2019 vw tiguan FRONT ASSIST INOP AFTER TOWBAR FITTING
Tony@beltonmotors
C?ID=362723
Hi there, tony here a newbie here.
ok so i had in a 2019 vw tiguan for a towbar to be fitted along with a dedicated wiring kit that connects into the can system in the fuse box. so everything went well, bar fitted wiring connected. After following the coding instructions and a few vcds videos on youtube i got the kit to work and all the lights on the towbar plug now work. Now the issue i have is that on the dash it says FRONT ASSIST not available and has error codes recorded.
after doing some research ive found that this sometimes happens on these tiguans and people are saying take it dealer. Apparently the coding for the front assist needs altering to work when a towbar is fitted, how true this is i dont know. My knowledge is limited when it comes to coding and i have fitted many kits on older vehice and coded them 1st time and never had an issue, but this is the 1st with front assist fitted
any help, direction, how toos etc would be greatly appreciated.
thanks in advance
tony
here is the scan of the car
Wednesday,15,April,2020,13:55:19:10625
VIN: WVGZZZ5NZKW907464   License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 17 19 22 29 2B 36 39 42 44 4B 52 5F
          69 6C 6D 75 A5 CA D6 D7
VIN: WVGZZZ5NZKW907464   Mileage: 8764km-5445miles
4B-Multifunc. Module -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DFGA)       Labels: None
   Part No SW: 04L 906 026 QR    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H26 6583
   Revision: B4H26---
   Coding: 0119003203461D083000
   ASAM Dataset: EV_ECM20TDI01104L906026QR 004006
   ROD: EV_ECM20TDI01104L906026QR.rod
   VCID: 0A58AAD0AD16C81FF9-805E
17156 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 8764 km
                    Date: 2020.04.15
                    Time: 13:47:28
                    Coolant temperature: 28 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 11.800 V
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
   Part No SW: 5Q0 614 517 EE    HW: 5Q0 614 517 BN
   Component: ESC           H35 0107
   Revision: 00000000    Serial number: 61189000003806
   Coding: 0AEE929A30200B73477B070662C74950490CD0E2E046927534605078D02A4A0B00402F641A1B13111435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 78BCE018C3FACA8F9F-802C
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 6102167963
   Coding: 132C2C0623
   VCID: 43C647F4CABC5957FA-8016
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11695078
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K10000    Serial number: 00000B01347364
   Coding: 0012012420211001110510000010102A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 4AD86AD0ED96881F39-801E
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 01001913201274
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CB4FC08F7C2E6AFFB-8028
   Subsystem 1 - Part No SW: 5NC 955 119 A    HW: 5NC 955 119 A  Labels: 1KX-955-119.CLB
   Component: 326 RL 150419  033 0372
   Serial number: 00000001904100304426
   Component: RLHS  052 0107
   Serial number: S4Y19M05D08H02M14S45
   Coding: 00A8DD
   Serial number: 000000000ZY1910518LE
   Serial number: 00000000000047030755
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000004051904220405
541204 - Databus
          [LWR_AFS_01 / 05 Datenbus empfangener Fehlerwert]
                    Reset counter: 212
                    Mileage: 8764 km
                    Date: 2020.04.15
                    Time: 13:49:29
   Part No SW: 3Q0 919 298 E    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0046
   Serial number: 002202197498030
   Coding: 0331663841
   ASAM Dataset: EV_EPHBO2CVW3260000 010019
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 3FCE4B04A6543DB79E-806A
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Coding: 2A0460C358FF8728749C810560408700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
   VCID: 42C842F0D5A6505FF1-8016
1229 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Reset counter: 172
                    Mileage: 8764 km
                    Date: 2020.04.15
                    Time: 13:47:27
                    Voltage terminal 15: 11.7 V
                    Control Module temperature: 51 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_irreversible error
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    007 0403
   Serial number: 003FNR5ANEXO
   Coding: 98CCC0C00C0000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 1366B7B4FA5C09D70A-8046
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1040
   Serial number: 5NC857705C0134T01292
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1040
   Serial number: 5NC857706C0129T01251
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 001 405 19
   Serial number: 3570000000025285FB3N
   Subsystem 4 - Part No SW: -----------    HW: 480 001 405 19
   Serial number: 35800000000418700C38
   Subsystem 5 - Part No SW: -----------    HW: 480 401 605 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001BAF00135445C.
