Hi there
It is car mechanic Majo here currently from New Zealand.
I have problem with my car with diagnostics P177D code after recall from Škoda and they wanted to replace clutch.I have checked the clutch and has been replaced recently.
After I brought my car from service I did service oil in megatronic and gearbox as well.
I replaced correctly.
I have done several times basic setting of trans with VCDS step by step process from http://wiki.ross-tech.com/wiki/index.php/7-Speed_Direct_Shift_Gearbox_(DSG/0AM) and the setting stops on 255 / 59 / 0
May you give me an advice what can I do with please?
I have attached auto-scan data below.
Thank you
Best Regards
Majo Janecek
f; Driftsuspension NZ
www.driftsuspension.co.nz
Driftsuspension.co.nz
Ph +642108361097
P177D
Saturday,27,June,2020,14:04:02:10034
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: TMBCT61Z3B2115154 License Plate:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: TMBCT61Z3B2115154 Mileage: 142910km-88800miles
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LR HW: 03L 906 023 JH
Component: R4 1.6l TDI H43 9977
Revision: --H43--- Serial number:
Coding: 00254014032500080000
Shop #: WSC 73430 031 00064
ASAM Dataset: EV_ECM16TDI02103L906023LR 003012
ROD: EV_ECM16TDI02103L997557A.rod
VCID: 014AACC7902E388E04-8055
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 050 G HW: 0AM 927 769 D
Component: GSG DSG AG7 431 2670
Revision: 00043014 Serial number: CU501305236216
Shop #: WSC 05200 824 180624
VCID: 2D122077B4360CEE90-8079
006013 - Dual Clutch
P177D - 001 - Torque too High - Intermittent
Fault Status: 00100001
Reset counter: 10
Mileage: 142917 km
Date: 2014.11.18
Time: 02:46:57
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 133B201C092300FFC80C04E9901D0081310000
Shop #: WSC 73430 790 00064
VCID: 76A0CF1BC1E00F3621-8023
Part No SW: 3T0 820 047 R HW: 3T0 820 047 R
Component: AC Manuell H16 0401
Revision: 00007001
Coding: 0000000002
ROD: EV_ACManueBHBVW36X_VW46.rod
VCID: 3E30173BA150877639-806B
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 40000AB8E00508C040080080110001E4437000AE526D81605C8440000040
VCID: 383C01238B74B946F3-806D
Subsystem 1 - Part No: 1Z2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 24011 26 0601
Coding: 00D7B7
Component: RLS 070211 05 54 0403
Coding: 0730ED
Address 10: Park/Steer Assist (J446) Labels:| 5J0-919-475.clb
Part No SW: 5J0 919 475 A HW: 5J0 919 475 A
Component: PARKHILFE 4K H11 0005
Revision: --H11--- Serial number: 32991103451236
Coding: 00010E
Shop #: WSC 13765 790 00064
ASAM Dataset: EV_EPHVA14SKxxx0000 001001
ROD: EV_EPHVA14SKxxx0000_001.rod
VCID: 3326360F9A125A1EC6-8067
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q8 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC23B6B
Coding: 0020792
VCID: 3D32103764569C6E20-8069
Subsystem 1 - Serial number: 6332MSME5B510A036
Subsystem 2 - Serial number: 6342MSME5A7532004
Subsystem 3 - Serial number: 6351HSME26262E335
Subsystem 4 - Serial number: 6361HSME26242059+
Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B
Revision: FF010040 Serial number: 20110205100024
Coding: 188A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EB0D73BE1D0477679-802B
Subsystem 1 - Part No SW: 3T0 959 537 HW: 3T0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-URO H07 0012
Coding: 820000
Part No SW: 1Z0 920 843 M HW: 1Z0 920 843 M
Component: KOMBI H20 0420
Coding: 110A00
ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
VCID: 42C863CBD5A8E3965D-8017
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 280111F2002830
Coding: 351303
VCID: 302C390363046106BB-8065
Component: IMMO H20 0420
VCID: 6A98EB6B8D58DBD6B5-803F
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2120
Coding: 0000756
VCID: 48DC71E33B94C9C683-801D
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 34243513571C5D26DF-8061
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000756
VCID: 47DE72DF368AC6BE8A-8013
Part No SW: 1Z0 035 152 E HW: 1Z0 035 152 E
Component: Radio 007 0010
Revision: R0000000 Serial number: SKZAZ5L1527966
Coding: 050004000001
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 3228330BAD085316CD-8067
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 3326360F52125A1EC6-8067
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669351259
Coding: 0200000001010110
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 6288834B756883967D-8037
End----------(Elapsed Time: 01:02, VBatt start/end: 12.7V/12.6V)-----------
Thank you
Best Regards
Majo Janecek
Ph +642108361097
