2019 Seat Terraco Towbar issue
danimal
C?ID=407268
first post, be kind...
Fitted a new towbar and electrics kit to a 2019 Terraco, all went well, towbar works fine, all lights as expected.
Enabled 69 Towbar as detailed in the fitting instructions for the electrics, but then they get a little vague... some of these 'might' be required..:
Included a screen shot of the coding instructions, seem to be similar across all electrics manufacturer, mine isn't actually this one..
JrzNGJL
If that img insert doesn't work, then last page here : https://www.ecs-electronicsuk.co.uk/manual.php?f=VW19007MU Seat Tarraco Skoda Kodiaq web.pdf
some of the references are there, most of the controls modules are the same numbers but most don't have those functions listed, or don't seem to as they are ODIS codes and not VCDS... maybe there's some insight someone can give for future reference... ?
there's a few useful things there like disable the auto boot close if the tow electrics are connected.. (would save me getting hit on the head again with the trunk lid when my arm sweeps under the rear bumper...)
The main problem is ACC Auto Cruise Control complains at start up in a dash message.. can see a problem relating to A5 Front Drive Assist, is it just a databus clash, if so, how to resolve?
 Tuesday,28,July,2020,17:55:09:45043
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4513.4
VIN: VSSZZZKNZKWxxxxxx   License Plate:
Mileage: 17041km-10588mi   Repair Order:
Chassis Type: KN-SE37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 2B 36 42 44 46 4B 52 5F
          69 6C 6D 74 75 A5 D6 D7
VIN: VSSZZZKNZKWxxxxxx   Mileage: 17041km-10588miles
46-Central Conv. -- Status: Cannot be reached 0100
74-Chassis Control -- Status: Cannot be reached 0100
Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 RA    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 6580
   Revision: B4H25---
   Coding: 0125003203661D083000
   ASAM Dataset: EV_ECM20TDI01104L906026RA 004004
   ROD: EV_ECM20TDI01104L906026RA.rod
   VCID: 7AADF7671C55A6EB1DF-802E
17156 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 46
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 01:40:31
                    Engine speed: 841.00 /min
                    Normed load value: 36.1 %
                    Coolant temperature: 22 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 11.660 V
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
   Part No SW: 0DL 300 013 A    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 3004
   Revision: 00H06V07
   VCID: 2809FD2FB279E47B3BB-807C
   Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 60319000000775
   Coding: 2204929A50200B758778070962C64844490AD0E1E046127538625074F2294B0B00402E64121A03102F5E833B485266E4
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 79AFE86B1953ADF3145-802C
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 6097134669
   Coding: 132C0C0707
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D34A832B1F27230E9-8016
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11489215
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5FJ 907 044 E    HW: 5FJ 907 044 E
   Component: AC Automat    H35 4702
   Revision: 20K10000    Serial number: 00000B01239028
   Coding: 0010010420011001110510000010152A
   ASAM Dataset: EV_ACClimaPrehVW37X 002026
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 42DD4F8734052E2B05F-8016
   Subsystem 1 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 84825161
   Subsystem 3 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 8341027701ÿÿÿÿ
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7CA1F17F166198DB0F3-8028
   Subsystem 1 - Part No SW: 5NC 955 119 A    HW: 5NC 955 119 A  Labels: 1KX-955-119.CLB
   Component: 326 RL 290119  033 0372
   Serial number: 00000001901250301483
   Coding: 0FC5FD
   Component: RLHS  052 0107
   Serial number: S6Y19M02D20H19M17S31
   Coding: 0089DD
   Serial number: 000000000ZY1901502ZH
   Serial number: 00000000000046109000
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 BQ    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000027011904221200
13 Faults Found:
10762 - Bulb for Right Tail Light
          B12BF 15 [008] - Open or Short to Plus
                    Reset counter: 53
                    Time: 00:00:00
132619 - Voltage Supply; Terminal 30; Right
          B140E 13 [008] - Open Circuit
                    Reset counter: 53
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 00:10:22
