Hello
i have 2011 Audi A8 D4 4.2
and I have done full facelift conversation
everything is working fine low beam high beam DRL
except I have DTC on dash
can someone help me with getting rid of it
here is a full scan done via VCDS and the fault codes
Sunday,28,June,2020,00:53:28:64472
VIN: WAURVB4H0BN017775 License Plate: 111199
Mileage: 77441km-48119mi Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 20 28 34 36 3B 42 46
52 53 55 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
VIN: WAURVB4H0BN017775 Mileage: 77441km-48119miles
Address 01: Engine (------CDRA) Labels:* None
Part No SW: 4H0 907 560 B HW: 4H0 907 560
Component: 4.2l V8/4V H07 0004
Revision: N5H07---
Coding: 01060003290F0168
Shop #: WSC 99900 715 137177
ASAM Dataset: EV_ECM42FSI0114H0907560B 001004
ROD: EV_ECM42FSI0114H0907560B.rod
VCID: 290FF817B9769FC3245-807C
7144 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [044] - -
[Diagnostic interface for databus -J533-please read DTC]
Fault Frequency: 15
Mileage: 77306 km
Date: 2020.06.20
Time: 02:43:30
Engine speed: 695.50 /min
Normed load value: 26.3 %
Coolant temperature: 97 °C
Intake air temperature: 54 °C
Voltage terminal 30: 13.169 V
AFS dm: 22.3 kg/h
Median injection timing: 1.080 ms
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4H1 927 158 AD HW: 0BK 927 156 K
Component: 0BK 42 FSIRdW H08 0001
Revision: --H08---
Coding: 001111
Shop #: WSC 02313 785 00200
ASAM Dataset: EV_TCMALX51011 001013
ROD: EV_TCMALX51011_001.rod
VCID: 72BDDF7B54209C1B55F-8026
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 B HW: 4H0 907 379 B
Component: ESP PREMIUM H10 0273
Coding: 44E6E20022674700E300
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremi 005006
ROD: EV_ESPPremi_005_AU64.rod
VCID: 313F107791A6E703EC5-8064
Part No SW: 4H0 907 064 GB HW: 4H0 907 064 GB
Component: BCM2 2.0 H37 0572
Coding: 05872F00000000000000
Shop #: WSC 48154 001 1048576
VCID: 6FBBD60F4792B1F3BA1-803A
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2310000091594004
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00001002289116
Coding: 0018320000043201000001010101112131313333283333
VCID: 343119636E34D22B873-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 C HW: 4H0 820 043 C
Component: Klima 4 Zonen H14 0061
Coding: 4801227888
VCID: 2019E533CA4C5E8B73B-8074
0291 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 85
Mileage: 77306 km
Date: 2020.06.20
Time: 02:43:13
0314 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 85
Mileage: 77306 km
Date: 2020.06.20
Time: 02:43:13
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 GK HW: 4H0 907 063 EK
Component: BCM1 2.0 H20 0369
Revision: 2502003S Serial number: 00001757850202
Coding: 52EBF2FD504581E19982D084A0005F00009EC30826084101800000166111170001000000090000
VCID: 77ABEE6F3FC2F933621-8022
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 110202 H32 0040
Serial number: 110204023652
Coding: 025523
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10046959
Coding: 035523
Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B
Component: E1 - LDS H07 0044
Serial number: 27 01 2011 00000328
Subsystem 4 - Part No SW: 4H0 907 705 J HW: 4H0 907 705 C
Component: EVLS-SG H08 0280
Serial number: WA102032000000169493
Coding: 020300
7 Faults Found:
Reset counter: 91
Mileage: 77306 km
Date: 2020.06.20
Time: 02:36:53
Reset counter: 91
Mileage: 77306 km
Date: 2020.06.20
Time: 02:36:53
03455 - Function Restriction due to Faults in Other Modules
Fault Frequency: 18
Reset counter: 91
Mileage: 77306 km
Date: 2020.06.20
Time: 02:36:54
Reset counter: 85
Mileage: 77306 km
Date: 2020.06.20
Time: 02:43:37
Reset counter: 85
Mileage: 77306 km
Date: 2020.06.20
Time: 02:43:37
Reset counter: 85
Mileage: 77306 km
Date: 2020.06.20
Time: 02:43:38
Reset counter: 85
Mileage: 77306 km
Date: 2020.06.20
Time: 02:43:38
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
VCID: 2313EA3FDBDA45936E9-8076
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 H HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0030
Revision: 11001001 Serial number: 55901102001744
Coding: 300102
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 372B2E6F7FC23933A21-8062
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG001HBC-
Coding: 30314246323430303034554A304C34483053
VCID: 3635236B78C8C03BB97-8062
Serial number: 3575HRB406506JDCA1AW
Serial number: 3585HRB404T07OTS9GLW
Serial number: 3515JRB405109U26P0UB
Serial number: 3525JRB405109U26KORS
Serial number: 3554VRB405T09GGSD8GF
Serial number: 3564VRB405P09GGS215Q
Part No SW: 4H0 953 568 A HW: 4H0 953 568 A
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815KB300051
Coding: 000034
VCID: 313F10779126E703EC5-8064
Subsystem 1 - Part No SW: 4H0 951 528 G HW: 4H0 951 528 G
Component: E221 - MFL H04 0009
Serial number: 16 10 2010 33025330
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4H0 920 900 C HW: 4H0 920 900 E
Component: TBenRDW------ H30 0297
Revision: 26110011 Serial number: 658010211593036
Coding: 53A708001B000008010000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU64.rod
VCID: 2313EA3FDB5A45936E9-8076
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 G HW: 4H0 919 204 G
Component: Analoguhr D4 H05 0224
Serial number: 1110127000776
Part No SW: 4H0 907 468 AE HW: 4H0 907 468 AC
Revision: -------- Serial number: 00000001106481