   Subsystem 6 - Part No SW: -----------    HW: 480 401 505 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001A8F00135425F-
   Subsystem 7 - Part No SW: -----------    HW: 480 401 405 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001B4F0275A3176%
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 505 19
   Component: PedP_Sensor_D  005 6149
   Serial number: 2280001B6EFE7864D36Y
   Subsystem 9 - Part No SW: -----------    HW: 480 401 505 19
   Component: PedP_Sensor_P  005 6149
   Serial number: 2290001BCEE9B784281T
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 401 805 19
   Component: PedP_Sensor_C  005 6149
   Serial number: 2300001BEEFE7864B88/
   Subsystem 11 - Part No SW: -----------    HW: 480 001 305 19
   Serial number: I0M000000006EB18CB3K
   Subsystem 12 - Part No SW: -----------    HW: 480 001 305 19
   Serial number: I0N0000000000B18CB31
   Part No SW: 5NA 920 790 D    HW: 5NA 920 790 D
   Component: KOMBI         509 1701
   Coding: 24A400106F840600018863031001000800000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4368
   Revision: --------    Serial number: 0009522510
   Coding: 030500045F087300FB07225E0A0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 6E90C640B1BE843F45-803A
Component:0-00-00-00-00
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 36190000669010039174
   Coding: 2CFFFF
   Serial number: 3835681205
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00017.04.19
   Coding: 0101
   VCID: 4CD46CC8E7E2962F0B-8018
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45C259ECC4886767D4-8010
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 19000127407007
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 332617349A1CE9D76A-8066
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0007SDR33028
   Coding: 0014000000000500018280808180000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D32310CAC582FA78C-8068
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS002 0287
   Serial number: YE007SDO1338B
   Coding: 003F1A20D201048000001000
   VCID: 44C444E8CFB25E6FC3-8010
   Subsystem 1 - Part No SW: 5Q0 959 408 A    HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000030073997
   Coding: 0D0000
   Part No SW: 5QF 909 144 B    HW: 5QF 909 144 A
   Component: EPS_MQB_ZFLS  507 5582
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 49DA55DCE890830730-801C
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0345
   Serial number: 30041910800676
   Coding: 00000005090008CE01104F010A0000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3522292C9468F7E744-8060
13706046 - Databus
          [LV_Abblendlicht_li_def received error value]
                    Reset counter: 212
                    Mileage: 8764 km
                    Date: 2020.04.15
                    Time: 13:49:29
13706047 - Databus
          [LV_Abblendlicht_re_def received error value]
                    Reset counter: 212
                    Mileage: 8764 km
                    Date: 2020.04.15
                    Time: 13:49:29
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS002 0287
   Serial number: YE007SE71478D
   Coding: 003F1020DE01048000001000
   Subsystem 1 - Part No SW: 5Q0 959 407 A    HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000030097805
   Coding: 050000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0891
   Coding: 02730601FF00000051110101008808001F0506E6012000008E
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 322812306506E0DF61-8066
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHW1323745
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: ConWysTrailer H14 0137
   Serial number: 00000181563668
   Coding: 0100000200000000
   VCID: 393A251CB8701387A0-806C
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG053320
   Coding: 01230600820F20000000408C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   Part No SW: 5Q0 959 107 T    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0271
   Revision: --------    Serial number: A2-C748-5840-9
   Coding: 0A28
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 02230601EA42380D3F1CBE020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW37.rod
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H10 0610
