Need Some Help
Byron
C?ID=12098
Hi, Got my Hex-V2 today and was able to connect to 02-Transmission (to show gear selection in D) and Electronics 1, Block 17 controllers (to deactivate seat belt chime) with no problem. Hoping to adjust "A/C comfort for Stop/Start" I looked for access to the air conditioner controller and I didn't find one and I don't find one in list in the autoscan. As you can probably tell, I'm looking for a way to disable Start/Stop like I did on my 2018 S5's. Does this make any sense to you?
Can you help me gain access to the appropriate controller?
Thanks,
Byron
Here is the data: 2020 Audi A6 Allroad VIN: WAU92BF29LN067598.
And here is the Autoscan:
Tuesday,14,July,2020,14:47:57:36392
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4526.4
VIN: WAU92BF28LN067598   License Plate:
Mileage: 622km-386mi   Repair Order:
Chassis Type: F2-AU58 (4K0)
Scan: 01 02 03 06 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47 52 5F
          61 6D 74 75 81 82 A5 BB BC C4 CA CB CC CF D6 D7 DB DC DD DE
VIN: WAU92BF28LN067598   Mileage: 622km-386miles
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
DD-Sunroof 2 -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: OK 0000
Address 01: Engine (J623-DLZA)       Labels: None
   Part No SW: 4K0 907 559 D    HW: 06M 907 309 G
   Component: V6 3.0l TFSI  H11 0002
   Revision: B8H11000
   Coding: 32650012236E010E34286000000400000000000000000000
   ASAM Dataset: EV_ECM30TFS0114K0907559D 001003
   ROD: EV_ECM30TFS0114K0907559D.rod
   VCID: 36352333F8CF9F3BB97-8062
Readiness: 1110 0101
   Part No SW: 4K0 927 153 M    HW: 0HL 927 156 B
   Component: 0HL 30TFSINAR H01 0005
   Revision: --H01---    Serial number: 0000000942
   Coding: 000001
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU58.rod
   VCID: 372B2E37FFC56633A21-8062
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041200014003630
   Part No SW: 4N0 907 379 AQ    HW: 4N0 907 379 P
   Component: ESP9 Premium  H06 0857
   Coding: 58AA169729A82B9D97A34C9A3A8551E2F539891A6894D4E9325C8A47AF9C91
   ASAM Dataset: EV_ESP9BOSCHCMP 004011
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 074B9EF7CFA5D6B3121-8052
   Part No SW: 4M6 959 760 B    HW: 4M6 959 760 B
   Component: MEM-BFS       009 0044
   Serial number: 00000399097939
   Coding: 001CB2400001BEA14843010101010000810000070700878700000000000000
   ROD: EV_SCMPasseSideCONTIAU736_VWE3.rod
   VCID: 3D273C1FDDF94C6378D-8068
   Subsystem 1 - Part No SW: 4N0 907 182     HW: 4N0 907 182
   Component: N477 VB1 BFSv  H04 0011
   Serial number: SJ800115121940258830
   Coding: BF2F00
   Valve Block 2 In Passenger Side Front Seat:
   Subsystem 2 - Part No SW: 4N0 907 182 D    HW: 4N0 907 182 D
   Component: N478 VB2 BFSv  H04 0010
   Serial number: SJ800109012011470142
   Part No SW: 4N0 907 063 KE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0691
   Coding: 07000363C0291CCD070E57889CEF9C38130B37110406009701010A001B331601086909028010000000000303004308180802000044010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 7BA3F207836D8253069-802E
   Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000001912040402417
   Coding: 7DC727
   Serial number: 24194161X81A955555A0
   Coding: 02006E
   Light switch:
   Subsystem 3 - Part No SW: 4K1 941 501 C    HW: 4K1 941 501 C
   Component: E1 - LTM  H09 0086
   Serial number: 14S21.01.2000692894
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0300
   Serial number: 0000009600373Z00F402
   Coding: 250000
   Subsystem 5 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE119111923610901
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 BE    HW: 4K0 947 135 BE
   Component: Dachmodul  H42 0416
   Serial number: C00444394
   Coding: 0D0101
   Electrically Adjustable Steering Column:
   Subsystem 7 - Part No SW: 80A 907 705 A    HW: 80A 907 705
