Fault Found And No CEL
treefort
Canada
C?ID=380169
Hi there,
I just got back from a drive, did an autoscan and found a p2002 code, but no check engine light. I know it works, so am thinking the computer checks periodically for faults then illuminates? If someone could please enlighten me it would be greatly appreciated.
treefort
Canada
C?ID=380169
Hi, thanks for the replies.
The mechanic just replaced the DPF, sensors and sensor hoses with ones from a car that had 50,000kms on it.
I will run down to the car and get an auto scan. I did save the fault code info which I will attach now. Thank you,
VCDS Version: Release 20.4.1 (x64) Running on Windows 10
                Address 01: Engine       Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 906 019 JT    HW: 03L 907 309 AA
  Component and/or Version: R4 2,0L EDC G000AG  8184
           Software Coding: 0350078
            Work Shop Code: WSC 00066 000 00000
                      VCID: 065596CFE42F0B6B697-8052
008194 - Particulate Trap Bank 1
               P2002 - 007 - Efficiency Below Threshold
                    Fault Status: 01100111
                    Mileage: 120219 km
                    Date: 2014.11.09
                    Time: 10:06:50
                    RPM: 1725 /min
                    Speed: 87.0 km/h
                    (no units): 45.9
                    (no units): 25.5
                    (no units): 1.78
                    Pressure: 87 mbar
                    Pressure: 26 mbar
treefort
Canada
C?ID=380169
Here is the auto scan
Friday,19,June,2020,07:44:06:33381
VIN: 3VWPL7AJ6EM605504   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJ6EM605504   Mileage: 120300km-74750miles
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 906 019 JT    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000AG  8184
   Revision: 12H16---    Serial number:
   Coding: 0350078
                    Mileage: 120219 km
                    Date: 2014.11.10
                    Time: 10:06:50
                    RPM: 1725 /min
                    Speed: 87.0 km/h
                    (no units): 45.9
                    (no units): 25.5
                    (no units): 1.78
                    Pressure: 87 mbar
                    Pressure: 26 mbar
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3524
   Revision: 05551213    Serial number: 00001207150408
   VCID: 2411EC4772D3D97B173-8070
   Revision: 00H31001
   Coding: 114B600C492200FF881006E4921D0042310000
   VCID: 7DA7F923BDF948B338D-8028
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001019
   Coding: 0010004002
   Shop #: WSC 00066 000 00119
   VCID: 7BA3F73BA36D4683069-802E
   Part No SW: 5K0 937 086 R    HW: 5K0 937 086 R
   Component: BCM PQ35 M    122 0173
   Revision: BJ122001
   Coding: AF380E1A802F3EC4008800C17000054449000086535D0520648020200040
   VCID: 43D34FDB9B9DFE430E9-8016
   Component: Wischer 12071  26  0512
   Coding: 009795
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R027RGL
   Coding: 00004E43
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C213427E6E381BB4F3-8068
   Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME684C2178ZZZ+
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME5D4C2178ZZZ3
   Serial number: 3511HSME0754612FZZZL
   Serial number: 3521HSME5A08622FZZZU
   Serial number: 35527SME1D0B7929ZZZS
   Serial number: 35627SME6A5C4A2EZZZ/
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90422MG50019T
   Coding: 188A140000
   Shop #: WSC 00066 000 00213
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B5E60F984F1BEB797-8022
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0354372 FLE 20130624
   Coding: 820000
617735 - Selector Lever Park Position Lock Switch
          B1162 11 [008] - Short to Ground
                    Fault Frequency: 97
                    Reset counter: 92
                    Mileage: 118851 km
                    Date: 2020.06.06
                    Time: 22:29:24
   Part No SW: 5K0 920 873 D    HW: 5K0 920 873 D
   Component: KOMBI         H04 0811
   Coding: 370F00
   VCID: 313F151331A17CD3EC5-8064
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 14081303000380
   Coding: 352002
   VCID: 79AFED33A9D17493145-802C
   Component: IMMO          H04 0811
   VCID: 6A8DC27FDCF7CF0BEDF-803E
   Component: TUER-SG FT    002 0501
   Revision: 13110009    Serial number: 0007218669
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   VCID: 5BE397BB03ADA683669-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1509
   Serial number: 00000008037824
   Coding: 000490
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   VCID: 392F2D33E551B493545-806C
   Component: TUER-SG BT    002 0501
   Revision: 15110009    Serial number: 0007225812
   Coding: 0004B4
   VCID: 5CE194A706A3A1BB6F3-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 C    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1509
   Serial number: 00000007959857
   Coding: 000490
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0006
   Revision: -----06S    Serial number: VWZ4Z6N3620355
   Coding: 05000400040007
   VCID: 2313EF5B7BDDDE436E9-8076
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664719638
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2D323FECD7BF8B5DF-806E
End----------(Elapsed Time: 01:09, VBatt start/end: 12.4V/12.4V)-----------
Please post what OBD2 says in Mode 3 and Mode 9?
