- Joined
- Mar 9, 2015
- Messages
- 476
- Reaction score
- 336
- Location
- Australia
- VCDS Serial number
- C?ID=241363
Hi All,
This is a bit of a naughty post from me, apologies in advance...
I had to rush off so make full admissions that I haven't yet done the basic 1st lot of checks with respect to confirming wiring etc
I did do continuity checks between the steering connector plugs at pins T41/26 and T41/29 to ECU pin T94/45. Have not yet had a chance to check measuring blocks in ECU when cruise stalk buttons are pressed.
Nonetheless I would appreciate any advice from any PQ25 experts (iichel )
So I have helped a friend with his 2014 2HA Amarok install some basic comfort features.
He got a cluster and highline BCM from a Polo, got stalks with cruise again from a Polo and MK6 GTI MFSW.
Original scan:
More to follow...
Original scan:
Wednesday,17,June,2020,11:54:39:58930
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WV1ZZZ2HZEA009865 License Plate: CSM82F
Mileage: 51880km-32236mi Repair Order:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 19 25 56
VIN: WV1ZZZ2HZEA009865 Mileage: 51880km-32236miles
Address 01: Engine (------CFPA) Labels: None
Part No SW: 2H0 907 115 HW: 2H0 907 115
Component: 2.0l R4/4V TF H06 0002
Revision: P8H06--- Serial number: 00000000000000
Coding: 01190012430500010000
Shop #: WSC 07456 000 09999
ASAM Dataset: EV_ECM20TFS0112H0907115 004001
ROD: EV_ECM20TFS0112H0907115_004.rod
VCID: 619F5B4F71C7C9233C5-8034
Readiness: 0000 0001
Address 03: ABS Brakes (-----) Labels: None
Part No SW: 2H0 907 379 M HW: 2H0 907 379 D
Component: ESP MK25A XT H44 0111
Revision: 00H44001
Coding: B07324B689940D9E24AA91A9AF55F0
Shop #: WSC 07456 790 49164
VCID: 3A2DCC23BC51FAFB5DF-806E
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 2H0 907 047 E HW: 2H0 907 047 E
Component: Climatic-T5 H20 0505
Revision: 00001009
Coding: 0000000002
Shop #: WSC 07456 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 2A0DFC634C714A7B2DF-807E
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 086 P HW: 6R7 937 086 P
Component: PQ25 BCM H30 0561
Revision: -3------ Serial number: --------------
Coding: 640000380C210000002008102C4B84C40040410E60020000300000000003
VCID: 50F98E8B0AED50AB83B-8004
Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 002 3323
Coding: 050000
Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 002 3323
Coding: 050000
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00H H07 0013
Revision: -------- Serial number: 003HN00D0HRE
Coding: 000000000000000000000000000000003048
Shop #: WSC 07446 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3333E1079BBB0BB39E9-8066
Serial number: 3495RRB400O50JHIB8L+
Serial number: 3505RRB400K50JB27HG7
Serial number: 3555YRB400E50GQ0G9MU
Serial number: 3565YRB400E50GQ0EGLZ
Part No SW: 2H0 920 860 D HW: 2H0 920 860 D
Component: KOMBI H04 0709
Coding: 170200
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 270B05575F637713321-8072
Part No SW: 6N0 909 901 HW: 6R7 937 086 P
Component: GW-K-CAN TP20 H30 0561
Revision: -3------
Coding: 742100
Shop #: WSC 07462 790 50316
VCID: 70B92E0BAAAD70ABA3B-8024
Component: IMMO H04 0709
VCID: 6A8D3C638CF18A7BEDF-803E
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 534 5314
Revision: -------- Serial number: VWZZZ4H6244611
Coding: 16000400040005
Shop #: WSC 00078 790 00206
VCID: 46D5A8D3F8A98E1B297-8012
End----------(Elapsed Time: 00:36, VBatt start/end: 12.1V/12.1V)-----------
More to follow...
