIN: WAUZZZ4G7DN049646   Mileage: 250424km-155606miles
03-ABS Brakes -- Status: Cannot be reached 0100
04-Steering Angle -- Status: Cannot be reached 0100
Address 01: Engine (J623-CDUD)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 Q    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H39 0002
   Revision: 53H39---
   Coding: 12254012040601020000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907401Q 001003
   ROD: EV_ECM30TDI0114G0907401Q.rod
   VCID: 313F102931A42B43EC5-8064
5608 - No Communications with Steering Angle Sender (G85)
          U0126 00 [039] - -
                    Mileage: 250424 km
                    Date: 2020.07.30
                    Time: 14:43:11
                    Engine speed: 0.00 /min
                    Coolant temperature: 25 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 11.720 V
                    Cruise Control System (CCS): status-Bits 0-7: 4
                    selected gear-Bits 0-7: 0
   Part No SW: 4G1 927 156 T    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0007
   Revision: --H03---
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 3E253B15F0FAC43B617-806A
8007 - No Communications with Steering Angle Sender (G85)
          U0126 00 [039] - -
          [Lost Communication With Steering Wheel Angle Sensor Control Module]
                    Mileage: 250424 km
                    Date: 2020.07.30
                    Time: 14:43:11
                    Engine speed: 0 /min
                    Transmission input speed: 0 /min
                    Engine torque: -64 Nm
                    Transmission fluid temperature: 27 °C
                    Accelerator position: 0.0 %
                    Clutch status: Beide Kupplungen offen
                    Voltage terminal 30: 11.600 V
                    Voltage_5V_CAN_pressuresensors-Param to DOP: 4.915 V
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 27A68701E465E180CB00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 36352335D8CA0C7BB97-8062
   Part No SW: 4H0 907 064 FG    HW: 4H0 907 064 CG
   Component: BCM2 2.0      H32 0560
   Coding: 01A93046000000000000
   Shop #: WSC 02541 002 1048576
   VCID: 73B3DA218BB859535E9-8026
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 AB    HW: 4G0 820 043 AB
   Component: KLIMA 2 ZONEN H11 0076
   Serial number: 17081200111212
   Coding: 3602000821
   ASAM Dataset: EV_AirCondiBasisUDS 002040
   ROD: EV_AirCondiBasisUDS_002.rod
   VCID: 5F9BA69117B0ED330A1-800A
   Part No SW: 4H0 907 063 CA    HW: 4H0 907 063 A
   Revision: 12012002    Serial number: 00000001396446
   Coding: 690000108034A7E00105008000005F5F0F9CC60826080201000004406001
   VCID: 698FB849D9749383E45-803C
   Component: WWS57X 120720  H36 0080
   Serial number:         120801172522
   Coding: 0045F7
   Serial number: 20502262
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
   Component: E1 - LDS  H07 0044
   Serial number: 09 08 2012  00000384
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: EF480446000000000001
                    Reset counter: 99
                    Mileage: 250424 km
                    Date: 2020.07.30
                    Time: 14:43:00
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG009WBVZ
   Coding: 30323436313330303333554A304C34473053
   Serial number: 3575HRB40571G1DM9GGD
   Serial number: 3585HRB405N1D5MK6PJ4
   Serial number: 3515JRB405V1DKAS4GE2
   Serial number: 3525JRB405N1AP6088ND
   Serial number: 3554VRB405L1GCDMEHIE
   Serial number: 3564VRB400G4UIV8RP80
1049600 - Databus
          U1121 00 [137] - Missing Message
          [CAN: 0x084 ESP_06 Timeout]
                    Reset counter: 99
                    Mileage: 250424 km
                    Date: 2020.07.30
                    Time: 14:43:10
1050112 - Databus
          [CAN: 0x086 LWI_01 Timeout]
                    Reset counter: 99
                    Mileage: 250424 km
                    Date: 2020.07.30
                    Time: 14:43:10
   Part No SW: 4H0 953 568 E    HW: 4H0 953 568 E
   Revision: --------    Serial number: 90372KLB00009
   Coding: 000011
   Shop #: WSC 45816 000 1048576
   VCID: 35372439C54C0763B0D-8060
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0009
   Serial number: 15 06 2012  33245472
   Part No SW: 4G8 920 900 J    HW: 4G8 920 900 J
   Component: MDieRdw       H34 0306
   Revision: 26450232    Serial number: 658100812592001
   Coding: 13021100034100080D0000
   ASAM Dataset: EV_RBC7KMID 004045
   ROD: EV_RBC7KMID.rod
   Part No SW: 4G5 907 468 B    HW: 4G5 907 468
   Component: J533--Gateway H11 0035
   Revision: --------    Serial number: 00000000635891
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001016
   VCID: 3431193DCEB61E6B873-8060
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790837701
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 080612000000000003A2
4230 - No Communications with Steering Angle Sender (G85)
          U0126 00 [009] - -
                    Reset counter: 99
                    Mileage: 250424 km
                    Date: 2020.07.30
                    Time: 14:43:09
                    Voltage terminal 30: 11.5 V
                    Voltage terminal 15: 11.6 V
                    Control Module temperature: 41 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4228 - No Communication with ABS Brake Control Module
          U0121 00 [009] - -
                    Reset counter: 99
                    Mileage: 250424 km
                    Date: 2020.07.30
                    Time: 14:43:09
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H02 0053
   Revision: --------    Serial number: EJ1BPA7200ZVB.
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   VCID: 33331A21CBB819539E9-8066
   Component: TSG FA        H03 0506
   Coding: 011C16004000620002080002
   VCID: 47CB5EF1AFA085F3D21-8012
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0030761498
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1F2534A2105B95F-8066
3158276 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Ausfall Botschaft "PDU_LWI_01"]
                    Reset counter: 99
                    Mileage: 250424 km
                    Date: 2020.07.30
                    Time: 14:43:09
                    Write only channel
   Revision: 00002001    Serial number: 0180941091
   Coding: 0100062020B90000832009040001040F0000000000000000000000000000
                    Reset counter: 99
                    Mileage: 250424 km
                    Date: 2020.07.30
                    Time: 14:43:07
   Component: TSG BF        H03 0506
   VCID: 46D553F5A8AA9CFB297-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000433749
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B03024113884193D69-807E
   Part No SW: 4G0 035 180 F    HW: 4G0 035 180 E
   Component: RMC           H53 0775
   Coding: 0100010001411947002B040001010000000000
   VCID: 221DEF6564C280DB65F-8076
   Subsystem 1 - Part No SW: 4G0 919 603     HW: 4G0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9464H/0C2544673
   Subsystem 2 - Part No SW: 4G1 919 610 B    HW: 4G1 919 610 B
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LHE000GI
   Component: TSG HL        H03 0506
   Coding: 010814004000620002080002
   VCID: 49CF58C9B9B47383C45-801C
   Component: TSG HR        H03 0506
End----(Elapsed Time: 01:45, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Scan, as instructed.
MasterTommy
Amsterdam
C?ID=295586
Are you sure you can do that with the hardware you currently have?
Renier
Belgium
C?ID=411980
I have no idea to be honest. Might have to install some kind of Bluetooth adapter or retrofit an MMI 3G+ if that's even possible. I know that they have Bluetooth capabilities by default, just not enabled by default.
