- Joined
- Dec 7, 2015
- Messages
- 22
- Reaction score
- 12
- Location
- North East PA
- VCDS Serial number
- C?ID=165579
Hi, can someone help me with coding the modules for the OEM westfaldia hitch. My Q7 did not come with a hitch. It's 2017 prestige with ACC and lane assist. I enabled trailer in can gateway but I just learned the hard way there is way more to this then I thought. It looks like other modules need to be trailer module aware. Audi pre-sense is disabled and got few errors in the scan. Below is my scan, any help greatly appreciated.
Thank you,
David
Friday,31,July,2020,15:41:06:60178
VCDS Version: 20.4.1.0 (x64)
Dealer/Shop Name: Home user
VIN: WA1VAAF75HD033474 License Plate:
Mileage: 88672km-55098mi Repair Order:
Chassis Type F7-AU73 (8W8)
Scan: 01 02 03 06 08 09 13 15 16 17 19 28 29 36 39 3C 42 44 46 47
50 52 5F 69 6C 6D 74 81 82 84 8B A5 BB BC CA CB CF D6 D7
VIN: WA1VAAF75HD033474 Mileage: 88672km-55098miles
29-Left Light -- Status: INTERFACE NOT COMPATIBLE
39-Right Light -- Status: INTERFACE NOT COMPATIBLE
50-Seat Adj. 3rd row -- Status: INTERFACE NOT COMPATIBLE
74-Chassis Control -- Status: Malfunction 0010
84-Night Vision -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE
D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CREC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4M0 907 551 A HW: 06E 907 425
Component: 3.0l V6 TFSI H10 0003
Revision: --H10---
Coding: 2A2A0032056E010D74280000000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TFS0214M0907551A 001005
ROD: EV_ECM30TFS021_AU73.rod
VCID: 2D5B34A97CFA2CEE90-8078
17176 - Databus
U1123 00 [039] - Received Error Message
Mileage: 88672 km
Date: 2020.07.31
Time: 10:35:51
Coolant temperature: 24 °C
Intake air temperature: 25 °C
Voltage terminal 30: 11.738 V
Engine status: Stop
ACC variants (coding): ACC with braking until at standstill/Stop & Go
Readiness: 1110 0101
Address 02: Auto Trans Labels:| 0BK-927-156.clb
Part No SW: 4M0 927 158 L HW: 0D5 927 156 H
Component: 0D5 30TSIUSA H03 1006
Revision: --H03---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011_AU73.rod
VCID: 3D7B04E9AC9ABC6E20-8068
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-PRE-V1.clb
Part No SW: 4M0 907 379 Q HW: 4M0 907 379 N
Component: ESP9 Premium H09 0657
Coding: 28AA149C30A50A9991A25898188156A6E6269A14280C50891A186A65676459
ASAM Dataset: EV_ESP9BOSCHAU536K 012013
ROD: EV_ESP9BOSCHAU536K_AU73.rod
VCID: 458B6C09C44AF4AE78-8010
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-BFS 008 0031
Serial number: 00000221993338
Coding: 001410000000B0010000010101010000000000000000000000000000000000
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: 76E9DBC5C92C2F3621-8022
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4M0 820 043 AB HW: 4M0 820 043 AB
Component: Klima Zone 4 H52 0093
Coding: 6608090C5548011110680280800000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 65CB8C89648AD4AE98-8030
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000001085342
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: E1084D4800PAG0MUFU02
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0266
Coding: 07500363E0691CCD050F571958AF9CB911033D019000000000000000220016010869012B025709
VCID: 0201B71595E403961D-8056
Subsystem 1 - Part No SW: 4M1 955 119 A HW: 4H2 955 119 C Labels: 1KX-955-119.CLB
Component: WWS536 160822 043 0893
Serial number: 89555300401623501516
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 62319717
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AD HW: 4M0 941 531 AD
Component: E1 - LDS H06 0008
Serial number: 30 06 2016 00522681
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0050
Serial number: 0000009600335Z1X7R02
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20160915224434 00609
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE114071612010683
Coding: 030000
Interior Light Module:
Subsystem 7 - Part No SW: 4M0 947 135 CP HW: 4M0 947 135
Component: J528-Dachele H14 0130
Serial number: Q00202425
Electrically Adjustable Steering Column:
Subsystem 8 - Part No SW: 4M0 907 705 A HW: 4M0 907 705 A
Component: J866-EVLS-SG H03 0080
Serial number: WA125376000025475025
Coding: 020100
Subsystem 9 - Part No SW: 4M0 925 301 A HW: 4M0 925 301 A