   Component: J866-EVLS-SG  H07 0200
   Serial number: WA140323000078321161
   Coding: 0A0700
   Subsystem 8 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V512 LLR1SLvL  H01 0012
   Serial number: Q98BK01360475
   Subsystem 9 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V514 LLR1SKvL  H01 0012
   Serial number: Q98BK01078575
   Subsystem 10 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V516 LLR1SLvR  H01 0012
   Serial number: Q98BK01360471
   Subsystem 11 - Part No SW: 4N0 963 575 A    HW: 4N0 963 575 A
   Component: V518 LLR1SKvR  H01 0012
   Serial number: Q98BK01078551
   Part No SW: 4K0 907 561 G    HW: 760 907 561 A
   Component: LRR4R         H04 0332
   Coding: D2659F5478082C00010360E10000003E4A1246484401009E05
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 323D1F2314A7831B95F-8066
   Part No SW: 4N0 959 655 N    HW: 4N0 959 655 N
   Component: AirbagVW31    H15 2720
   Serial number: 003YXM00C7J1
   Coding: BFFCF0C000C00000A000003FF20D410000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 47CB5EF78F2516B3D21-8012
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
   Component: BeltPretRevFL  H10 0115
   Serial number: 00AI2020022125000000
   Coding: 04F001
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
   Component: BeltPretRevFR  H10 0115
   Serial number: 00AI2020022388600000
   Coding: 04F001
   Occupant Detection:
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H12 0022
   Serial number: IBH0000D19000CDXFV01
   Coding: 303136
   Subsystem 4 - Part No SW: -----------    HW: 480 002 801 20
   Serial number: 35700000000F997C544.
   Subsystem 5 - Part No SW: -----------    HW: 480 002 801 20
   Serial number: 358000000007797C544S
   Subsystem 6 - Part No SW: -----------    HW: 480 033 101 20
   Component: SideSensor_Dr  002 0149
   Serial number: 351002C0487255A09DAA
   Subsystem 7 - Part No SW: -----------    HW: 480 033 101 20
   Component: SideSensor_Pr  002 0149
   Serial number: 352002C0487299E0AEBQ
   Subsystem 8 - Part No SW: -----------    HW: 480 032 501 20
   Component: FrontSensor_D  002 0149
   Serial number: 355002C046F10860AA12
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 032 501 20
   Component: FrontSensor_P  002 0149
   Serial number: 356002C00B98A9E05DBW
   Part No SW: 4N0 907 129 Q    HW: 4N0 907 129 Q
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 3FDB4617D7F55E736A1-806A
   Part No SW: 4K0 920 890 B    HW: 4K0 920 890 B
   Component: FBenUSAACC--- H12 0212
   Coding: 8BC670E5FC88D7050293E16098804B0008002000
   ASAM Dataset: EV_DashBoardAU65X 001017
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 2D070C5F0D99DCE3C8D-8078
   Part No SW: 4K0 907 468 Q    HW: 4K0 907 468 C
   Component: Gateway       H06 0272
   Serial number: 1AF02121330701
   Coding: 020100050004064054960000005B0132DCBA004F18000000097D078E10000000
   ASAM Dataset: EV_Gatew31xAU65x 003190
   ROD: EV_Gatew31xAU65x.rod
   VCID: 42DD4FE3A407339B05F-8016
   Subsystem 1 - Part No SW: 4K0 951 523 J    HW: 4K0 951 523 J
   Component: E221__MFL  H06 0010
   Serial number: 00000000000000000000
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 741863130020011700B4
   Part No SW: 4N0 907 144 D    HW: 8W0 907 144 C
   Component: SCU_MLBevo    H03 0803
   Serial number: 30303030303030
   ASAM Dataset: EV_SCUZFLSAU65X 003019
   ROD: EV_SCUZFLSAU65X.rod
   VCID: 2F3B16570795AEF3FA1-807A
Address 22: AWD (J492)       Labels:* None
   Part No SW: 4K0 927 755 C    HW: 0CJ 927 749 A
   Component: C8_DL4_H_SD2H02 0008
   Serial number: 19326B2444
   Coding: 170C0000
   ASAM Dataset: EV_AWDCQUOD31 001052
   ROD: EV_AWDCQUOD31.rod
   VCID: 3537243FE5C99423B0D-8060
   Component: MEM-FS        009 0044
   Serial number: 00000399096053
   Coding: 001C9A400001BEA14803010101010000810000070700878700000000004000
