2015 Audi A6 - Aircon Failure
Ben Pine
C?ID=403180
Hi All,
I bought my Ross Tech HEX-V2 device a month or so ago and I am loving what I can do with it.
I originally bought it as I had multiple lights on my dash which turned out to be a faulty wheel sensor. I've since replaced this and erased the DTC's without any further issues however I've now got an aircon fault which has started on the hottest day of the year... always the case!!!
Could someone help me identify what the problem is? I have a fault code but don't know how to identify what it actually means - is there a list anywhere? Also any advice on how to check the pressures or any other part of the system using vcds would be very welcome
As you can probably tell I am very new to this.
Ben
Thursday,25,June,2020,18:38:26:25046
VIN: WAUZZZ4G2GN055827   License Plate:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 47 52 53 55
          5F 62 6D 72 AC
VIN: WAUZZZ4G2GN055827   Mileage: 145808km-90600miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 1649
   Revision: 85H23---
   Coding: 12254012242401080000
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79AFE8C0895F4FA3145-802C
   Part No SW: 4G1 927 153 B    HW: 0CK 927 156 S
   Component: 0CK 20TDI RdW H03 0002
   Revision: --H03---    Serial number: 0000000057
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002020
   ROD: EV_TCMDL382021_VW51.rod
   VCID: 290FF880397F3F23245-807C
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  HB1 0572
   Serial number: 75117041150160000827
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF4020A10FD7631C5-8014
   Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
   Component: BCM2 2.0      H37 0572
   Coding: 01B9704E000000000000
   VCID: 7BA3F2C883E37DB3069-802E
   Serial number: 3215000117598011
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Component: KLIMA 4 ZONEN H14 0112
   Serial number: 14071500040722
   Coding: 34220978210000
   VCID: 6393AAA81BD3A5732E9-8036
0557 - A/C clutch
          B1488 15 [009] - Open or Short to Plus
                    Reset counter: 52
                    Mileage: 145799 km
                    Date: 2020.06.24
                    Time: 21:01:54
                    Voltage terminal 30: 13.83 V
                    A/C clutch-Remaining run time for play protection: 0.0 s
                    A/C clutch-Status: On
                    A/C clutch-Supply voltage: 13.5 V
                    A/C clutch-Current power consumption: 0.000 A
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001117237701
   Coding: 0105001440349FE041014083000018000F9DC7082F08020100000894E100140200400024030000
   VCID: 71BFD0E0D1AF07E3AC5-8024
   Component: WWS57X 150626  H37 0080
   Serial number:         150701035637
   Coding: 0045F7
   Serial number: 24092399
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 12 07 2015  00000289
   Serial number: E3C8C5B7000000000001
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1005PTCE
   Coding: 30333130313630323639554A305234473053
   VCID: 3B2332C8C3E3BDB3469-806E
   Serial number: 3575HRB405P3H46A3P7C
   Serial number: 3585HRB405H3H46CC1QB
   Serial number: 3515JRB401I53400M9AI
   Serial number: 3525JRB401I534009GKN
   Serial number: 3554VRB40653GAJID8N$
   Serial number: 3564VRB40533GSECD0IV
   Revision: C0068538    Serial number: 90862OG40000A
   Coding: 000035
   VCID: 3B2332C8C363BDB3469-806E
   Serial number: 19 06 2015  D0055417
   Part No SW: 4G8 920 951 E    HW: 4G8 920 951 E
   Component: MDieGb        H43 0604
   Revision: 29450306    Serial number: 658130715592033
   Coding: 33A712000B412600010000
   ASAM Dataset: EV_RBC7KMID 004050
   ROD: EV_RBC7KMID.rod
   VCID: 323D1FEC14A97CFB95F-8066
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung / Adaption]
                    Reset counter: 52
                    Mileage: 145799 km
                    Date: 2020.06.24
                    Time: 21:00:53
   Part No SW: 4G5 907 468 F    HW: 4G0 907 468 AC
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001924747
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 38292DC4F2D596ABABB-806C
   Serial number: 7606347103
   Voltage stabilizer:
   Serial number: 150512000000000001CF
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0021
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 678BBEB8EF6BC953F21-8032
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 11071500040089
   Coding: 22
   VCID: 3D273CD0DDF7B38378D-8068
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720JNZC6
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33331AE8EBB375F39E9-8066
   Coding: 011C16015C01620002080002
   VCID: 47CB5E388FABE953D21-8012
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0026987174
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 392F28C0C9DF8FA3545-806C
   Revision: 00002001    Serial number: 0373922814
   Coding: 013B0622A0B93080C320090400010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Revision: CJ007001    Serial number: 00000000177406
   Coding: 030000
   VCID: 1D67DC507DB7D38358D-8048
   Coding: 011C16015E01620002080002
   VCID: 46D5533C88A1F05B297-8012
   Revision: --------    Serial number: 00000001535140
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070C900D972303C8D-8078
   Coding: 04FE02102A600200
   VCID: 343119F4EEBD72CB873-8060
   Coding: E01E00
   Coding: E01E00
Address 5F: Information Electr. (J794)       Labels: Redir Fail!
