Hi Everyone,
I need to do an auto scan on a 2014 Lamborghini Huracan and I have the professional Hex-V2 interface with unlimited Vins.
Having a look around I have found some people advising this can be done with the Hex-Net but no comments saying it works with the V2. When I purchased the V2 a couple of years ago I had the choice between the 2 and was advised they were identical apart from the WiFi, this being the case I opted for the cheaper unit which was more like my Hex+can I had previously. I assume as the V2 covers all of the current range (as per the Ross-Tech advert) it should have the same capability as the Hex -Net?
Is anyone able to confirm if this is correct or not?
If the V2 is not compatible can you please advise what the differences are between the 2 so I can decide if I should invest in the HEX-NET.
This is the first Lamborghini I have ever needed to scan and I don't imagine I will be seeing many more.
Many thanks for your help
Andy
Andy