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   Component: N475 VB1 FSv  H04 0011
   Serial number: SJ800115121940258836
   Coding: BF2F00
   Valve Block 2 In Driver Side Front Seat:
   Component: N476 VB2 FSv  H04 0010
   Serial number: SJ800109012011470146
Address 3C: Lane Change (J769)       Labels:* None
   Part No SW: 4N0 907 566 H    HW: 4N0 907 566 A
   Component: MRR_HR H16 0267
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651_AU58.rod
   VCID: 3B233207C3ED4253469-806E
   Part No SW: 4M1 959 793 J    HW: 4M1 959 793 D
   Component: TSG FS002 0425
   Serial number: YE007SLJ09748
   Coding: 001DCB0152001482A009A032
   ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 46D553F3882F0FBB297-8012
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0505
   Coding: E1002101010000
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010.rod
   Part No SW: 4N0 907 064 DP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H15 0202
   Coding: 013400004FB100C0650FA0046C05880203004000810426502F0400000F04823F001E0101010011
   ASAM Dataset: EV_BCM2CONTIAU651 010009
   ROD: EV_BCM2CONTIAU651_010_AU58.rod
   VCID: 005985EBEA8BE18B53B-8054
   Ignition key:
   Subsystem 2 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY200102EXD
   Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000048072505
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 14355148
   Rear Spoiler Adjustment:
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAK7D03G5H.
   Coding: 0185020000AAAA2FAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 2411E97B5E531DAB173-8070
   Part No SW: 4M1 959 792 J    HW: 4M1 959 792 D
   Component: TSG BFS002 0425
   Serial number: YE007SLI31338
   Coding: 001DCB015E001482A009A030
   ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   VCID: 45D754FFB52904A320D-8010
   Part No SW: 4K0 035 084 D    HW: 4K0 035 084 A
   Component: MU-H-LNS-US   056 2711
   Coding: 0185420200000000C1220002061C00302F0001E403F008048E
   ASAM Dataset: EV_MUHigGen2pALPI 001001
   ROD: EV_MUHigGen2pALPI_AU27.rod
   VCID: 270BFE772F65F6B3321-8072
   Subsystem 1 - Part No: V03 959 804 CD
   Component: MIB2P_NA_Q119  0366
   Subsystem 2 - Part No SW: 4K0 919 605 L    HW: 4K0 919 605 F
   Component: DU AU58x Top  H31 0053
   Serial number: INX00128121900220106
   Subsystem 3 - Part No: V03 959 800 EG
   Component: Gracenote2  3008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Component: LSR-D5/C8  H33 0110
   Serial number: 00004420000003414009
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4K0 919 603 L    HW: 4K0 919 603 F
   Component: DU AU58x Bot  H31 0053
   Serial number: INX00105012000240251
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 726 A    HW: 4N0 035 726
   Component: MediaConnectL  014 0133
   Serial number: 052000039479005
Address 61: Battery Regul. (J1120)       Labels: None
   Part No SW: 4N0 915 105 B    HW: 4N0 915 105 B
   Component: BMS_48V_LiIon H06 0108
   ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
   ROD: EV_BMS48VLiIonLGAU536_AU58.rod
   VCID: 290FF84F3971C0C3245-807C
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4
   Coding: 1270
   ROD: EV_DeckLidCONTIAU736_VW27.rod
   VCID: 3431193BEEB38D2B873-8060
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4K0 907 777 CA    HW: 4K0 907 777 C
   Component: Fahrwerk-SG   H52 2135
   Serial number: 1401200309
   Coding: 745D3840F848
   ASAM Dataset: EV_ChassContrContiAU651 002016
   ROD: EV_ChassContrContiAU651_002.rod
   VCID: 78A9ED0BB25BA94B6BB-802C
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130847738
   Coding: 303030
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 4K1 035 283 C    HW: 4K1 035 283 B
   Component: ConBox        H09 0233
   Serial number: 005CCA12F121230
   Coding: 01C020FF4040800000
   ASAM Dataset: EV_ConBoxAU651 002004
   ROD: EV_ConBoxAU651_002.rod
