Coding
hernan2531
C?ID=395690
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 53 55 56
          62 65 6D 72
VIN: 3VWDJ71K98M036833   Mileage: 297300km-184733miles
03-ABS Brakes -- Status: Not registered 0011
0F-Digital Radio -- Status: Not registered 0011
1C-Position Sensing -- Status: Not registered 0001
46-Central Conv. -- Status: Not registered 0011
47-Sound System -- Status: Not registered 0001
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Not registered 0011
6D-Trunk Elect. -- Status: Cannot be reached 1100
   Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G53NK85J
   Coding: 0403010A1C070160
   Shop #: WSC 00066 123 12345
   VCID: 3635208A544A987BB8F-8062
Readiness: 0000 0101
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1408
   Revision: 04808020    Serial number: 00000910020377
   Shop #: WSC 04940 001 00001
   VCID: 1C61D222CAA6222BAEB-8048
   Revision: 00H11001
   Coding: 0023238
   Shop #: WSC 12345 001 00204
   VCID: 73B3D99E07B8CD535F1-8026
            003 - Mechanical Failure
            008 - Implausible Signal
   Part No SW: 1K0 820 047 GF    HW: 1K0 820 047 GF
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 6E85C8EA6C9AE0BBB0F-803A
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Revision: 00H54000    Serial number: 00000000709861
   Coding: 158C8F0340041500470000000F00000000285D035C000100000000000000
   Shop #: WSC 00066 123 21122
   VCID: 71BFD3967DA4FF43ADD-8024
   Component: Wischer 230807 020  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Fault Status: 01101100
                    Reset counter: 73
                    Mileage: 297309 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.60 V
                    Reset counter: 73
                    Mileage: 297309 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.50 V
00985 - Right Tail Light (M2)
                    Reset counter: 73
                    Mileage: 297309 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.35 V
00317 - Rear Lid Control Module (J605)
                    Reset counter: 73
                    Mileage: 297309 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.80 V
02091 - Rear Window Washer Pump (V13)
                    Reset counter: 73
                    Mileage: 297309 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 10.75 V
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0133740
   VCID: 2E0508EAAC1AA0BBF0F-807A
00532 - Supply Voltage B+
                    Reset counter: 113
                    Mileage: 297309 km
                    Time: 21:46:22
                    Voltage: 8.40 V
                    Reset counter: 113
                    Mileage: 297309 km
                    Time: 21:45:52
                    Voltage: 8.40 V
                    Reset counter: 73
                    Mileage: 297309 km
                    Time: 08:00:56
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M02R8UN
   Coding: 0013889
   Shop #: WSC 00066 000 00000
   VCID: 6C81C2E25A8612AB9EB-8038
   Subsystem 2 - Serial number: 6332MSME1B5E6923M
   Subsystem 3 - Serial number: 6342MSME183E447BO
   Subsystem 4 - Serial number: 6351HSME0F310E358
   Subsystem 5 - Serial number: 6361HSME0F2308679
   Subsystem 6 - Serial number: 63727SME0F121A32.
   Subsystem 7 - Serial number: 63827SME0F122B4C8
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0002021
   Shop #: WSC 00063 000 00000
   VCID: 015F83564D04EFC35DD-8054
   Part No SW: 1K6 920 974 A    HW: 1K6 920 974 A
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G53NK85J
   Coding: 0016203
   Shop #: WSC 13861 067 57207
   VCID: 323D1C9AB822845B947-8066
                    Reset counter: 73
                    Mileage: 297309 km
                    Time: 01:19:05
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 73
                    Mileage: 297309 km
                    Time: 01:19:05
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 030707F2000398
   Coding: F5807B070202024002
   VCID: 30391692B62EB64BE23-8064
                    Mileage: 297309 km
                    Time: 01:19:06
                    Reset counter: 73
                    Mileage: 297309 km
                    Time: 01:19:06
                    Reset counter: 73
                    Mileage: 297309 km
                    Time: 01:19:07
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T2MF704
   Coding: 0000003
   VCID: 392F2BB66554770355D-806C
   Component: IMMO            VDD 1216
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000565178801
   Coding: 0000165
   VCID: 3B2331BE6F684513471-806E
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 35372786494C9363B15-8060
02546 - Steering Limit Stop
                    Mileage: 297290 km
                    Temperature: 29.0°C
                    Voltage: 11.30 V
                    Voltage: 11.10 V
   Component: A_ KSG PQ35 RDK 052 0221
   Coding: 150001FE0F83007F2900058F80881F6658DC40
   Shop #: WSC 00001 123 208896
   VCID: 04518A425216FAEB76B-8050
   Subsystem 1 - Component:   Sounder No Answer
   Subsystem 2 - Component:       NGS No Answer
                    Fault Status: 01100101
                    Reset counter: 73
                    Mileage: 297309 km
                    Time: 01:19:05
                    Reset counter: 73
                    Mileage: 297309 km
                    Time: 01:19:07
                    Reset counter: 73
                    Mileage: 297309 km
                    Time: 01:31:11
01134 - Alarm Horn (H12)
                    Reset counter: 73
                    Mileage: 297309 km
                    Time: 01:31:11
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 1K6 035 456 B    HW: 1K6 035 456 B
   Component: 08K Audioverst.     0006
   Revision: 00004000    Serial number: 00000008111628
   VCID: 2B0301FE9F08D593D71-807E
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000054678731
   Coding: 0001204
   VCID: 3C2132A26A66422B4EB-8068
Address 53: Parking Brake
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74B1DA8202B6CA6B46B-8020
01539 - Headlights Not Adjusted
00497 - Sensor for Vehicle Leveling; Rear
01533 - Terminal 56 (High Beams)
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio ZSW       017 0035
   Revision: 00017000    Serial number: VWZ5Z7G6075965
   Coding: 0010011
   VCID: 290FFBF695F4C78325D-807C
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000001966944
   Coding: 0000128
   VCID: 3E2538AA7C7A503B60F-806A
   Component:    RDK              0450
   Coding: 0100101
Address 6D: Trunk Elect.
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000001941340
   Coding: 0000128
   VCID: 3FDB45AE7B7059336B9-806A
End----(Elapsed Time: 01:36, VBatt start/end: 10.6V/10.2V. VIgn 10.2V)-----
jono
Canberra, Australia
C?ID=410415
I’m going to get in early and suggest you edit with the CODE wraparound then include more details :)
Did you try Coding: 0021122 yet?
Whats up with 0x53?
FOD?
WHY? Is firmware not up to date?
Ever been here or JPPSG?
Volkswagen
PartVersion
1K0907115S_0020
0040
Please charge this poor car's battery.