Component: SL-Q7NF/AU736 H10 0013
Serial number: 00000000000000077009
Subsystem 10 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V512 LLR1SLvL H03 0012
Serial number: L14DG21500198
Subsystem 11 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V514 LLR1SKvL H03 0012
Serial number: L14DG21100051
Subsystem 12 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V516 LLR1SLvR H03 0012
Serial number: L14DG21500203
Subsystem 13 - Part No SW: 4M0 963 575 HW: 4M0 963 575
Component: V518 LLR1SKvR H03 0012
Serial number: L14DG21100052
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 4M0 907 561 E HW: 4M0 907 561
Component: LRR4 H09 0220
Coding: B4779FF278FFEC09949880A1
ASAM Dataset: EV_ACCBOSCHAU736 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 326127D565C47316CD-8066
1229 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 212
Mileage: 88672 km
Date: 2020.07.30
Time: 22:29:52
Control Module temperature: 30 °C
Voltage terminal 15: 11.6 V
Status_ACC_System: ACC_irreversible error
2153 - Databus
Reset counter: 212
Mileage: 88672 km
Date: 2020.07.30
Time: 22:29:52
Voltage terminal 15: 11.5 V
Address 15: Airbags (J234) Labels:* None
Part No SW: 4M0 959 655 A HW: 4M0 959 655 A
Component: Airbag10.44 H71 0086
Serial number: 003M50014WC-
Coding: AECCFCC000800000A0F00033C24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 397310F9B8B2804E0C-806C
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 4M0857705E0280Q01066
Coding: 88001B
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 4M0857706E0280Q00659
Coding: 88001B
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J160005YSRJ0D
Subsystem 4 - Part No SW: ----------- HW: 442 062 409 16
Serial number: 3577Y009B1FB75D0C44J
Subsystem 5 - Part No SW: ----------- HW: 442 062 409 16
Serial number: 3587Y009B1FB75D0D39P
Subsystem 6 - Part No SW: ----------- HW: 442 0B2 709 16
Component: SideSensor_Dr 1C7 0148
Serial number: 35177009F21438F4D31F
Subsystem 7 - Part No SW: ----------- HW: 442 0B2 709 16
Serial number: 35277009F21438F3C33G
Subsystem 8 - Part No SW: ----------- HW: 442 0C3 108 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500992172482B183
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 442 0C3 108 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500992172484F157
Central Sensor XY:
Subsystem 10 - Part No SW: ----------- HW: 410 201 309 16
Component: CentrSensorXY 1C8 0108
Serial number: I0O7800BD20D7DC1A29L
1060613 - Databus
Reset counter: 212
Mileage: 88672 km
Date: 2020.07.30
Time: 22:29:55
1060614 - Databus
Reset counter: 212
Mileage: 88672 km
Date: 2020.07.30
Time: 22:29:55
1060615 - Databus
Reset counter: 212
Mileage: 88672 km
Date: 2020.07.30
Time: 22:29:55
1060617 - Databus
Reset counter: 212
Mileage: 88672 km
Date: 2020.07.30
Time: 22:29:55
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 GS HW: 4M0 907 129 GS
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 0717A601BEC626BE4A-8052
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4M0 920 890 B HW: 4M0 920 890 B
Component: FBenUSA H15 0302
Coding: 08C600E17C88CF0502A369601800400008000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 2F672EA176F65EFEA2-807A
U1014 00 [009] - -
Reset counter: 212
Mileage: 88672 km
Date: 2020.07.30
Time: 22:29:51
Part No SW: 8W8 907 468 C HW: 8W8 907 468 C
Component: Gateway H27 1298
Revision: 4Q080005 Serial number: 0584Q015716A05
Coding: 0301000100000E405407000000590030D41200070C0000000175078E00000000
ASAM Dataset: EV_CGateCONTIAU491 002060
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 4C9D592DE72005E6A7-8018
Subsystem 1 - Part No SW: 4M0 951 523 A HW: 4M0 951 523 A
Component: J453 MFL H06 0002
Serial number: 20160923122001 00463
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 3103151804
66304 - Databus
U1124 00 [008] - Additional Installations Detected
Reset counter: 252
Mileage: 88672 km
Date: 2020.07.30
Time: 22:29:52
Address 28: HVAC, Rear (E265) Labels:* None
Part No SW: 4M0 919 158 D HW: 4M0 919 158 D
Component: Klima Zone 2 H52 0092
Coding: 000000000000000100800080000000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
ROD: EV_AirCondiFondBHTCAU736.rod
VCID: 36691BC589AC6F36E1-8062
Address 29: Left Light
Interface not compatible.