   VCID: 2809FD4B227BF9CB3BB-807C
   Part No SW: 4K1 713 041 K    HW: 4K1 713 041 H
   Component: GSM-LL H14 0051
   Serial number: 20.022 40607
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 2B030247338DD2D3D69-807E
   Part No SW: 4K1 919 617 B    HW: 4K1 919 617 B
   Component: HeadupDisplay H11 4910
   Coding: 4700E0
   ASAM Dataset: EV_HeadUpDisplAU65X 001011
   ROD: EV_HeadUpDisplAU65X_VW53.rod
   VCID: 33331A27EBBD8A139E9-8066
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AR    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0295
   Coding: 020184000000000000FBD60000F0D50C139F5600000000000000000000969401019BA8000000000000000080000000000000000000000000F980400000000000000078180080009000800080000000000080400000E0
   ASAM Dataset: EV_ZFASAU516 001007
   ROD: EV_ZFASAU516_001.rod
   VCID: 0F7BB6D7A7D58EF3DA1-805A
   Part No SW: 4M1 959 795 J    HW: 4M1 959 795 D
   Component: TSG HFS004 0425
   Serial number: YE007SLK13507
   Coding: 000DCB0100001482E008A020
   ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001018
   VCID: 48C95DCB823B19CBDBB-801C
   Component: TSG HBFS004 0425
   Serial number: YE007SLF02985
   ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001018
Address C4: DC/DC Converter (A7)       Labels: None
   Part No SW: 4K0 959 663     HW: 4K0 959 663
   Component: DCDC_GEN_2 H20 0307
   Serial number: DC20054000766
   ASAM Dataset: EV_DCDC48VFLEXAU581 004001
   ROD: EV_DCDC48VFLEXAU581_VW38.rod
   VCID: 75B7E43FA549D42370D-8020
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Coding: 268040058203
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_VW27.rod
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4N0 909 145 K    HW: 4N0 909 145 C
   Component: HAL_MLBevoH03 0398
   Revision: --------    Serial number: CCC_098_B_9056_
   Coding: 42244200
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010.rod
   VCID: 392F280FC9D17043545-806C
Address CC: Starter-Generator (----)       Labels:* None
   Part No SW: 4N0 903 028 N    HW: 4N0 903 028 N
   Component: BSG-HP1-65    H17 0523
   Serial number: 22012000020470
   Coding: 20000400000000
   ASAM Dataset: EV_Start48VAU651 001006
   ROD: EV_Start48VAU651_001.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H16 0267
   Coding: 0FFC00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651_AU58.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 572 DC    HW: 4K0 941 572 D
   Component: LMS_MLBevo    H06 0031
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 72BDDF23D427C31B55F-8026
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ASAM Dataset: EV_LMSRightHELLAAU58X 001013
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 H    HW: 4N0 907 669 A
   Component: MRR_VR H16 0267
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651_AU58.rod
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H16 0267
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651_AU58.rod
Address DD: Sunroof 2 (J392)       Labels:* None
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Component: SAD_STG_2     006 0002
   Coding: 229000058204
   ASAM Dataset: EV_SunRoof2CONTIPO623 009011
   ROD: EV_SunRoof2CONTIPO623.rod
   VCID: 76B5E333B84FDF3B797-8022
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4K0 035 502 B    HW: 4K0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 800000
   ASAM Dataset: EV_Charg1MobilDevicAU651 004001
   ROD: EV_Charg1MobilDevicAU651.rod
   VCID: 2019E56B4A4B018B73B-8074
HVAC functions have been integrated into the BCM at address 09 on this car.
DV52
C?ID=194404
^ ^^ ^ Wow - that's the 2nd longest BCM long code string that I have ever seen - what a monster!!!
If I'm correct, the Byte count is a massive 65! I know it's academic given there is no label file for the module, but can the long code helper screen accommodate this many Bytes?
