VW caddy converted from 7DSG to manual Gearbox
Mohammad
Palestine
C?ID=383900
Hello everyone i need help convert VW caddy from automatic to manual Gearbox
what is the sgo file number that can i use to flash ecu and how can i recoding the abs !
i attached full scan and advanced id for ecu
regards
Monday,29,June,2020,18:48:18:06524
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WV2ZZZ2KZBX227218   License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56
VIN: WV2ZZZ2KZBX227218   Mileage: 111170km-69077miles
02-Auto Trans -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 FK    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 9970
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00254014032400080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023FK 003010
   ROD: EV_ECM16TDI02103L997557M.rod
   VCID: 74B026578E3AB86B473-8020
6088 - No Communication with Transmission Control Module
          U0101 00 [167] - -
                    Mileage: 111170 km
                    Date: 2020.06.29
                    Time: 04:56:03
                    Engine speed: 782.00 /min
                    Normed load value: 23.9 %
                    Coolant temperature: 95 °C
                    Intake air temperature: 42 °C
                    Ambient air pressure: 900 mbar
                    Voltage terminal 30: 13.779 V
                    Driver request torque-TQI_DRIV_SUB: 0.00 Nm
                    Control Module temperature-TECU: 60 °C
Readiness: 0110 1000
Address 02: Auto Trans
   Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
   Revision: 00H31001
   Coding: 623C600D09240301460D06E59021C041300000
   Shop #: WSC 35110 377 00159
   VCID: 75B61B5385C0A16370D-8020
                    Reset counter: 217
                    Mileage: 111138 km
                    Date: 2014.11.20
                    Time: 02:28:23
                    Count: 3
                    Count: 14
                    Count: 29184
                    Count: 8195
                    Count: 49152
                    Count: 256
                    Count: 512
   Part No SW: 7N0 907 426     HW: 7N0 907 426
   Component: AC Manuell    H15 0101
   Revision: 00010001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW32.rod
   VCID: 71BE2F43F1288D43AC5-8024
   Part No SW: 2K5 937 086 B    HW: 2K5 937 086 B
   Component: BCM PQ35 M+   011 1044
   Revision: BD011001
   Coding: 401A0A3A80251A6B088800829400816443517288526F8160648000000040
   VCID: 3536DB53C540E163B0D-8060
   Subsystem 1 - Part No: 1T1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 08101  26  0512
   Coding: 009795
   Component: RLS 051010 05  54  0403
   Coding: 0330ED
                    Reset counter: 217
                    Mileage: 111170 km
                    Date: 2014.11.20
                    Time: 04:56:02
                        Term 15 On
                    Voltage: 13.90 V
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 L    HW: 1K0 919 475 L
   Component: PARKHILFE     005 1806
   Revision: 00005000    Serial number: 0 263 004 450
   Coding: 108101
   VCID: 3B22CD6BE3643713469-806E
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag013 H06 0013
   Revision: --------    Serial number: 003HN0019ZMO
   Coding: 000000000000000000000000000000003133
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3332E54BCBB4FF539E9-8066
   Serial number: 3495RRB405H00IUGJ9F4
   Serial number: 3505RRB4065010DAEA0C
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90440JJD0002H
   Coding: 1882160000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B41C5F9846AA7B797-8022
   Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H07 0013
   Serial number: 0026504
   Coding: 820000
0516 - Databus
                    Reset counter: 217
                    Mileage: 111170 km
                    Date: 2020.06.29
                    Time: 04:56:02
   Part No SW: 2K0 920 875 A    HW: 2K0 920 875 A
   Coding: 181A00
   VCID: 2D06F3332D90A9A3C8D-8078
12648704 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Getriebe: keine Kommunikation]
                    Reset counter: 217
                    Mileage: 111170 km
                    Date: 2020.06.29
                    Time: 04:56:02
Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 141010F1002559
   Coding: EDA01F0600020200007400
   VCID: 6D863333E19069A388D-8038
                    Reset counter: 217
                    Mileage: 111170 km
                    Date: 2014.11.20
                    Time: 04:56:03
   VCID: 6A8C382FDCFE7E9BEDF-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2109
   Coding: 0000048
   VCID: 48C8A2A7AEB26C8BDBB-801C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 140    3001
   Revision: 00H17000
   VCID: 313EEF433D28CD43EC5-8064
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000048
   VCID: 47CAA19BA3AC63F3D21-8012
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: RCD310 EU     H13 5042
   Revision: -----05S    Serial number: VWZ4Z2K1366256
   Coding: 0500040002
   VCID: 65964B13356051E3C0D-8030
                    Fault Status: 01101011
                    Reset counter: 217
                    Mileage: 111170 km
                    Date: 2014.11.20
                    Time: 04:56:01
End----------(Elapsed Time: 00:58, VBatt start/end: 13.8V/13.8V)-----------
Monday,29,June,2020,19:05:40:06524
VCDS Version: Release 20.4.1 (x64)
                Address 01: Engine
Control Module Part Number: 03L 906 023 FK
  Component and/or Version: 1,6l R4 CR td H43 9970
           Software Coding: 00254014032400080000
            Work Shop Code: WSC 35110
Advanced Identification/FAZIT
     Identification: SJ8-FST
     Revision: --H43---
     Date: 16.10.10
     Manufacturer number: 0015
     Test stand number: 0686
Flash Status
     Programming Attempts(application): 2/3/2
     Successful Attempts(application): 2/2/2
     Programming Status: 00000000
     Flash Date: 00.00.00
Misc.
     Hardware number: 03L 907 425 C
     Workshop System Name: J623
     ASAM Dataset Revision: 003010
Car Info
     Chassis Number: WV2ZZZ2KZBX227218
     Engine code: CAYD
VCDS Info:
       Labels: 03L-906-023-CAY.clb
       Readiness: No script available
NZDubNurd
New Zealand
C?ID=230482
Untick "Auto trans" in the CAN Gateway installation list, for a start.
The Engine ECU will most probably need to be changed to a manual version (or possibly flashed), and the ABS error will probably disappear then.
dnoermann
C?ID=358118
You have this Engine:
03L 906 023 FK ==>
- CAYD
- 7MG (EU5)
- G1C (DSG 7 Gears)
- 7L3 ( Without Start / Stop)
I think you want this:
03L 906 023 DB ==>
- CAYD
- 7MG (EU5)
- G0C (Manual 5 Gears)
Regarding ABS Coding you have to search VCDS Scans, to see the difference ....