Address 36: Seat Mem. Drvr (J136) Labels:* None
Component: MEM-FS 008 0031
Serial number: 00000221432152
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
Address 39: Right Light
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 B HW: 4M0 907 566
Component: MRR1Rear H13 0230
Revision: --------
Coding: 0EE002
ASAM Dataset: EV_RearRadarS1BoschAU736 001015
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 346D21CD9FD07D26DF-8060
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 G HW: 4M0 959 793 C
Component: TSG FS 009 0052
Serial number: 0000221741939
Coding: 005D9B005E001080000120B0
VCID: 42817715D564C3965D-8016
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H20 0005
Serial number: 0000309311
Coding: B0000101000101
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
Address 46: Central Conv.
Address 47: Sound System (J525) Labels:* None
Part No SW: 4M0 035 223 B HW: 4M0 035 223
Component: MIB2_amp_PD H02 0430
Serial number: 00000000019992
Coding: 0135060A008AF53AAF0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
VCID: 2241D7953524E3963D-8076
Address 50: Seat Adj. 3rd row
Part No SW: 4M0 959 792 G HW: 4M0 959 792 C
Component: TSG BFS 009 0052
Serial number: 0000221228646
VCID: 41837819D062D88E44-8014
Address 5F: Information Electr. (J794) Labels:* 4M0-035-MIB-HGH2.clb
Part No SW: 4M0 035 880 B HW: 4M0 035 880
Component: MU-P-LNS-US 052 0692
Serial number: A289J0G7521721
Coding: 013706020000000053220002041A00102F001BE501700904BE
ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
VCID: 2B5F3AB142EE22DE8E-807E
Subsystem 1 - Part No SW: V03 959 802 DL HW: -----------
Component: NAR 2019 --- 0069
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9GJ4031NF
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4M0 919 615 H HW: 4M0 919 615 H
Component: ControlUnit_P H15 0209
Serial number: 29091600000000000221
Component: Gracenote2--- --- 3009
7223 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 252
Mileage: 88672 km
Date: 2020.07.30
Time: 22:29:57
Voltage terminal 30: 12.0 V
BAP-BAP_Function_ID: 16
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 C HW: 4M0 907 383
Component: Anhaenger H20 0214
Revision: 9C001003 Serial number: 0409097694
Coding: 0210000200000000
ROD: EV_TrailFunctGener2Hella_VW37.rod
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 E HW: 4M0 907 428
Component: Areaview 2 H13 0315
Serial number: C854607JG004182
Coding: 02350602BA0FA10008404000
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 30962730500000
Coding: 0030
VCID: 4895653DF358E9C683-801C
Address 74: Chassis Control
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M1 713 041 F HW: 4M1 713 041 F
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20160924001009
ROD: EV_GSMWaehlZFAU736.rod
VCID: 2855C5BD531809C663-807C
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4M0 919 617 B HW: 4M0 919 617 B
Component: HeadUpDisplay H28 1603
Coding: 5F01E0
ASAM Dataset: EV_HudNSEIKAU736 001015
ROD: EV_HudNSEIKAU736_AU73.rod
Address 84: Night Vision (J853) Labels:* Redir Fail!
Part No SW: 4M0 907 547 A HW: 4M0 907 547
Component: NV-ECU-Gen3 H08 0027
Serial number: 635514900201638
Coding: 210111
ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
Camera For Night Vision System:
Subsystem 1 - Part No SW: 4G0 980 552 HW: 4G0 980 552
Component: NV-CAM-Gen3 H03 0006
Serial number: 623466500F1624400411
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 4M0 907 541 E HW: 4M0 907 541
Component: LRR4 H10 0220
ASAM Dataset: EV_ACC2BOSCHAU736 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 30652DDD6BC84106BB-8064
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 4M0 907 217 D HW: 4M0 907 217 A
Component: BVS H14 0042
Coding: 0407030600000202032023B6AD0000B4B0F0C020C020
ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
0646 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 212
Mileage: 88672 km
Date: 2020.07.31
Time: 10:31:43
Control Module temperature: 42 °C
Voltage terminal 15: 11.80 V
Part No SW: 4M0 959 795 G HW: 4M0 959 795 C
Component: TSG HFS 009 0052
Serial number: 0000221798256
Coding: 004D9B0000001080400020A0
VCID: 448D710DCF70CDA66F-8010
Component: TSG HBFS 009 0052
Serial number: 0000221798251
Address CA: Sunroof
Address CB: Rear Axle Steering (J1019) Labels:* None
Part No SW: 4M0 909 145 G HW: 4M0 909 145 D
Component: HAL_MLBevoH07 0607
Revision: -------- Serial number: CCC_007_D_07_03
Coding: 008408
ASAM Dataset: EV_RearAxleSteerZFAU736 005010
ROD: EV_RearAxleSteerZFAU736_005.rod
Address CF: Lane Chge Asst 2
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End-------------------------(Elapsed Time: 07:09)--------------------------
Thank you,
David