   Serial number: 18011915P22537
   Coding: 000307060000040100021344C150A90094000E20004000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002_VW37.rod
   VCID: 40CC48F8DBAA424FE7-8014
1123187 - Local Data Bus
          U116B 00 [009] - Received Malfunction Value
                    Reset counter: 172
                    Mileage: 8764 km
                    Date: 2020.04.15
                    Time: 13:47:27
                    Control Module temperature: 32 °C
                    Outside air temperature: 17.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 991.2 s
                    Voltage terminal 15: 11.6 V
                    mid: 02 C0
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
   Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Coding: 708040732602
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75A2E92CD4E8B7E784-8020
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 004C88F89B2A824FA7-8054
0773 - Supply Voltage for Low-Beam
          C11FD 13 [040] - Open Circuit
                    Reset counter: 0
                    Mileage: 8764 km
                    Date: 2020.04.15
                    Time: 13:49:29
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
                    Reset counter: 0
                    Mileage: 8764 km
                    Date: 2020.04.15
                    Time: 13:49:29
End----(Elapsed Time: 01:50, VBatt start/end: 12.1V/11.9V. VIgn 11.9V)-----
tont.langfield@yahoo.com
Controller Software Versions:
ECU 1 = Engine 6583
ECU 2 = ABS Brakes 0107
ECU 3 = Acc/Start Auth. 1204
Sub ECU 3 > 1 = Acc/Start Auth. 0906
ECU 4 = Auto HVAC 4301
Sub ECU 4 > 1 = Auto HVAC 0201
ECU 5 = Cent. Elect. 0273
Sub ECU 5 > 1 = Cent. Elect. 0372
Sub ECU 5 > 2 = Cent. Elect. 0107
Sub ECU 5 > 3 = Cent. Elect. 0316
Sub ECU 5 > 4 = Cent. Elect. 0314
Sub ECU 5 > 5 = Cent. Elect. 0070
ECU 6 = Park/Steer Assist 0046
ECU 7 = Auto Dist. Reg 0342
ECU 8 = Airbags 0403
Sub ECU 8 > 1 = Airbags 1040
Sub ECU 8 > 2 = Airbags 1040
Sub ECU 8 > 3 = Airbags 0887
Sub ECU 8 > 4 = Airbags 0887
Sub ECU 8 > 5 = Airbags 6149
Sub ECU 8 > 6 = Airbags 6149
Sub ECU 8 > 7 = Airbags 6149
Sub ECU 8 > 8 = Airbags 6149
Sub ECU 8 > 9 = Airbags 6149
ECU 9 = Instruments 1701
ECU 10 = CAN Gateway 4368
Sub ECU 10 > 1 = CAN Gateway 0052
Sub ECU 10 > 2 = CAN Gateway 9070
ECU 11 = AWD 7084
ECU 12 = Left Light 0014
ECU 13 = Steer. Col. Lock 0020
ECU 14 = Seat Mem. Drvr 0024
ECU 15 = Right Light 0014
ECU 16 = Door Elect, Driver 0287
Sub ECU 16 > 1 = Door Elect, Driver 0010
ECU 17 = Steering Assist 5582
ECU 18 = Multifunc. Module 0345
ECU 19 = Door Elect, Pass. 0287
Sub ECU 19 > 1 = Door Elect, Pass. 0010
ECU 20 = Information Electr. 0891
Sub ECU 20 > 1 = Information Electr. 8130
Sub ECU 20 > 2 = Information Electr. 1030
ECU 21 = Trailer 0137
ECU 22 = Back-up Cam. 0608
ECU 23 = Trunk Elect. 0271
ECU 24 = Telematics 0825
ECU 25 = Frt Sens. Drv. Assist 0610
ECU 26 = Sunroof 0002
ECU 27 = Light Ctrl Left 2 0008
ECU 28 = Light Ctrl Right 2 0008
Alternator data: Bosch  - 110 Amp
PetrolDave
Westbury, UK
C?ID=1423
Welcome Tony good first post, however can I suggest that you keep your VCDS up-to-date as the version you have used is over a year out-of-date (the current version is 20.4.1).
Tony@beltonmotors
C?ID=362723
hi dave, thanks for the reply, i have updated vcds, the scan was done on the 15th april, but due to covid and lock down we have only just got back to work on the car... and ive updated to 20.4.1....
I'm thinking coding in the ACC module should probably be adjusted to include "Control Module for Trailer Recognition installed". It's in Byte 3.
DV52
C?ID=194404
^^^^ Tony: apropose of the DTC in the ECU on your auto-scan, I note that the long-code string is like this:
Byte	Hex	Binary
0	01	00000001
1	19	00011001
2	00	00000000
3	32	00110010
4	03	00000011
5	46	01000110
6	1D	00011101
7	08	00001000
8	30	00110000
9	00	00000000
6	1D	00011101
7	08	00001000
8	30	00110000
9	00	00000000
I've highlighted Byte 5, Bit 4 in the ECU. On my database for MQB build vehicles, this software switch has the descriptor trailer installed. If the problem persists after implementing Uwe's fix (i.e. Byte 3, Bit 3 in the hex13 module) -try setting this Bit, then try clearing the DTC- maybe?