133387 - Voltage Supply; Terminal 30 for Central Locking
          B140F 13 [008] - Open Circuit
                    Reset counter: 53
                    Time: 00:00:00
133899 - Voltage Supply; Terminal 30 for Seat Heaters
          B1411 13 [008] - Open Circuit
                    Reset counter: 53
                    Time: 00:00:00
197123 - Lock Module for Central Locking; Rear Left
          B12DB 07 [008] - Mechanical Failure
                    Reset counter: 53
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 00:10:22
197132 - Lock Module for Central Locking; Rear Left
          B12DB 01 [024] - Electrical Failure
          Intermittent - Confirmed - Not Tested Since Memory Clear
                    Reset counter: 13
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 00:10:22
197379 - Lock Module for Central Locking; Rear Right
          B12DC 07 [008] - Mechanical Failure
                    Reset counter: 53
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 00:10:22
197388 - Lock Module for Central Locking; Rear Right
          B12DC 01 [024] - Electrical Failure
                    Reset counter: 13
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 00:10:22
204546 - Remote key 2
                    Reset counter: 237
                    Mileage: 14337 km
                    Date: 2020.03.03
                    Time: 15:46:53
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [008] - -
          [Sensor-DWA->kein Signal/ Kommunikation]
                    Reset counter: 53
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 00:10:22
533013 - Databus
          [ELV_01 Datenbus fehlende Botschaft]
                    Reset counter: 53
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 00:10:22
539925 - Databus
          [Kombi_02 Datenbus fehlende Botschaft]
                    Reset counter: 53
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 00:10:22
589592 - Databus
          U1201 00 [008] - No Communications
          [CAN Keine Kommunikation]
                    Reset counter: 53
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 00:10:22
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417319043
   Coding: 0371263851
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 51FF70CBE163C5B38C5-8004
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Coding: 320067C358FF8728749C814580508700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
196741 - Sensor for Automatic Distance Control
          [FCTSEN_BLOCKAGE]
                    Reset counter: 53
                    Mileage: 16693 km
                    Date: 2020.07.12
                    Time: 20:54:36
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 39 °C
                    Vehicle speed: 14.76 m/s
                    Longitudinal acceleration: -1.00 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
196742 - Sensor for Automatic Distance Control
          [FCTSEN_DEC_BLOCKAGE]
                    Reset counter: 53
                    Mileage: 16695 km
                    Date: 2020.07.12
                    Time: 20:56:10
                    Voltage terminal 15: 13.1 V
                    Control Module temperature: 38 °C
                    Vehicle speed: 27.28 m/s
                    Longitudinal acceleration: 0.19 m/s²
196743 - Sensor for Automatic Distance Control
          [FCTSEN_INC_BLOCKAGE]
                    Reset counter: 53
                    Mileage: 16365 km
                    Date: 2020.07.09
                    Time: 15:08:08
                    Control Module temperature: 41 °C
                    Vehicle speed: 9.36 m/s
                    Longitudinal acceleration: -0.25 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
1229 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Fault Frequency: 46
                    Reset counter: 32
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 01:40:31
                    Voltage terminal 15: 11.6 V
                    Control Module temperature: 20 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: -0.16 m/s²
   Part No SW: 5Q0 959 655 BS    HW: 5Q0 959 655 BS
   Component: AirbagVW21    007 0403
   Serial number: 003FMR51532/
   Coding: 98CCC0C0000000005C5450CF00C800545065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 127DBFC724E57EABF5F-8046
   Subsystem 1 - Part No SW: -----------    HW: 480 000 902 19
   Serial number: 357000000008A6A4093M
   Subsystem 2 - Part No SW: -----------    HW: 480 000 902 19
   Serial number: 3580000000037419683E