   Part No SW: 4G1 035 192 A    HW: 4G1 035 192 A
   Component: RMC Nav Plus  H61 0139
   Coding: 0101010101415B47082B060301020100000000
   VCID: 211FE0A041CFF7637C5-8074
   Subsystem 1 - Part No: 8X0 919 884 H
   Component: P28-50-14.06  0001
   Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464F/0F2718255
   Subsystem 3 - Part No SW: 4G2 919 610 E    HW: 4G2 919 610 E
   Serial number: 90349OG90000W
   VCID: 49CF580099BF1F23C45-801C
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 190501059
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   VCID: 363523FCF8C160DBB97-8062
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 151730179
   ROD: EV_RDCMA00100.rod
   VCID: 2F3B1698079B5113FA1-807A
End----------(Elapsed Time: 01:47, VBatt start/end: 12.9V/13.7V)-----------
HMC
C?ID=28246
Hi Ben Pine,
It means your AC compressor clutch is not powered, although without looking at a some tech info I am surprised it has a clutch and is not variable geometry. So look at your handbook and check the fuses, get a test light and wiring diagram and load test the wiring following the wiring diagram.
Regards HMC
Bruce
Near Philadelphia, PA, USA
Supply voltage to the clutch is measured at battery voltage. Clutch current is zero....
Either there is a blown fuse, or a connection to the clutch has failed, or the clutch has gone bad and is now an open coil, or the least likely is that the drive transistor circuit in the ECU has failed.
Inspect for a blown fuse - need wiring diagrams to figure out which one.
Inspect the wiring for a loose/broken connection.
Test the clutch coil by unplugging the connector and then using DVOM, measure the coil resistance. The value should be found in repair info. At a guess, expect a couple ohms.
If the clutch coil has resistance, then you either have a broken wire back to the control module, a blown fuse, or a failed control module.
For complete wiring information, go to erwin and download the wiring diagrams.
Ben Pine
C?ID=403180
Thanks for the very quick advice gents.
Unfortunately it isn't the fuses :( , that would of been a nice easy fix.
I've never heard of erwin before .... but have found their website so will register and download the drawings
Jef
HQ
Another crappy sketch appears:
Is the wire from terminal T20c/16 to the AC compressor (N25) good? Do you have continuity (ohm test) through the N25 itself?
Ben Pine
C?ID=403180
Hi Jef,
thanks for the info although i'm not sure what an N25 is. :eek:
I do have a clutch on the air con compressor and it spins easily by hand as it should. I have tested the power to the clutch coil and I have power when the air con is switched on. Next job is to test the coil itself... once i can remove the under tray (when the spline sockets are delivered)
Ben
Jef
HQ
https://www.ross-tech.com/training/
Watch the last 2 videos and also print out the Wiring Diagram Training PDF so you can follow along with the video.
0557 - A/C clutch
So the HVAC (J255) is saying is doesn't have a good electrical path from T20c/16 to ground. This electrical path passes right though the AC clutch (N25). So maybe a broken wire? Maybe a rotted terminal? Maybe a burnt up N25? The J255 isn't smart enough to know just what the problem is, but knows along that specific electrical path is not good.
Dana
Western PA, USA
Adding to the above suggestions, even though this is intended for newer systems using N280-Refrigerant Regulating Valve (i.e. variable geometry per post #2) the incandescent light bulb test absolutely applies:
https://forums.ross-tech.com/showthread.php?633-Tis%92-the-HVAC-Season
If N25 (the compressor clutch) has a 2 terminal connector the bulb will allow you to test both the power to the clutch -and- the ground to it. (This helps rule out a problem on the ground side when dealing with a conventional clutch.)
However, if the clutch has a single power wire connector as per Jef's brilliant illustration it would be far less likely that a ground specific problem exists but you might want to use the compressor housing as test light ground rather than another ground source.
Ben Pine
C?ID=403180
Managed to remove the under tray to make sure that I hadn't missed anything ... I hadn't.
The compressor itself was a single wire which had 12v. The grounding on the compressor itself was good pointing to a faulty compressor. I've since replaced this and its all back up and running.
Thanks for all of your help/suggestions.