NEtech
C?ID=56995
Pleas post a new Autoscan after your changes.
Tony@beltonmotors
C?ID=362723
hi don and ewe, many thanks for your reply, now i am very new to this coding practice and therfore my knowledge is not up to speed yet. from your suggestion don, i go into the main engine management ecu and into long coding and change byte5 bit 4 from a 0 to a 1 and similarly in ewes suggestion but within the acc module.. is there an instruction on how to do this.....many thanks for your help, this a steep learning curve as i am new to coding and the functions of vcds....tony
DV52
C?ID=194404
Tony: I've divided my very impromptu instructions for the ECU part into two bits; a set of pictures (referenced by numbers 1-4) and some words that relate to numbered pictures.
The words are as follows
  1. Picture 1: This is the ECU main screen. Select Coding - 07
  2. Picture 2: you should see the numbers shown in the Current coding box. Select Long Coding Helper
    Picture 3:The numbers shown on your screen will be different. By clicking on successive black boxes on the line the starts with the grey 3), navigate to Byte 5. Place a tick in Bit 4 - then click on the X on the extreme top RHS to close the screen
  3. Picture 4:If you have made the correct changes, you should see the exact number shown in the New Coding box (notice that highlighted 5 is the digit that you changed -it's in a hexadecimal number base). Only if this number appears, select Doit!!
The numbered pictures look like this:
Uwe's suggested change follows exactly the same process but with the hex13 module - which is Auto Dist. Reg.
When you get to Picture 3, navigate to Byte 3 and place a tick in Bit 3 which should have the descriptor Control_module_for_towing_sensor.
If you have made the changes correctly, the number in the New coding box in Picture 4 should be 2A0460CB58FF8728749C810560408700000000000000000000 (notice the highlighted digit)
The number in the Current coding box is: 2A0460C358FF8728749C810560408700000000000000000000
Hope this makes sense!!
Tony@beltonmotors
C?ID=362723
hi don...wow thank you so much for your reply...and detailed how too... and i actuallu understand it....LOL... the vehicle is back in the workshop tomorrow so i will be working n it then and will update with new scan and screen shots. fingers crossed it will rectify the issue.
On another related note, by changing the bit, what is it actually doing to those systems, i presuming its altering the characheristics for when the vehicle is towing something, the abs, front assist etc...
and also how do you know what bit changes what in the hex code, is there and info source or somewhere i can research study this.
Again thanks to every one who has helped so far and i will update some point tomorrow with the progress of the fix
DV52
C?ID=194404
On another related note, by changing the bit, what is it actually doing to those systems, i presuming its altering the characteristics for when the vehicle is towing something, the abs, front assist etc...
Tony: I had suspected that you might be a bright boy (meaning that your IQ is on the RHS of the normal distribution bell-curve) - if you have understood my instructions, it confirms my suspicion!!;)
As for your very, most-excellent questions - you are getting into an area that has puzzled me for many years. I was told by a wise professor early in my youth (now many years ago) that if a person can't explain a construct in simple terms, then he/she really doesn't understand it!! Such is the case with your question - but nevertheless, here goes:
At its very base, your question goes to the heart of difference between the 2 x principal features that can be altered with a VCDS cable/dongle; adaptation channels and separately, long code. When I first joined this forum, one of my inaugural questions was - what's the difference between these 2 x facilities, or asked another way, how do the design engineers @ VAG decide which activity in the module is allocated to either category? To date, and despite a number of quite erudite responses from RT, that answer still evades me!!
However, and IMO of course, there may be some insights into the underlying nature of these function by virtue of their structure and the descriptors for each Bit/channel - perhaps? Long code's structure is relatively simple; it consists of a number of Bytes and within each Byte there are 8 x binary Bits. The relationship between Bytes and Bits are mathematical and historic and can't be altered.