   Subsystem 3 - Part No SW: -----------    HW: 480 401 802 19
   Component: SideSensor_Dr  004 6149
   Serial number: 35100011E2C009B383E1
   Subsystem 4 - Part No SW: -----------    HW: 480 401 902 19
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001B12E4B1B5660/
   Subsystem 5 - Part No SW: -----------    HW: 480 401 202 19
   Component: FrontSensor_D  004 6149
   Serial number: 35500010C2C0098592E1
   Part No SW: 5FJ 920 790     HW: 5FJ 920 790
   Component: KOMBI         615 1701
   Coding: 24A46E1FEF800600018862031001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_SE37.rod
   VCID: 55F784DBD58BA99350D-8000
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4367
   Revision: --------    Serial number: 0009132833
   Coding: 030500F40F086A00E91322581A0F00010001070000000000000000000000
   ROD: EV_GatewNF_SK26.rod
   VCID: 6E85CB37501DFA4BB17-803A
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 5FJ 959 537 A    HW: 5FJ 959 537 A
   Component: E221__MFL-PR6  H01 0130
   Serial number: 000000000G0381131218
   Coding: 012000
   Serial number: 5189720405
131712 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x80]
                    Reset counter: 32
                    Mileage: 17041 km
                    Date: 2020.07.28
                    Time: 16:48:28
                    Supply voltage: Terminal 30: 11.7 V
                    Terminal 15: On
131723 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x8B]
                    Reset counter: 32
                    Mileage: 17041 km
                    Date: 2020.07.28
                    Time: 16:48:28
                    Terminal 15: On
66304 - Databus
          U1124 00 [008] - Additional Installations Detected
          [Mehrverbau CAN]
                    Fault Frequency: 23
                    Reset counter: 55
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 00:59:41
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: OFF
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00029.01.19
   Coding: 0101
   VCID: 4CC161BF0641E85BFF3-8018
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 19000019723014
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   VCID: 33331A437BBF97A39E9-8066
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006SAM15948
   Coding: 001C000000000500018480808180000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D273C7B4DFB51D378D-8068
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007SB12636D
   Coding: 003F1A20D201040000001000
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 44D1499F2E11201B373-8010
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000027548520
   Coding: 2D0000
   Part No SW: 5QF 909 144 B    HW: 5QF 909 144 A
   Component: EPS_MQB_ZFLS  507 5582
   Coding: 93170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 49CF58AB0933FD73C45-801C
Address 46: Central Conv.
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 02021910803076
   Coding: 000000070900065601000900000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 3537245B75CB8993B0D-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007SB20077A
   Coding: 003F1220DE01040000001000
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000027460162
   Coding: 350000
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5F0 035 874 A    HW: 5F0 035 874 A
   Component: MU-S-ND-ER    H50 0514
   Serial number: SEZAZ2W0235672
   Coding: 04231601FF00000051110101008808002F0100E601A00400C6
   ASAM Dataset: EV_MUStd4CTSAT 001001
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 270BFE13BF67EB03321-8072
   Subsystem 1 - Part No SW: 5FJ 919 605 A    HW: 5FJ 919 605 A
   Component: ABT_Std-2_Nav  H56 8130
   Serial number: SEZ6ZHW0432756
   Subsystem 2 - Part No SW: 6P0 919 866 AF    HW: -----------
   Component: ECE1 2018/19  --- 1030
0513 - Rear Right Treble Speaker
          B1068 13 [008] - Open Circuit
          [Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
                    Reset counter: 72
                    Mileage: 16729 km
                    Date: 2020.07.15
                    Time: 03:30:37
                    Voltage terminal 30: 12.1 V
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: ConWysTrailer H14 0137
   Serial number: 00000181563668
   Coding: 0100000200000000
   ROD: EV_TrailFunctGener2Hella_VW37.rod
   VCID: 392F286B59D36DF3545-806C
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG047184
   Coding: 06230601260FA0000060608C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0266