Is car FOD modified?
treefort
Canada
C?ID=380169
Hi Jack,
This car is an amalgamated car. Engine from a 2013 wagon and a 2014 body.
Here is the mode 3 and mode 9 info:
Friday,19,June,2020,08:42:58:33381
VCDS Release 20.4.1 (x64):  Generic OBD2
Mode 9 : Calibration Identification
Type 02 - VIN : 3VWPL7AJ6EM605504 (Address E8)
Type 04 - Calibration ID : 03L906019JT 8184 (Address E8)
Type 04 - Calibration ID : 02E300058M  3524 (Address E9)
Type 06 - Calibration Verification Number : D2AAC2D8 (Address E8)
Type 06 - Calibration Verification Number : 00000952 (Address E9)
Type 0A - Controller Name : ECM-EngineControl (Address E8)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Type 0B - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 2630
    Ignition cycle count : 11075
    Conditions completion count / Specified conditions encountered count
         NMHC Catalyst : 608 / 507
         NOx/SCR Catalyst : 0 / 0
         NOx Adsorber : 2691 / 2622
         PM Filter : 2854 / 385
         Exhaust Gas Sensor : 2711 / 2630
         EGR and/or VVT : 3600 / 2624
         Boost Pressure : 3980 / 2630
         Fuel : 3980 / 2630
Friday,19,June,2020,08:43:14:33381
Mode 03: Emission related fault codes
Address 7E8: No fault code found.
Address 7E9: No fault code found.
Hi Jack,
Seems like there is no issue is there, is there a limitation in the car now or any pending DTC's in OBD2 MODE?
Did you try defaulting the cars ECU with reboot and re-code?
So a little FOD? :rolleyes:
treefort
Canada
C?ID=380169
The car seems to be running great. P2002 is in the list of pending DTCs.
I dont think the ECU has been defaulted with a reboot and re-code.
FOD is custom tuning, right? As far as I know it is all stock progamming.
Here is the pending OBD2 DTC codes
Friday,19,June,2020,09:09:50:33381
Mode 07: Pending emission related fault codes
Address 7E8: 1 Fault Found:
P2002 - Particulate Trap Bank 1: Efficiency Below Threshold
Is the new/used DPF or sensors dirty, seems so no?
Here in the USA we are not allowed to install/purchase a DPF or CAT from another vehicle, unless it was tested certified by CARB and or EPA approved I believe?
Not sure if you are aware of this, however, being Salvage in the USA or Rebuilt Salvage is not a means for a void of useful life warranty and the opinion from EPA is in JPPSG?
Did you ever consider you may want to check your EPA laws in Canada & since they often are mirrored in CARB/EPA USA, by contacting your administrator for a legal opinion?
https://forums.ross-tech.com/showth...uot-JPPSG-quot&p=156577&viewfull=1#post156577
treefort
Canada
C?ID=380169
Are you able to read the freeze frame data for the above p2002 code?
I'm just wondering what the two pressures are and the three unitless values. One of the values has to be out of the normal range for the code to pop up, right? Is the first pressure(reading 87mbar) the g450 DPF differential pressure sensor? Do you know what the alarm setpoint is for it?
Thanks Jack.
I just u plugged the battery, shorted the leads and am going for a drive on the highway to see what happens. Will keep you updated.