The usual analogy is to think of Bytes as being switch-banks and to consider Bits as individual switches within these banks - but in this case, these are software switches rather than mechanical single-pole, singe-throw switches. Although not strictly true in all cases, there is evidence that the design boffins attempt to cluster the functions in each Byte according to their purpose (i.e. the software switches for the rotary light switch in your car, the LDS, are all congregated into the same Byte)
Anyhow, for want of a better answer as to what is the raison d'etre of long code and adaptation channels, my uneducated guess is that at least up until quite recently, long code was intended as a manufacturing production line decider and adaptation channels were meant to be decision variables related to the internal workings of the module itself. I repeat again (tautology intended) - this is a guess and it should be pointed-out that in some newer modules, there has been a tendency to transfer long code switch functions into adaptation channels.
So - what happens when a long code Bit is changed? Well, in essence control modules appear to be multi-purpose devices that are able to accommodate various buyer options. The state of the Bits in the module's long code (i.e. the OFF/ON state of each software switch) seems to tell the module which particular option is installed in the car (it's called a PR code) and therefore which peripheral equipment the module must control.
Your trailer exercise is a case in point - before the install, the modules were told to not bother to run their internal software routines for trailer control - after the install, stuff changed when the CAN network recognized that a trailer module was registered in the Gateway installation list. Adding the hex69 module to the CAN network wasn't enuff because other modules were affected in the trailer function - hence a DTC resulted from not switching-on the trailer related software routines in the ECU and hex13 module.
As to your final question about what bit changes what in the hex code - for those of us who are mere mortals, we must rely on the descriptors next to those Bits that are populated with words. I suspect that the wizened troglodytes that work feverishly in the dungeons of RT's HQ have secrets that only the Ross Tech deities know - but alas we users are not so privileged! I'm only kidding, I'm certain that with the introduction of the "yellow" long code helper screens, we have as much information about the the Bit function that is available.
Tony@beltonmotors
C?ID=362723
hi don, again thank you for your reply... and the detailed info...so s i type this i have just jumped into the tiguan and am about to attempt the coding suggestions...so we will see if my intelligence is on the RHS.....lol:eek:
here goes....
as for the ins and outs of coding, its something i have only more recently started to gain an interest in, ive done basics coding new modules, injectors, etc in and many towbars but this s the first at this level...
from what i can gather this tiguan was pre registerd so the customer bought it from a fore court and did not order it. Also i have discoverd tat when the car was orderd it could have been orderd towbar ready for want of a better description. So from this im presuming that the modules that have errors would already be expecting to see a trailer module...so in your previous message where you mentioned the difference between adaption channels and long coding that this would have been part of production line decider, this being that the car would have been set as trailer module ready.....or am i way of here
thanks again don
tony
Tony@beltonmotors
C?ID=362723
FIXED FIXED FIXED FIXED
hi again do, ok you sir are a legend and shout out to ewe, i followed your excellent instructions both with your and ewes suggestion and done... lights off all working no fault codes stored....brilliant...its given me confidence to pursue this coding more...