   Revision: --------    Serial number: 32279592000000
   Coding: 3D08
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   VCID: 45D7549B252B191320D-8010
Address 74: Chassis Control
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 04230601EA761A0D0100040200356003804600
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW25.rod
9457171 - Audio signal output 1
          B14F1 13 [008] - Open Circuit
                    Reset counter: 53
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 00:00:04
                    Voltage terminal 30: 12.2 V
   Part No SW: 3Q0 980 654 M    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0451
   Serial number: 03021915P10375
   Coding: 030307060000040000021344C152A50084000E20000080
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 41DF408B310335331C5-8014
1123187 - Local Data Bus
          U116B 00 [009] - Received Malfunction Value
          [RDR1_Header_FGN_Status]
                    Fault Frequency: 46
                    Reset counter: 32
                    Mileage: 16706 km
                    Date: 2020.07.14
                    Time: 01:40:32
                    Control Module temperature: 23 °C
                    Outside air temperature: 18.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 3.8 s
                    Voltage terminal 15: 11.8 V
                    mid: 02 C0
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 5
                    Software_Info_2: 4
                    Software_Info_1: 0
   Part No SW: 992 941 571 AC    HW: 992 941 571 A
   Component: LED1L         H08 9201
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X_SK48.rod
   VCID: 6393AA038BDF47232E9-8036
131329 - Databus
          U1201 00 [032] - No Communications
          [can data bus - no communication]
   Component: LED1R         H08 9201
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
131329 - Databus
End----(Elapsed Time: 02:04, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
Hi and welcome.
Since you "Fitted a new towbar and electrics kit", this belongs in Retrofits, not Tweaks. I'll move it there.
I don't suppose you have a scan from before you started the tow bar installation, do you?
DV52
C?ID=194404
^ ^^danimal: Hi. I suspect that Uwe is tactfully implying that this vehicle might have more than one problem!! .
In any event - pending the provision of additional information (perhaps we might even get a peek at the change records in the CodingLog, CSV and adpLog.CSV files on your laptop) and apropos of the specific J483 question in your post - the long code string in your hex13 is more readably shown as:
Byte	Hex	Binary
0	32	00110010
1	00	00000000
2	67	01100111
3	C3	11000011
4	58	01011000
5	FF	11111111
6	87	10000111
7	28	00101000
8	74	01110100
9	9C	10011100
10	81	10000001
11	45	01000101
12	80	10000000
13	50	01010000
14	87	10000111
15	00	00000000
16	00	00000000
17	00	00000000
18	00	00000000
19	00	00000000
20	00	00000000
21	00	00000000
22	00	00000000
23	00	00000000
24	00	00000000
I've highlighted Byte 3, Bit 3 because it is set low (i.e. zero). According to the "yellow" long coding helper screen, this software switch is fairly pertinent to your retrofit project - see below:
Try setting this switch, then clear ALL DTCs and then re-post your auto-scan - please
danimal
C?ID=407268
thanks for the welcome..
Haven't got a scan from before hardware install, never been into the system on this one (honestly gov'nor), had to go buy a new hex-2 cable for it which only just arrived, my old one hex-can was reported as not working, so never tried it....
the car isn't very old, never been any dash errors or anything.
happy to have the post moved around to where it should be, thank you.
I'll go make some checks as described by DV52 ↓↓
Hi and welcome.
danimal
C?ID=407268
Hiya,
made the bit change, cleared DTC's, ACC now doesn't moan or error, no other errors now... thank you.. :thanks:
to Uwe's 'subtle' point.... ;)
Chassis Control module (74) was not discover-able, should i take this out of the Installation list, as it can't find it anyway? then the scan should run with no errors....
thanks
Dan
Byte	Hex	Binary
0	32	00110010
1	00	00000000
2	67	01100111
3	C3	11000011
4	58	01011000
5	FF	11111111
6	87	10000111
7	28	00101000
8	74	01110100
9	9C	10011100
10	81	10000001
11	45	01000101
12	80	10000000
13	50	01010000
14	87	10000111
15	00	00000000
16	00	00000000
17	00	00000000
18	00	00000000
19	00	00000000
20	00	00000000
21	00	00000000
22	00	00000000
23	00	00000000
24	00	00000000