Thanks Jack.
REREAD.......amended.....
https://forums.ross-tech.com/showth...und-And-No-CEL&p=204766&viewfull=1#post204766
READ THIS TOO........
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
You may really appreciate the functions of a decade box to help determine values in blocks and compare how a DTC is initiated huh?
https://forums.ross-tech.com/showth...uot-JPPSG-quot&p=183939&viewfull=1#post183939
treefort
Canada
C?ID=380169
You are thinking replacing the g450 sensor with the decade box to figure out what pressure trips the DTC? I have a handpump and pressure gauge I could also use. Unless the lamp illuminated, how would you know when the DTC is on?
I just did an hour highway drive watching DPF related temperatures, pressures and regen status. Everything seemed good. Ive attached a screenshot of the values while parked idling at the end of the drive.
https://imgur.com/aY3bGO6
P2002 code came back up after doing an auto scan..and no CEL on again. Freeze frame values all look low? Can you please help decipher which values set off the code?
Friday,19,June,2020,11:19:21:33381
VIN: 3VWPL7AJ6EM605504   Mileage: 120410km-74819miles
   Coding: 0350078
                    Mileage: 120327 km
                    Date: 2014.11.10
                    Time: 00:48:60
                    RPM: 1771 /min
                    Speed: 90.0 km/h
                    (no units): 30.6
                    (no units): 20.4
                    (no units): 2.00
                    Pressure: 49 mbar
                    Pressure: 23 mbar
   Revision: 00H31001
   Revision: 00001019
   Coding: 0010004002
   Revision: BJ122001
   Coding: 009795
   Coding: 00004E43
   Coding: 188A140000
   Coding: 820000
                    Fault Frequency: 100
                    Reset counter: 93
                    Mileage: 118851 km
                    Date: 2020.06.06
                    Time: 22:29:24
   Coding: 370F00
   Coding: 352002
   Coding: 0004B5
   Slave Driver:
   Coding: 000490
   Revision: 00H22000
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
131584 - Motor for Rear Window Regulator
          B11EE 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 53
End----------(Elapsed Time: 01:08, VBatt start/end: 12.6V/12.6V)-----------
aY3bGO6
Coding: 0350078
When the sensor values go outside the range as specified in the diagnostic stack of flash, a DTC is set to pend at the respective value during a DCY completed, after the needed fault reoccurs in next DCY or conditions met, the DTC will become a DTC to illuminate the MIL when confirmed.
Are you sure the signal lines are not plugged with FOD or inverted for sensor locations?
Have you checked the actual PSI of the sensor lines to correlate to block values using mighty vac and determine if the sensors data as reported to controller are within spec as seen on your gauge?
Have you defaulted the ECU by re-code with a valid WSC & importer # yet because I see no change + reboot?
That data in last scan read in red shows as if from or implies from when controller was new...........
Many (most?) engine/emissions related faults have to exist for several drive cycles before they trigger a MIL.
The RTFB will tell you exactly when or if a DCY will pend DTC depending on frequency.
ModelJetta Variant
GOV
Date of production26.08.2013
Model year2014
Sales typeAJ539M
Engine CodeCJAA
Transmission CodePPY
Emission standard7GBEmission standard ULEV 2
P2002 Particulate Trap
Efficiency Below Threshold Regeneration Service must be performed. Refer to 01 Chapter
Regeneration and Diesel Particulate Filter Checking
Check the Exhaust Pressure Sensor 1 -G450- / Differential Pressure Sensor -G505-. Refer to → Chapter „Exhaust Pressure Sensor 1 - G450-, Checking“.
Differential pressure Signal < (exhaust gas volume flow)
or
Accumulated loading increment from differential pressure < 1 g
Time since engine start 90 Sec.
Exhaust temperature downstream EGR - cooler >60° C or < 200° C
HP - EGR valve < 30% open
LP - EGR mass flow > 17 kg/h
LP - EGR valve > 55% open for > 2.5 Sec.
Temperature downstream DPF < 400° C or >140° C
DPF regeneration = not active
Above conditions must be fulfilled accumulative for 40 s to get a monitor result
6 s l 2 DCY