HOWEVER
allthough all the lights are off this is now the new vehicle scan after coding
Friday,10,July,2020,12:17:20:10625
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WVGZZZ5NZKW907464   Mileage: 10454km-6495miles
   Revision: B4H26---
   Coding: 0119003203561D083000
   VCID: 0A58AAD0AD16C8D655-805E
17156 - Databus
          U1123 00 [038] - Received Error Message
                    Mileage: 10454 km
                    Date: 2020.07.10
                    Time: 12:04:14
                    Coolant temperature: 38 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 11.960 V
   VCID: 78BCE018C3FACA4633-802C
   Coding: 132C2C0623
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43C647F4CABC599E56-8016
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 4AD86AD0ED9688D695-801E
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7CB4FC08F7C2E66657-8028
   Coding: 00A8DD
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 231
                    Mileage: 9827 km
                    Date: 2020.06.16
                    Time: 13:04:57
   Coding: 0331663841
   ROD: EV_EPHBO2CVW3260000_VW37.rod
   VCID: 3FCE4B04A6543D7E32-806A
12664896 - Databus
          [Bildverarbeitung - ARA_Sensor_02 - kein Signal/keine Kommunikation]
                    Reset counter: 250
                    Mileage: 9827 km
                    Date: 2020.06.16
                    Time: 07:14:17
   Coding: 2A0460CB58FF8728749C810560408700000000000000000000
   VCID: 42C842F0D5A650965D-8016
1067 - Databus
          [FAULT_TIMEOUT_MOTOR_20]
                    Reset counter: 16
                    Mileage: 10454 km
                    Date: 2020.07.10
                    Time: 12:03:17
                    Voltage terminal 15: 11.9 V
                    Control Module temperature: 43 °C
                    Longitudinal acceleration: 0.34 m/s²
1088 - Databus
          [FAULT_TIMEOUT_TSK_06]
                    Reset counter: 16
                    Mileage: 10454 km
                    Date: 2020.07.10
                    Time: 12:03:17
2065 - Databus
          [FAULT_TSK_HANDSHAKE]
                    Reset counter: 16
                    Mileage: 10454 km
                    Date: 2020.07.10
                    Time: 12:03:17
196804 - Databus
          [VDY_INPUT_PARAM_ERROR]
                    Reset counter: 16
                    Mileage: 10454 km
                    Date: 2020.07.10
                    Time: 12:03:17
          U1014 00 [008] - -
          [FAULT_CODING_AAG]
                    Fault Frequency: 81
                    Reset counter: 16
                    Mileage: 9827 km
                    Date: 2020.06.15
                    Time: 16:10:02
                    Voltage terminal 15: 11.8 V
                    Control Module temperature: 61 °C
   VCID: 1366B7B4FA5C091EA6-8046
   Coding: 80000D
   Coding: 80000D
          U1014 00 [008] - -
                    Reset counter: 250
                    Mileage: 9827 km
                    Date: 2020.06.16
                    Time: 07:14:17
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E90C640B1BE84F6E9-803A
   Component: 0-00-00-00-00
   Coding: 2CFFFF
   Coding: 0101
   VCID: 4CD46CC8E7E296E6A7-8018
   VCID: 45C259ECC48867AE78-8010
   VCID: 332617349A1CE91EC6-8066
   VCID: 3D32310CAC582F6E20-8068
   ROD: EV_DCU2DriveSideMAXHKLO.rod
   VCID: 44C444E8CFB25EA66F-8010
   Coding: 0D0000
524434 - Databus
          [Message ARA_Status_01 missing]
                    Reset counter: 210
                    Mileage: 9827 km
                    Date: 2020.06.16
                    Time: 07:16:01
   Coding: 931F0000
   VCID: 49DA55DCE89083CE9C-801C
   VCID: 3522292C9468F72EE8-8060
   ROD: EV_DCU2PasseSideMAXHKLO.rod
   Coding: 050000
   VCID: 322812306506E016CD-8066
   ROD: EV_TrailFunctGener2Hella_VW37.rod
   VCID: 393A251CB870134E0C-806C
   Coding: 0A28
   Revision: --------
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40CC48F8DBAA42864B-8014
          U116B 00 [008] - Received Malfunction Value
          [RDR1_Header_FGN_Status]
                    Fault Frequency: 77
                    Reset counter: 16
                    Mileage: 9827 km
                    Date: 2020.06.16
                    Time: 07:22:05
                    Control Module temperature: 29 °C
                    Outside air temperature: 17.0 °C
                    System run time: 455.5 s
                    mid: 02 C0
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
   VCID: 75A2E92CD4E8B72E28-8020
   VCID: 004C88F89B2A82860B-8054
End----------(Elapsed Time: 01:53, VBatt start/end: 14.7V/14.7V)-----------
i have performed a full dtc erase and all have erased
vehicle off and back on...no faults recorded
absolutly brilliant, thankyou all so much....cant wait for the next coding problem
tony
Systemmeister
C?ID=198132
Hi Tony.
I have a 2019 Tiguan Match 4motion manual RHD with losst abs coding.
It would be really useful to know a bit more about the spec of your car if possible please?
I have had a first pass attempt at building up the coding from the very useful spreadsheet on here, but always good to have a means to cross check.
Although I've used vag-com for 20 years on and off, I'm in new territory with the complex long coding deal here.
I will post up my story about why I'm in this mess on a separate post....
MTIA :)