Coding: 00E5074800
Shop #: WSC 02729 823 28888
VCID: 74B1D9632E34922B473-8020
Voltage stabilizer:
0272 - Local Databus
U1030 00 [009] - Electrical Malfunction
Fault Frequency: 11
Reset counter: 91
Mileage: 77306 km
Date: 2020.06.20
Time: 02:33:21
Voltage terminal 30: 12.6 V
Voltage terminal 15: 12.6 V
Control Module temperature: 49 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 04018B6B74745D545420363E
VCID: 33331A7F6B3AD5139E9-8066
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 C HW: 4H0 919 158 C
Component: Klima Fond H14 0062
Coding: 0000000000
ROD: EV_AirCondiHeck.rod
VCID: 303915739AACEE0BE3B-8064
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4H0 907 553 C HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0096
Coding: 008000
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_VW51.rod
VCID: 2C010103B6848AEBDF3-8078
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00001002289114
Coding: 00183B0000053201000001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 HW: 4H0 907 637
Component: SARA 6D H02 0015
Revision: -------- Serial number: EJ1BPA3100BU2+0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 6C81C10376044AEB9F3-8038
Part No SW: 4H0 959 793 E HW: 4H0 959 793 E
Component: TSG FA H02 0162
Revision: -------- Serial number: 0000112569279
Coding: 011F1E205E0062C202080006
VCID: 3B23325F436A1D53469-806E
Revision: 00002001 Serial number: 0420708917
Coding: 011A0E2000B93585B330C7C00A0100000000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.028 H06 0006
Serial number: WOO1121203R
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 G HW: 4H0 947 135 G
Component: DACHELEKTRONI H11 0080
Serial number: H2011000000000005247
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS009 H05 0004
Serial number: WOO1000BH25
Part No SW: 4H0 959 792 E HW: 4H0 959 792 E
Component: TSG BF H02 0162
Revision: -------- Serial number: 0000112597191
Shop #: WSC 02312 785 00200
VCID: 3A2D375B4C50245B5DF-806E
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000038043
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0D071BBC7094DB2DF-807E
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Component: MxB-ECU 001 0100
Coding: 02B602102A200200
VCID: 343119636EB4D22B873-8060
Subsystem 1 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7530
Coding: E00200
Subsystem 2 - Part No SW: 7PP 941 472 F HW: 7PP 941 472 F Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7530
Coding: E00200
5334529 - Fan for Left Headlamp
C1166 01 [137] - Electrical Failure
Fault Frequency: 18
Reset counter: 91
Mileage: 77306 km
Date: 2020.06.20
Time: 02:36:08
Part No SW: 4H0 035 056 J HW: 4H0 035 056
Component: Radio U STD H52 0133
Revision: AB001007 Serial number: 439BZ0B7508038
Coding: 070003020100000001
VCID: 290FF817B9F69FC3245-807C
Part No SW: 4H0 035 754 T HW: 4H0 035 754 C
Component: H-BN-RW H41 0939
Revision: -------- Serial number: 062BH0B7504121
Coding: 020400000301F1EF47108F0E00000003FC0001000000000000
VCID: 38292D53725C364BABB-806C
Subsystem 1 - Part No: 8R0 060 884 BN
Component: ROW 2014 0605
Subsystem 2 - Part No SW: 4H0 919 604 C HW: 4H0 919 604 C
Component: DU8 D4 SV NB H46 0021
Serial number: AUZ8ZDB1100CUJX
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000027927
Component: CD-Database 2712
Reset counter: 85
Mileage: 77306 km
Date: 2020.06.20
Time: 02:35:28
Text: DU902A,Front,M,0,0,6
03175 - Invalid Data Set
Reset counter: 85
Mileage: 77306 km
Date: 2020.06.20
Time: 02:35:27
Voltage: 12.60 V
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 A HW: 4H0 959 795 A
Component: TSG HL H04 0162
Revision: -------- Serial number: 0000112451161
Coding: 010F1E20400062C202080006
VCID: 392F285749562F43545-806C
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 HW: 4H0 907 441
Component: SG Rueckfahrkamera 0030
Revision: --H04--- Serial number: 525 PA8J0ZD0MF
Coding: 1020003
VCID: 6597B427996E7BA3C0D-8030
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 P HW: 4H0 959 107 M
Component: HDSG-Modul H11 0036
Revision: 10011001 Serial number: 020100307
Coding: 0210044000
ROD: EV_DeckLidContrUnit.rod
VCID: 3B23325F43EA1D53469-806E
0051 - Hall Sensors in Motor 1 for Rear Lid
B1211 12 [008] - Short to Plus
Reset counter: 131
Mileage: 77440 km
Date: 2020.06.27
Time: 00:10:31
Voltage terminal 30: 13.88 V
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000022154
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6393AA3F9BDA05932E9-8036
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H04 0162
Revision: -------- Serial number: 0000112451164
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H05 0081
Revision: 0L0D5012 Serial number: SN101216 0524
ASAM Dataset: EV_GSM2x3Mono 001014
ROD: EV_GSM2x3Mono_AU64.rod
VCID: 2B03021FB38A8DD3D69-807E
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00456606063301
Coding: 660FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F3B160F8792F1F3FA1-807A
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00456606073702
Coding: 260FF2
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 00060000031F000000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 6FBBD60F4712B1F3BA1-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
VCID: 70B9D5735A2CAE0BA3B-8024
End----------(Elapsed Time: 02:51, VBatt start/end: 12.3V/12.3V)-----------
